Subaru Baja Transmission Troubles
Discuss transmission issues with your Baja here.
It took several trips to the dealership from April-November 2005 to convince the service manager that there was a problem, but finally after 3 technicians rode with me, the dealership ordered another tranny from Peru and installed it in early 2006. :sick:
Guess what? The grinding noise was still there.
Too much time was wasted with that dealership in Pennsylvania, so when I found myself in Kansas City late this summer, I took it to a Missouri dealership. They too decided to replace the tranny and did so, but guess what? The symptoms have become worse. :mad: Now, when first driving it, the tranny 'clunks' from 2nd to 3rd and after it warms up a bit, it grinds between the same two gears.
Question: have any of you experienced similar problems or heard of a grinding noise?
I am now set to meet with the district manager on 27-Sep-06 as a next step. I hope I don't have a :lemon: !
Thank you,
Todd
http://forums.nasioc.com/forums/
Good luck!
Hmmm.
John
I noticed he front right CV joint boot was cut.
I brought the vehicle to the dealer to replace the boot.
They replaced the front right axle.
After replacing the front axle (part cost $488 + labor = about $600) the clicking/clucking noise was still there.
I brought the vehicle back to the dealer, it seems now the noise comes from the transmission.
FYI I had to change a front right bearing at 30000 miles under warranty, but the front right axle was replaced at 78 000 miles? Coincidence or miss-diagnose? The dealer passes the ball to Subaru, Subaru passes the ball to the Dealer!
Transmission problem at 78000 miles it is unbelievable! Otherwise the car drives fine, no problem. Only when the wheels are turned full way there is clucking sound like if gears do not catch correctly. Sound comes mainly from the front right side. Turning into a parking stall is when the sound can be noticed really well. Could it really be the transmission? I have to pay $550 just to put down the transmission and check what is going on. Any idea if it can really be a transmission problem?
Anyways, I would say it's probably the front diffy, not the transmission, the front diff however is inside the trans
-mike
At least I understand why they have to drop the transmission, it seems logical.
On the pother hand, $75 wholesale for the front axle and I paid $488
I am waiting for them to tell me what is the exact problem. But is seems to explain why the sound is heard only when the wheels were turned all the way. This is low mileage to have a bad front differencial.
What could have caused that?
