Honda Odyssey Transmission Problems
1303133353647
    Faster? I doubt it. You really don't need any special tools to rebuild one of these units.
    Cheaper? You bet. If I did these every day I'm sure I could finish one in 2 days.
    You are contradicting yourself here. But anyway, dealer techs also don't want to spend 2 days rebuilding a transmission. It's not profitable for them unless that's all they do. Techs get paid flat-rate on a job, not by the hour.
    Compare your factory pay rate in Japan vs. paying a U.S. Tech to do the same thing.
    My understanding is that they are being rebuilt in Alabama - not Japan. Those techs are probably rebuilding 1 a day because that's all they do.
    Now, it costs HOW MUCH to buy one of these from Honda? $4,000.
    Well the $500 you spent isn't the only cost - labor to rebuild, shipping, warranty, profit margin for Honda, profit margin for dealer, tech labor to install. Yes, there's profit in it but since we aren't a socialist economy, I don't begrudge them.
  • lbreeslbrees Member Posts: 3
    My brake lights on my 1990 Accord are stuck "ON" and the only way I can turn them off is to pull the fuse. Anyone have an inexpensive solution to this problem?
  • pgnagelpgnagel Member Posts: 60
    I'm not contradicting myself, you just didn't understand what I wrote.
    I'm not going to get into a shouting match over this. The part is $4,000 plus another $1,000 to install at the dealer. I spent $1,100 total on my project. I'll gladly absorb any risk to save that kind of money and have the experience of doing the work. The replacements are grossly overpriced period.
    My point in all of this is that the work of rebuilding that gearbox isn't worth $4,000 no matter who does it, and I'm stating my case so if there is anyone else out there who wants to try it I can offer them some help. The warranty on these units is gone, and not everyone can afford to cough up the dough to have Honda do the work.
    My dealer was under the impression that the rebuilt units were in fact coming from Japan, but it doesn't matter where they come from, they're too expensive. Also, anyone who does rebuild one of these things has to understand proper filtration and heat management on the new unit or they will be going through this again.
    So, pick up your wrenches and get to work or go get stuffed. And don't try to tell me what I already know, especially if you've never done it yourself.
  • polsobrpolsobr Member Posts: 5
    Hi.Were you the one who said they would send out a summary of the rebuild, if so that would be fantastic. Thank you so much
    I would give it a try. I have it on my shop floor and was just thinking of starting this. Thanks for sharing and posting. Any tips would be great. I've rebuilt turbohydramatic 350's before. Never one of these. thanks again.
    Hey Browneee. What or where is the 3rd gear pressure component. Thanks for your help.
    Hi All. I have a 01 ody that shifts great, smooth- no issues other than the 0740 code. No symptoms at all. I have read about cleaning screens and 3rd gear components. Dealer checked and said all solenoids are working fine!! What to do- what -to do!! Thanks
  • cootedslcootedsl Member Posts: 1
    #10361073 2004 Odyssey overheated
  • loveourhondaloveourhonda Member Posts: 1
    I am interested in summary of the rebuild. I have a 2000 Odyssey with 230K and my tranny oil is starting to slip. I've changed the oil twice this year which helps temporarily but it won't last much longer. Interested in whatever you can send me. Can you get parts directly from Honda?
    Before you yank out that gearbox, you might want to consider adding a few things to see if they help. If I were doing this again I would hae installed a Hayden 678 cooler (which I will do shortly) along with the Mangefine filter (which I did a few years ago, and it helped dramatically). Service the transmission one more time to see if it helps.
    By the way, a freshly rebuilt transaxle (part B7TA) holds just over 6 quarts of fluid when completely rebuilt, so a servicing replaces about 50% of the fluid. This is better then most GM transmissions by a long shot.
    Let me know what happens when you add the above items. I think they will by you at least another year of driving. Then we can talk about the rebuild, likely through another medium or I might be able to do a website about it.
    Thank you for the information, this site and your contribution has been really helpful.
    I serviced the transmission with synthetic, added a additive called Seafoam and cleared the code. So far - so good. It's amazing the abuse a trans can take with old fluid in it, people never think about that oil until thinks start to act up. Thanks again.
