Dodge Dakota Tires and Wheels
Talk about your Dak's running gear here!
I run Nokian Vatiiva tires (P265/75R15) on my 2000 Dakota. (I paid under $90 each per tire)
The reason I chose Nokian Vatiiva is because Nokian makes the best snow tire in the world (the Hakkapeliitta) and the Vatiiva is based on that design.
I do want to comment on your choice of tires ("Passenger", "Light Truck" or "Truck")...
*)The PASSENGER tires (starting with a "P") will give you the best ride quality.
*)The LIGHT TRUCK tires (Starting with "LT") will have slightly rougher ride but will handle more weight.
*)The TRUCK tires (31X10.5R15)will have the harshest ride but will be able to carry 300 lbs of wight daily. (for example a large toolbox in the bed of your Dak.)
Basically, as you move up in weight-carrying ability, you get more sidewall plies but less tread deapth. The heavier tires also cost a lot more.
Personally, I only carrry heavy weight about 3 times a year so I went with "P" rated tires so it does not ride like a rock the rest of the year.
In other words, if you carry a load in the back of your truck EVERY SINGLE DAY... then go with the tires that have more sidewall plies for stiffness.
and handles like my toyota x-runner.........Is there alot of
snow where you live.......I'm in PA so there not been to bad of winters lately
I am glad I do not have 18inch wheels such as yours. The choice of tires is limited and VERY expensive. I bet your tires cost more than $90 each.
Yes - Vermont gets its share of snow. I specifically orderd my Dak from the factory with every traction-improving option available. (Including MANUAL xmission!) Of course, when locked into 4X4, it likes to go only in a straight line.... but this is the nature of a true 4 wheel drive when the front wheels are trying to spin at the same speed.
I just purchased a 2004 Dodge Dakota SXT, my question is the truck has P255 65R / 16, is this the right size tire that came on the Dakota new? I am not sure when I have the tires changed if I should put 16's back on it or is it suppose to have 15's?
Also it looks like the outer side of the tire is wearing more then the inner side on the front, and ideals? Thanks Bobby
It is not possible to put 15 inch tires on 16 inch wheels.
As for your possible uneven wear, you need to have your truck put on an alignment machine.
It is best to get an alignment at least annually to prevent excessive wear on your expensive tires.
Also have all the ball-joints and other suspension components checked.
I assume you rotate the tires regularly. (most tire-sales places will do this FREE of charge)
I'm looking to replace OEM Goodyear Eagle LS, P255/65R/16 tires for my 2003 4.7L QC 2WD. Has anyone had any experiences with and/or can provide feedback for the following tires:
- Nokian WR SUV
- Goodyear Fortera Triple Tred
Thanks in advance,
dataguru
I'll likely go with the WR SUVs in the factory size P255/65R/16 or maybe slightly wider in a P265/70R/16 size. If I pick the wider taller size, will it raise the 3.92 differential drive ratio (i.e., to a lower number) due to less revolutions of the tire?
dataguru
I run the Vativva "P" on my Dakota and the WR on my 56MPG Volkswagen TDI.
To answer your question about changing the outsied tire diamater -- DONT DO IT! The Dakota factory shop manual warns that changing the tire diameter will affect the function of the ABS system.
If you REALLY want to change the tire diameter, the service-manual recommends reprogramming the onbobard computer so the ABS system and speedometer are accurate.
Thanks again, Bruce, you are a gem!
dataguru
http://ohio.adtaker.com/recalls/info.aspx?mk=NOKIAN
dataguru
Six-bolt wheels torque more evenly and are generally thought to contribute to reduced lateral runnout and thus less wheel vibration at speed. They also provide a stronger mounting under high torque and stress load conditions.
You typically will not find six-bolt Dodge wheels for the Dakota in many places because...well they're not for Chevies, although the bigger custom auto places here in Rochester, New York seem to carry them.
Dusty
Even if your Dak has 4 or 5 bolt wheels, you would have the VERY SAME PROBLEM because most folks do not carry Dodge wheels. You problem is not the 6-bolt pattern... it is the fact it is a Dodge. (Dodge=Different!!)
I assume that you are aware that 5-bolt Ford is not interchangable with 5-bolt chevy nor 5-bolt Dodge...they are ALL different bolt patterns. (diameter of bolt-pattern is different)
Have you tried researching for a replacement dodge wheel on the internet? There are MANY places which should carry what you are looking for.
Does anyone know if rims from a 2004 f150 will fit a 2003 dakota 6 bolt?
Dusty
kcram - Pickups Host
