Dodge Dakota Electrical Problems
Here's the discussion to talk about any issue you have with electricity or an electrically-powered component.
I went to the parts department of the dealer to get a flasher. They sold me a 'relay' for $47. Owner's manual does not show a location.
Anyone have any advice as to the problem. If the 'relay', where can I find it in the truck?
As yet I cannot locate it in the truck.
Good Luck Ger.
Jim
kcram - Pickups Host
*)Fan motor drawing too much current.
*)Blocked airflow. (the resistor is mounted in the airflow to keep it from burning out!!)
Inspect the connector and the five wires that connect to the resistor board. Using a strong light, look closely at the terminals as well as the wires from the top of the connector. Are there any signs of corrosion (green residue) or melted plastic? Pay close attention to the two strped wires in pins 1 & 2. Do they looked burned or show signs of the insulation melting?
If so, the contact resistance is high or the conductivity has been reduced at the terminals and is causing conductor overheating.
Order Chrysler part 5017124-AA to repair. This kit contains new wires with crimped on terminals and a connector body with a new moisture sealing membrane.
Dusty
The listing inside the panel cover lists #12 as the Starter fuse and there is no listing for an IOD fuse. I tried pulling #12 fuse and there was no snap-in retainer. If anyone can tell me how to identify the IOD fuse and where it is located, it would be greatly appreciated.
Thank you in advance. Ken
A somewhat common problem of intermittently blinking lights for that year Dakota is the Light Switch mounted on the instrument panel.
Dusty
Eighteen volt output is about the max for a regulated system. The check engine indicator lamp is illuminating because the Electronic Voltage Regulator (EVR) electronics in the PCM is seeing an abnormal charging rate.
The normal maximum charging rate varies according to temperature of the battery, from about 12.6 volts at 100 degrees F, to 16.0 volts at 0 degrees F.
The fact that the alternator is charging at 18 volts indicates that the battery is taking an excessive amount of charge current. It could be caused by a battery that is not holding a charge or is starting to develop a low internal resistance.
Electronic Voltage Regulator failures in the PCM have been amazingly rare in Chrysler vehicles in my experience. I'd more believe you have a wiring problem or a flaky alternator at the moment.
How old is this battery and have you just started to have this problem since its turned quite cold? (I'm assuming you are living in a North American winter climate area.) I've seen batteries play tricks on good auto technicians and I have experienced a similar scenario myself on a '93 Nissan Sentra. The battery could be the problem here.
My recommendation is to install a new or known good battery from another vehicle and see if the charging situation remains the same. If it does then you probably have a wiring problem (to the alternator), a bad alternator, and lastly, a bad PCM.
Good luck,
Dusty
Kidding aside, The cheep rebuilding process allows the prices to be VERY low and attractive. But BEWARE! -- you are the tester of the alternator. If it fails, you have to remove it and take it back so you can have the privlidge to get another untested alternator.
For me, the labor to replace an alternator several times just to find a good one is FAR more expensive than just installing a KNOWN GOOD alternator once.
This truck will run fine for a while then the "Check Gauges" light will come on. Shortly after that the oil and fuel gauge will go to their maximum limit (H and F). Sometimes, but not always, the volt meter will drop to below 8 volts while at the same the alternator starts charging at about 17 volts. The truck will sometimes start running rough caused by a rich fuel mixture (based on the black smoke it pukes out). Once the ABS/Brake lights have come on when all this happens and once the airbag lamp has come on.
The "check guages" lamp will then turn off and the truck returns to normal.
This has been going on for about a year and I have found no weather condition (hot/cold) or sequence of events that causes this to happen. The problem may occur right at startup or take several days to happen.
The dealer says bad PCM. I sent the PCM to be check and repaired if need be. The PCM was determined to be operating correctly.
Please help me before I drive this thing into a lake and give up
Speaking battery temperature, I don't know if they had a battery temperature sensor in the battery tray that year, but if they did and that sensor was bad or the wiring defective, you could get over or under charging.
At the moment I would be trying a Mopar new or rebuilt alternator. I know they're more expensive. But I've had so many bad experiences with aftermarket rebuilts over the years that I just don't go that route any more.
Best of luck,
Dusty
I 'll post the the solution so others with he same issue can have a ray of hope.
I know that this sounds like an issue with the fuses or the switch, but I have already replaced the switch and the fuses are good.
The next step in the trouble-shooting process reads "take to a professional, put out lots of dough."
Any takers?
Dusty
(side note: it's weird that I see message "1 of 3" and this message is "3 of 3", but there appears to be no "2 of 3")
When I get the opportunity, I will be checking the fusible links...then try to find myself some more hair, as I am pulling all of mine out trying to fix this.
Tim
SINCE THAT TIME I HAVE INSTALLED A NEW CRANK SENSOR, NEW CAM
SENSOR, AND A MOPAR PCM. It is still sitting in the shop.
1995 Dakota C.C. 4x4 318 auto. 178,000 mi. Ran 16.44 sec. 1/4 mi. last year just for fun.
Today I had a problem.
Starts, stalls, worked the throttle,almost to and to the W.O.T.,
Pedaled it to keep running, Always runs like a raped date. Still did today after warming up. drove to work with two feet,(one on gas at stoplight.)
I'm ASE CERT. in Susp. and Brakes and have been doing this for awhile. But I'm stumped.
Sometimes crank/no start, sometime fires up runs fine,dies in about 1 min.Dies like I turned off the key.Sometimes cranks and I have no spark or fuel pressure or injector pulse.Sometimes I have all three.
Fuel pressure is constant 38 psi.-on start/stall/dead/restart.
Also always cranks over strong.All the time
After it dies I hear a click from a relay under the hood and fuel press. jumpsto 40 and back to 38.
Still has spark after dies.I put a spare plug in #2 wire that I disconnected. Started and watched spark plug until engine died,
the spare plug was still firing as engine spun but not running.
Got gas and spark but it don't run. Who told the injectors to quit!!?
I ruled out the cam sensor(pickup coil) but two local gurus said put one in. So, $30 later same problem. Charging system is good too.
I'm leaning towards PCM. But don't want to waste $250 on a non-returnable part.
Any other suggestions?
Any ideas or similar experience resolved would be greatly appreciated.