  • 2005honda2005honda Member Posts: 6
    I am facing my first replacement/repair it seems. My 2005 honda od growls/grunts/groans at low rpms and hunts at certain speeds if not pushing the gas much; 35-40, 65-70.
    I must ask, what wording did you use exactly to convince honda to change out 3 of your transmissions? Any other advice other than sell at 100k?
    Thank you, Thomas.
  • joycewujoycewu Member Posts: 1
    I also have 2001 Odyssey and it just reached 60K miles last week, and the two lights became on recently. I sent my car to do the transmission service last week, which did not help too much!
    After read all the messages here about Replacement Transmission, I was very sad about these news. This is my first Honda car. Also, I am the first owner. I just called the Honda dealer today, and what I got was: "Sorry! Your warranty is expired, we could not do anything about this issue." I really don't know what I should do so far. Just spent about $ 4000~5000 in getting a new transmission in the dealer? Or find other store to fix the problem?
  • dboweringdbowering Member Posts: 3
    Personally I would spend the money on a Jasper transmission. They have a great warranty. Note that you will pay more money for that brand but not as much as you would at the dealership. My 2004 Odyssey tranny went out this past August. I went to an AAMCO dealer and am starting to regret my decision. The van still shudders @ 45 mph at 1200 RPM's. I've had it back to them twice and they keep telling me there's nothing wrong. I've got a 12,000 mile/12-month warranty on it and am hoping the tranny falls out soon!
    Hang in there. Other than the tranny issues (which is a huge issue) I have really enjoyed my Odyssey
  • autowriteautowrite Member Posts: 226
    That's all great & good on a Jasoer transmssion in the USA but where would they be located in Canada.
  • fuvangfuvang Member Posts: 6
    Look folks, I got lucky I think. I changed the transmission fluid myself and my van stopped shaking. I have a brother in law who is a mechanic and says the torque converter box is very sensitive. So if you haven't changed the transmission fluid or have had the Honda shop done it, do it yourself one more time. It cost only a little over $30. Once you change it, it may make a difference. Worth $30. Plus don't trust Honda shop... the Honda shop in Asheboro, NC told my wife it was a mount bracket broken and would cost over $1000 to fix, plus they will service the transmission fluid... I didn't trust them, just serviced the transmission fluid myself, took 1 hour b/c engine was hot, ta da, fixed... good luck to all and if you don't know how to change it, let me know, very simple.. if you can change a tire, you can do this...
    These transmissions need to be kept clean and cool. Although the newer models have a serviceable filter, I would still recommend putting a redundancy in the system in the form or another filter. Also, remember that as those filters get used and begin to clog up you can have pressure drops in the system which can lead to all sorts of problems. Install a cooler as well. You can put in a nice one for less than $100.
  • cfdadecfdade Member Posts: 1
    2000 Ody 105K miles,1-owner. Oil, easy maintenance done by me, rest by mech/dealer. Engine light on, then TCS light lit on way home from tire rot/bal, Next morning, the shudder started when shifting or 3000rpm. Codes P1456 & P1259. Mech replaced faulty LF wheel sensor & LF wheel bearings...right & rear checked fine. Problem is lights still lit...dealer wants $100 to check...and I know tranny is going. Honda says regardless of my maintenence records, I'm out of 7yr/109K warranty and out-of-luck. Anyone try the tranny fluid service? OR the after-market cooler? Did it work? For how long? And...did the dreaded lights go out?
    Selling with known issues an integrity issue. Spending $2-3K for a vehicle with repetitive issues seems ill-advised. Thank you
  • captainlescaptainles Member Posts: 1
    Our 2001 Odyssey with 78000 miles had the same P0740 code. The dealer wants over $5000 to replace the transmission. The dealer contacted Honda for "good will" assistance, which was denied.
    Would you tell me who specifically you wrote to at Honda to appeal? I'd certainly appreciate it.
