Chevrolet Geo Prizm Transmission
My 1990 Geo Prizm with 158,000 miles suddenly started making an clunk-clunk-clunking noise only when it is in gear, running down the road. It did this after a momentary loss of power during which time it felt like it was in neutral. At first, when I accelerated, the engine revved, but no geared response, then it came back, but with the clunking noise. This noise does not occur during idle, only when running down the road in gear. I have had no other transmission problems. I did have th eCV axle joints replaced about 2 months before this happened. Also, maybe related, maybe not, I checked the fluids the other day and found some oil in my radiator reservoir. No water in oil. Car has never overheated since I have had it (2 years). Any ideas about clunking? Not sure if I want to fix it or not. Thanks.
Theron
Any ideas out there?
THANKS
pulled pan and filter found dime size bits of magent
braking, but never while driving. It has been misdiagnosed by two mechanics, one said the fuel injectors need cleaning and did that and the problem continues. Another said it's the distributor but that was tested and that also failed to eliminate the problem.
At this point I'm at my wits end. I hope there a mechanical or computer genius out there that can help.
thanks!
