For one thing, if the struts were worn out, the car would keep bouncing and bouncing. The fact that it "bar[e]ly moves" is proof that the strut cartridges (which function like shock absorbers) are in good shape. The only way that bad struts would cause a stiff ride would be if the springs were binding.
Second, find out if the dealership is a member of BBB, and if so file a complaint with them.
Third, call Hyundai Customer Service and tell them what happened.
Finally, never go back to that dealership, unless it's to buy a part or pick up a refund check.
I recently test drove a 2001 Elantra in a used car lot. It has 80,000 miles on it but the body is immaculate. I checked the glove compartment and found a ton of service receipts from the previous owner. The car shimmied on the highway; the new battery was loosing power so the alternator was replaced; brakes and rotors were replcced three times in about one year; power steering hoses too. Also, the car apparently stalled on the highway, but mechanic couldn't find the problem. The check engine light was on when I took it for a test drive (it otherwise drove very well)
On the one hand the car sounds like it might be a lemon. On the other, it has all new parts now so one would assume the problems are solved. Price is right -- $3000.
As a loyal Toyota owner, i'm very nervous about this car's reliabilty ratings.
Should I buy it?
The model itself has been pretty reliable (I owned a '01 Elantra for many years, my sister still owns it and it's been reliable). But I don't like unresolved check engine lights, even though it could be a minor thing like a sensor.
I used the usual search engines, e.g. autotrader.com and cars.com, to find most of these cars. You can do a search out as many miles as you like. You can also frequently check the Carfax report for the car online--some dealers provide access to the report in their ad. I use the search engines to narrow the field down to several cars that could meet my needs, then I go check them out, first by email and phone, then if there's no issue I check them in person.
1) kink in fuel filler hose
2) fuel in the carbon canister (which can happen if the tank has ever been "topped off")
You might ask the mech if they checked those things. I have found the type of pump matters with my '04 Elantra. On most pumps, no problems fueling. On others (especially at a particular station I frequent), I have to use the lowest setting on the pump and even then it shuts off with 1-2 gallons free space in the tank. So does this happen every time you fill up, at every station?
they said the same thing to me...
Help!
Weak alternator/belt/failing battery.
Bad plugs/wires.
Bad gas/moisture in the tank.
Clogged fuel filter/failing fuel pump.
The gas issue is the easiest & DIY thing to check. Get some gas line drier and run a few tanks of premium gas from a Top Tier brand.
Possibly. If the moisture buildup was mostly burned off then there wouldn't be any more to cause problems.
I'd still suggest the gas line dryer & premium gas. Call it cheap insurance.
What is happening??
OK, where's my car electrical expert here in the forum?
I replaced all spark plugs and wires and never had another problem. I don't know how or why moisture seemed to be a factor, but the problem went away and that was all I cared about. Hope that helps!
What about ignition control module? Would that be affected by moisture? Or should I stick with plugs and wires? Relatively cheap starting point, I would say.
Thanks for the continuing tips, folks.
Considering that it works OK at lower fan speeds (which would use less power) my first assumption would be there's another component (or components - plural) on that fuse that's drawing more than it's fair share.
When the fuse blows do you notice anything else that stops working (lights, radio, rear defrost, power windows, etc.)?
A good tech ought to be able to see what all is on that line and check the power draw at the individual component level.
Replaced the battery the first time but it kept doing this. Took it to the dealer and they said the negative battery cable was loose. They tightened it and it was fine for several days. Then it began again. Took it back to the dealer and they said the spark plug wires needed to be replaced. Had them replaced and it was fine for a few days. Now its doing the same thing. There seems to be no pattern as to the frequency of this happening. Your thoughts?
The car is a 4 cyl. with 90,000 miles. I also have a 2000 Elantra with 176,000 miles and no
problems. I was just wondering if anyone had a similar problem since my mechanic said that this is common.
I have a 2001 elantra and one day I came to a stop and I could feel my brakes pushed farther to the floor to stop than usual and when I got to my house I could smell what smelled like brake dust so I walked around and check the tires and it was my back left wheel. The rim was hotter than the others. I called my brother in-law, who works a little on cars and he said it could b the drum or bake line. Anyways I drove the car for about a month and I never happened again. Well today I come to a stop and I here this really loud scrapping noise. I take it to my dads and we put the car up on the lift and check the brakes, well my inner brake pads are grinded to the metal and my left rotor is bad. I got the pads and a new rotor, but I don't just don't want to fix what the problem caused before fixing the problem. Would you have any idea what might be the issue here or ha anyone had this problem as well?
Chris