  • gr26gr26 Member Posts: 12
    If you can get it done for $2-$3K, to me that changes the thought process a bit. Could you buy a used vehicle for that price to replace the van? If the van is in otherwise good shape, 105K miles is not much. If it's a Honda rebuilt transmission, typically that would come with a 3 year/36K mile warranty (mine did). At the same time, you may be ready for a new(er) vehicle (grin).
  • johnboy18johnboy18 Member Posts: 9
    my family and i just came back from a 2000 mile trip in our 03 with 114000, we averaged 75-80 mph checked the mpg 24-25mpg wow i am very happy with this van. :)
  • dcguy2dcguy2 Member Posts: 3
    I have received a letter from Honda announcing my 2010 Honda Odyssey Touring model is subject to a recall to replace the transmission software. I have long noticed the odd performance at relatively low speeds, particularly going down hill, where the car appears to downshift, particularly as you hit the brake, and then suddenly the downshift happens and you slow much more quickly than intended, and it happens with a noticeable lurch that passengers have complained about. We'll see whether it makes any difference when I have the new software installed this week. I will come back and report anything I notice. The job is supposed to take 1.5 hours at the dealer, and be free of charge. :confuse:
    Thank you for the 2010 trans software recall update. Please do follow up and let us know if it drives any different. When you do post follow up, please include the honda recall info, link, or similar so we can see if our vehicles are effected, and/or qualify or not also.
    Also, do you know what years the recall effects and whether it is related to Honda's ongoing struggle with front and rear hydraulic engine mounts allowing vibration when running on less than all cylinders to save gas?
    Thanks again, T
  • tomcat7tomcat7 Member Posts: 5
    Do some simple checking before you Jump off! 03 Odyssey; 130K: Had local Honda dealer change oil at normal interval and "check fluid levels" A few days later tranny shifted hard and D flashed for about 7 miles; no other malfunctions. I checked tranny level and found it 11/2 inches above max fill level on dip stick! Took van in to another Honda dealer and ordered tranny drained and filled also stating that I wanted to see removed fluid. Mechanic filtered fluid with paint stainer as I watched. No metal, no deposits found, no metal on magnetic drain plug. Removed fluid was just a little dirty but mechanic said it looked perfectly normal for being used 30K. He did not measure amount removed, but agreed with me that it was probably over filled. Over filling can create excessive pressures and foaming in the gear train and possibly trigger the flashing D. Extended use can damage transmission. I have routinely checked level since new and it has never been as high as found. I'm sure first mechanic did not check level properly and added unneeded fluid. Words to the wise; check fluid levels yourself after having service; oil as well as transmission fluid. I'm having meeting with first dealer who "checked the fluid levels"!!!
    That flashing D is a warning of pressure in the transaxle case that is out of range. It won't trigger the MAL light (check engine light), and will go out whenever the pressure level returns to normal. Yes, too much fluid can trigger that light, but so can a partially blocked filter or fluid transfer tube. Honda transaxles have lots of those tubes, some accessible from outside the case, and some only accessible from inside.
    When was the transaxle serviced, i.e. who overfilled the case? If you drove it like that for a few hundred miles it probably didn't do any damage. The internals in that case are pretty stout.
    Dude, just change the transmission fluid yourself... especially if you have tried to let Honda shop do it... I don't trust them a bit... especially the Honda shop in Asheboro, NC... crooked.. they told my wife that it was the engine bracket mount and would cost us over $1000 to fix it... I may not know much about cars, but knew enough to follow through to see what they say is correct.. which it wasn't... anyways.. change it urself.. not hard..and will only cost u about $35 for transmission fluids.. good luck.
  • ghar88ghar88 Member Posts: 3
    Here is my situation:
    Odyssey 2002 - 89K miles -
    well known issue - accelerator increases rpm but not speed - check engine light is ON.
    One dealer did the diagnostics:
    p1750 Clutch Pressure Failure
    p1751 2-3 shift malfuntion
    p1676 fptdr signal failure
    road test harsh shifting 2nd to 3rd also flaring 2500-4500 rpm
    Dealer is asking:
    Replace Transmission
    Front Engine Mount broken - replace it
    Ignition Switch Electical - to be replaced
    Total cost = $4545 + tax
    I was talking to other dealer and they say:
    Alongwith transmission replacement, you also need PCM (computer ?) to be replaced - additional $1000
    So, went to AAMCO:
    they got the same codes as above. and tells me that those all codes are electrical - may not need transmission to be replaced. So, asking for 2 hours labor ($230) for further diagnostics. They said transmission fluid is low and contaminated. Now I had replaced transmission fluid 5 months back at local reliable auto shop.
