Chevrolet Equinox: Meet the Members!
Let's have our "member" chat here. I only ask that if you raise issues you think will have general interest then please post or repost your message and responses in the appropriate specialized topic.
Thanks and enjoy!
Thanks and enjoy!
GM has been very good with us we had the original battery replaced just last friday because it was shorting out and not holding a proper charge. Really showed up when the temp goes down to -20 -30 celuis when you need alot of cold cranking amps to start the vehicle..
Let be tell you what happened with my 05 Equinox, could be the same thing.
There was a humming sound coming from the back and I made some little tests to see what it could be.
When rolling I put the truck in neutral, the sound was still there, rev the motor, the sound didn't change, put the truck in park (motor running), no humming sound. The faster I drove, the higher the sound was. It was a sound like I'd be rolling on tractor tires. Letting the truck roll by itself (on neutral) the sound would change when the truck was slowing down, going down a hill on neutral the sound would change picking up speed.
Had to change a left rear wheel hub bearing. That was it, no more humming sound, it was riding on air.
Hope this helps.
