Buick Century Brakes
I have done many different brake jobs on the various cars and trucks that I have owned over the last 30 yrs. I have a 95 Buick Century that I am trying to do a rear brake job on and am totally stumped. I cannot find a schematic or exploded view of the rear drum brake system. Chiltons takes my money and then their books show nothing. I have one side apart and can not figure out how to get the large U shaped spring, that holds the entire assembly together and against the baking plate, back on! Any suggestions or special tools necessary... Help!
The day after the car was in the shop, I noticed that under hard braking the front of the car pulls to the left. Also, I have heard a high-pitched squeal coming from the front brakes a couple of times under normal braking.
Any ideas and/or suggestions would be appreciated. We plan to buy a new vehicle as soon as we can find something we like and don't want to spend any more money on this vehicle. Thanks.
Thank You,
Jeff Ripple
The mechanic does not seem worried but the sound makes me cringe, I dread the sound and the looks I get from others who hear the gosh-awful noise.
The other day I met someone with the same model and he has the same problem.
Suggestions? Solutions? Thanks for any advice.
Also, I was just told I needed new front struts and an o-ring (not sure of the name) the ring that holds the muffler in place in rear of car, to keep it from going back and forth. Also had a tire replaced, some mechanic put the wrong size on the car! He put a 195 instead of 185. Anyway, Now my car has a low grinding sound coming from the back. And, it does not drive as smooth as it did. The car has 65M miles... my brother thinks I got taken. Any advise on these issues?? Appreciate any help! Thanks!
James Ndirwo
The left rear wheel makes a awful noise and locks up when braking at low speed. The Service Engine Soon light, Anti-Lock light, and Trac Off light come on when put in reverse.I have looked at the lining's and drum and everything seems to be fine. Wheel clyinder is not leaking. Is this a ABS issue, wheel bearing issue. I have seen different posts on this issue on this forum but cannot get the full post or answers.
Thanks for any help
Hope this helps someone else if they have the same problem.