    I'm the original owner of the vehicle. American Honda is saying 25% discount ==> ~$5000 cost.
    Of course, as most of us guessed this van will last for a long time without any major issues and kind of upset how Honda is treating it. Has anyone done any action against them?
    Mainly, I'm looking for some auto expert help on what shall I do?
    Have AAMCO spend another 2 hours and find out what really is bad?
    OR get it transmission replaced ???
    Any suggestion will be greatly help.
  • motyergmotyerg Member Posts: 2
    You are correct about changing the fluid yourself; it is just a little hard to get to without a lift. Your front engine mount may be bad. Ours in the 03 went bad at about 125K.. The engine would bump when accelerating hard. The front engine mount is vacuum operated. It stiffens up when the engine is torquing like during acceleartion, but at idle it is a shock absorber to dampen vibration. Honda dealer wanted $485 to change it out. I got it done for the cost of the part with another shop for around $200.
    The part had to come from Honda or at least we could not find one anywhere else.
    I'm beginning to believe the Honda dealers are driven to drive us out of the older vans and hope we will trade for a new one. Not gonna work with me! I think we are gonna drive something else real soon!
    Good luck,
    Just remember: Often free advise is worth what you pay for it! If it was my van; I would first try a drain, flush, and refill with a close inspection of the fluid at each drain. If no particles, in oil; try it out with new fluid. If not better, you may have real transmission issues. I would go find a Jasper dealer to see what a remanufactured transmission from them would cost; I have also heard good things about how Cottman treats their customers. I would do a lot before spending $5k with Honda!
    Good luck
  • xjbearxjbear Member Posts: 2
    edited November 2010
    after owning my 03 odyssey for awhile now, 50k miles since bought 101,200k now my dealer tells me i need a new trans. d letter blinked once in awhile over the last 2 years, but not alot, tcs lamp flashed a few times in the past but never got a check light, the dealer says no codes are coming up at all, just alot of slippage in the 2-3 gear upshift or 4-3 downshift and it lags awhile before reverse will kick in. was quoted $3500 by dealer, called Honda 1-800-999-1009 and got a case# yesterday, they called back today with more questions, said they would research the problem and my Honda "history" I presume, and call me back. I was very polite and can't wait to hear back from them, I certainly can't afford that expense right now. I've owned Honda cars and motorcycles for most of my adult life and love them, just did not expect it to happen 1k miles past extended warranty, especially since I buy Hondas based on the reliability. I've had 3 chevy pickups and work vans that ALL made it over 250k without a single issue save for the fuel pumps. i would like my
    Hondas to be the same.
    I also own a 2009 Accord
    My mom owns a 09 Accord also
    The recall is listed nowhere on the Honda website or any other recall website I can find. The letter from Honda notifying me of the recall says it applies to 2009 and 2010 Odysseys. I took it to the dealer and they did in exactly the 90 minutes they said it would take. I haven't noticed the problem that it used to have, but I haven't driven home from work yet down the hill in Georgetown, DC where I usually notice the problem when I'm doing maybe 20-25 mph, so it's hard to say. Noticing the absence of a problem is harder than noticing the problem of course.
  • jpfjpf Member Posts: 496
    I do this all the time no matter who services my vehicle. As soon as I drive out of the service center or dealership, I pull into a parking lot and pop the hood. I check the fluids and make sure the dipsticks are in place. I check the caps for the oil and coolant. In my experiences, I have found pliers, screwdrivers, a scissors, and a wrench under the hood. Another thing is that I never buy bulk oil at any rapid lube shop. Most of these places have kids working there. One time they overfilled a young lady's Plymouth Sundance and oil was gushing out everywhere underneath the car. The mistake probably did serious engine damage.
  • doggrandmadoggrandma Member Posts: 144
    I received the same letter for my 2010 EX-L. I wasn't having any problems, but the letter said that problems could occur if the software issue was not addressed, so I took it in and had it done. I haven't noticed any change in the van's performance, but I didn't have any problems anyway.
    I asked them to check the alignment, and they agreed it was off, but said they had to order some bolts to fix it. Sounds like there was a bigger problem than just the alignment, but as long as it is fixed with no cost to me, that's fine. Just thought I would let others know that if they feel their newer van is not aligned properly to have it checked.
    Here is what the actual recall letter says, since there's nothing about this at Honda.com:
    Product Update: PCM Update for Lock-Up Clutch Function
    This letter is to notify you of a potential transmission problem with your vehicle and what you should do to resolve it.
    What is the problem?
    A transmission judder (vibration) may sometimes be felt while driving between 20-45 mph. To minimize the opportunity for judder to occur, a software update for the transmission is available. If you do not feel the transmission judder, the software may prevent it from occurring. If the transmission software is not updated, the transmission may become damaged.
    What should you do?
    (take to any Honda dealer to "reprogram the transmission software" free of charge.)
    Felt what I thought was the original problem again today, which happens when braking, and it seems that the car suddenly downshifts at the same time, or judders for a moment, almost like the automatic transmission is trying to do some kind of engine braking thing. Don't really know what to say, but since they've been making automatic transmissions for half a century, you'd think this wouldn't be such a challenge for Honda engineers, would you?
    Yesterday I added a full quart of Seafoam trans additive to it and drove it for a half hour hoping it would break up whatever junk was in the trans. Today I did the whole drain tranny-refill-drive, drain-tranny-refill-drive, drain-tranny-refill routine. Added an inline filter to the cooler return line, which is the line closest to the drivers side on the radiator, 'your welcome', replaced the factory filter on top of the tranny, and installed a Rapid-Cool tranny cooler in front of the condenser. I used O'reilly Automotive Global trans fluid which says it is Honda Z1 approved and a "automotive filter"? inline trans filter they had in stock, a wix replacement filter, and no trans additives. So far it is shifting and not slipping at all, goes right into gear quickly and after it warmed up I did a few foot-thru-the-floor 0-70mph runs and it was flawless. I will knock on wood and hope that this lasts and was all that it needed, we will also drive this thing a little more conservatively now. I have a 150 mile trip to take Monday and I will post back with how it does and I will post over the long term, if I forget and you are curious feel free to message me.
    Thank you so much to all the people who have posted on all the forums and who have gone through this as well, the information so far has been a godsend.
    Bear
    If you continue to service that transaxle annually and replace the filter as well it will live a long and happy life. You really can't over filter or over cool the fluid in a transmission.
    Honda dealer tells me you cannot replace the filter. If you replace the transmision it comes with a filter that is not recplaceable. I do not know about 2005 & up models. I have a cooler since 259,000 kms (currently 267,000) Transmission on my 2002 was replaced at 180,000 kms. When you ask for a or throught standard maintence get you tranny fluid done not all of it gets replaced. Apparnetly you must do the fluid-maintenance 3 times and drive it in between to have completely new fluid.
  • longo2longo2 Member Posts: 347
    xibear, good job!
    I have a 2003 Odyssey as well and keep dumping the tranny fluid and wiping off the magnetic plug. Last time I did it I noticed that the magnet was getting weak so went to the local Honda Parts couinter and bought a new one for it. I recall saying that "this magnet is all that stands between me and your service counter"
    He said, "no, there is also a transmission filter you can change" He showed me the diagram and sure enough there was a little, what looks like a spin on filter that sits parallel to the top of the case.
    I have put a trouble light down there and for the life of me can't find the thing..I noticed that you mentioned changing yours...could you explain the process please? I thought it was on top of the trans case, but is it visible from underneath?
    Also, did you have to do any mod's to the line to the rad cooler to add the new filter?
    A service tech was standing at the parts counter and said that they "always put on an in line filter every time they have to change a tranny" but strangly enouigh, he said he had never seen the external filter!
    Would really like to hear more of your modification system.
    Thanks in advance for checking back...
    In searching for clues as to where that Honda Odyssey a/t filter is, I found this You Tube showing the a/t guts on a table and some very good info...but I still don't know where it is or how to get at that tiny filter to change it...
    http://www.youtube.com/watch?v=APC9JS6DdSo&feature=related
    Ok guess I'm closing in on the solution to my question...in looking at a website that sells all kinds of a/t items I found all the external filters listed for the Hondas and according to this, our 2003 Odyssey doesn't have an external a/t filter...just the 05 to 06's and the HOnda Accords V6's from 03 and up.
    Mystery solved...now I'm looking at the Magnafine filter products to add to my Odyssey a/t time bomb.
    FILTER, HONDA COOLER RETURN
    Code:
    Price: $5.71
    Quantity:
    ACCORD V6 (03-UP), ODYSSEY (05-06)
  • pilotnathanbpilotnathanb Member Posts: 7
    I have an opportunity to buy a 2002 Odyseey, with 75k miles for $5k. It sounds like a good deal, but I'm worried about the transmission problems I have been hearing about. It has been owned by a retired guy, who frequents my aunt and uncles hardware store. I have not seen it yet, but it sounds like a very nice, clean van. I just don't want to buy it and then have to fix the transmission for thousands of dollars. Would you buy it?
  • ark_honda_fanark_honda_fan Member Posts: 5
    I bought a 2001 Odyssey a year ago that had 75,000 miles on it. It was a single owner, all maintenance done at the dealership, owner said he never had any problems with the transmission, etc. One year later and now at 87,000 miles and I've begun to have transmission problems. In fact I am dropping it off tomorrow to get rebuilt at a cost of $2500-$3000. I thought I would be one of the people out there that didn't have problems, but sure enough I did. The local transmission shops that I talked to all say it's the same issue where the torque converter breaks down and pieces of the lining material clog things up. I could probably wait a little while on getting mine fixed as it's only slipping a bit, but I need to take it out of state for a long holiday trip and I need a good reliable vehicle - that's why I bought it, so I am biting the bullet and getting it fixed. Other than that, I am very happy with it and expect to have it for some time. I am willing to spend the money on the transmission, which will be the most expensive car repair I have ever had, because I think the van will be more reliable now and at least I know that the transmission issue has been addressed and shouldn't be a problem in the future. Transmission shop is giving me a 2 year, 24K mile warranty too. Hope this helps.
    That helps a lot, thank you. Right now we have a 1999 Camry and a 1999 Chevy Prizm (aka Toyota Corolla). They have both been excellent cars. We need a van, since we have three kids. However, I would hate to give up the reliablity I have enjoyed thus far for expensive repairs. Thanks.
    Remember: Free advise if often worth what you pay for it. But,,,2002 Odysseys were notorious for transmission problems. this one may have been replaced or repaired, there should be a record. You could have it inspected by a transmission shop like Cottman. At least have the transmission fluid drained and inspected by someone who know what to look for. 75K is not a lot miles provided all the scheduled maintanence was done. (tranny fluid changed every 30K) I believe there was a recall on 2002 for transmissions; check it out. One other consideration, it the price is right, you could afford to have a rebuilt transmission from Jasper installed and still get a good deal. Good luck; tread lightly!
    Thank you for your question. The Valvoline MaxLife Dex/Merc ATF is completely compatible with the Honda ATF Z-1 fluid used in your Odyssey. This product has been used in millions of Honda transmissions across the country, with no slipping issues. Valvoline stands behind the use of the MaxLife Dex/Merc ATF 100% for any Honda transmission requiring Honda ATF Z-1.
    >>>> >>>> Sent: Tuesday, November 16, 2010 12:49:34 AM
    >>>> >>>> To: valvtechline@ashland.com
  • jazzjune1jazzjune1 Member Posts: 1
    The Honda Odyssey 2001 extended their warranty to 107,000 miles because of known transmission issues. If your mileage is below 107,000 miles, please go to the Honda dealership. You may not have to pay a dime to get this fixed.
  • swap_njswap_nj Member Posts: 1
    I have 2003 Honda Odyssey. I had similar problem a month back with transmission (Oct'2010). It thought the transmission was not smooth.
    Gears were slipping. Few times I punched the gas, the rpms go up, but it takes a while for it to get into gear.
    So I showed to a NJ dealer (Open Road Honda). They advised me to fix something in transmission and also asked me to do timing belt package, which I did.
    It did cost me around 2500$. A month later (Nov'2010) my automatic transmission failed. The car stopped in mid of the road when I was driving with me and family with Flashing 'D' light and check engine light on. I had to tow in the vehicle to the same dealer on Black Friday (11/26/2010). Now today dealer called me and told I have to spent around 5000$ to fix the car after loyal customer discount.
    The error code which he mentioned to me are >>
    P0730-automatic transmission need to be replaced
    P0845-There is problem with 3rd gear pressure issue
    I checked online and my car is in the list of RECALL for 'Automatic Transmission'.
    I have 120K on my car. I called Honda company they told me the vehicle is not on under warranty and so they cannot help. Dealer did not fix the issue earlier when I had shown the car to him for transmission related issues. Now he is asking 4700$ to fix the same as now Check engine light is on.
    Not sure should I blame the Company , the dealer or myself. :-)
    Talk to a lawyer b/c the dealer should have fixed what you brought in.. especially you had them fixed it... what they didn't fix.... and told you they did... sounds like a good case to talk to a lawyer..
    "swap"..
    There is enough blame to go around several times on this one. Let's start with the obvious culprit...HONDA.
    They started having trouble with this a/t early on and it wasn't just the Odyssey but all the other Honda line that used the same a/t right up to the Acura.
    For some reason I still can't fathom, when the same parts fail early and the Mnf;er is aware of it, why didn't they fix it ASAP? This same transmission was used for years with the same issues.
    Ask any re-builder about the thing and they will point out the weakness and flaws ...all in the same places. Bad Clutch pack for the third gear, lack of lubrication on another gear that burns up , and a torque converter that turns to shreds and plugs up the lube flow to the entire transmission.
    If you hate hanging around a/t re-build shops, just do a Youtube search for Honda Odyssey Transmission Problems and you will find all the burnt, worn out parts spread out on re-builders benches. Keep on digging with the internet and you will find more forums like this one, with the same sad story as yours. (and mine)
    After years of the same complaints they did a patch up re-call to install a return line fluid mod' that re-directed some lube for the dry gears issues but never did anything to fix the rest of the weakness's in the the trans.
    It is criminal that a company as big as Honda can't engineer a better a/t and get it into the rest of the model years instead of just letting it go and denying their was a problem until the whole model line is redesigned years later.
    Under warranty they were putting in OEM rebuilt a/ts and guess what, with no mod's to the problem areas, they all had the SAME weaknesses! That's not just crazy, that's criminal.
    For a while the amount of Honda tranny troubles were statisically higher than even Chysler mini vans and that's really saying something for an outfit that was supposted to have a reputation for quality.
    Chysler never claimed that High Ground, and 'you sometimes get less than you pay for' was never truer than buying a Chysler Mini Van with their time bomb Tranny.
    But Honda came out with their "Pearl Harbor" line of automatics and the company never had the decency to do the right thing or their Lawyers to admit that they knew about it, until it was too late.
    Their solution is Classic Corporate cold and simple, trade it off, buy the new 2011 "Broke-Back" Odyssey.... problem $olved.
    (for them ;)
  • wmozewmoze Member Posts: 1
    At 108,100 the dealer replaced my original transmission under warranty because while we were driving it the TCS light came on as well as the check engine light and it shifted hard from 1 to 2nd and to 3rd. I paid $551 for the labor and they covered the $3500+ cost for the transmission. Now I've got a little over 145,000 miles on the vehicle (roughly 37,000 on the replaced transmission) and it went out again. I took it to a new dealership (I've moved recently) and they gave me a quote of $4100+ to replace the transmission. I've just got off the phone with American Honda Customer support and they are going to have someone call me. Anyone else have a similar issue and if so what was the outcome?
