Then I wait for about 20 mins and tried again, it got started without problem this time. All lights (The Check Engine/Low Oil Pressure/Check Battery light) were off when the engine got started. I drove for another 1 hour and the same thing happened again.
Does anybody have similar problem? Thanks.
http://en.wikipedia.org/wiki/Vapor_lock
The only thing the dealer thought, was that the signal from the key to the ECM may have been faulty, so he checked that out and all seemed well. We started using the spare key and haven't had any trouble since. Get the dealer to check your keys. They have a little chip in them that the ECM has to read. Gotta love computers! Good luck! Hope this helps.....
For a while I was really thinking that Hyundai has got things together, but unfortunately I was wrong. I’ve got to go back to Japanese cars! No I have a Korean and an American and I’m busy fighting with dealers about the problems there cars causing. But it’s entirely my mistake.
Because you said you had to spend 2 grand on repairs, I'm assuming your vehicle is out of warranty? Warranty covers the parts you mentioned less the freon. Hmm, must have been built on a Monday morning or Friday afternoon. Sorry to hear of your troubles...We had a '98 Grand Caravan Sport before our SF, and never had any trouble with it either. Just the luck of the draw, I guess.
How's your tires? Mine have 50K kms, and they're just about toast....
I guess those Bridgestone Duellers really are crap.
I'm not sure I see the connection between BBB and Lemon Laws. Can you elaborate?
SUVs and Smart Shopper
Illinois Lemon Law Info
Visiting Host Here
Over the weekend I experienced what some others have, ESC light off, cruise won't work, brake lights won't function and can't shift gears without using the override button.
Both were replaced under warranty, the brake light issue they were familiar with and looked to see if my VIN was covered under recall or TSB. It wasn't but replaced the ECU, according to my paperwork, under warranty along with the CV boot.
On another note, they had a Equus in the showroom. Looks great.
We purchased it used in Las Vegas, NV.
Anyone have an idea why someone would do this? :mad: :mad: :mad: :mad:
I went to the dealer and they wanted $40 (yes- $40) to replace it. i said I wasn't paying that much for it and went to Pep-Boys. Got a 13" blade for $6-99 and they replaced it for free.
However, be warned - the OEM blade arm assembly is a plastic arm, which would not come off, so the Tech. had to pull out the old rubber blade, take out the new one from it's metal arm and push the new one in to the existing prongs on the original blade arm.
Anyone else had the same problem or an easier experience for replacement?
I happened to get down on my hands and knees to inspect the tires last weekend, and noticed the inner 1/5 or so was severely worn (the fronts worse than the backs). Some squeaking occurs when making tight turns, due to this wear I'm sure.
I now have 31,000 miles (on the original Bridgestone Duelers) on the car. Have been rotating tires every year, but now will every 6 months. I plan on getting new tires sometime next spring.
Hopefully better tires will end up with a quieter ride with even tread wear!
Ryan
08 Limited AWD. Touring pkg with RES.
posted about the same problem.
My dealer will not discuss it with me unless I appear at the dealership and he has no choice but to speak with me. He said the Hyundai rep told him to stay out of the situation.
Piston slap may indeed be a characteristic of an engine (Subaru has a similar issue, due to very short piston skirt design and GM has had tons of complaints). But in that case of it being "normal" one would have to say that all engines of that type should do it---otherwise, it is "abnormal" to that particular engine.
Piston slap itself has often haunted engine designers. There is a huge debate still raging about whether it does, or does not, in fact, affect engine longevity.
From what I'm reading, automakers won't do anything about piston slap unless you seriously threaten them with action.
If this condition is intolerable to you, then perhaps Lemon Law procedures are your only course of action.
Visiting Host
The condition wouldn't be called "normal", but "not abnormal". It does not affect performance.
I've also just received a recall notice for the brake switch replacement due to the safety problems it causes if it goes out. My original brake switch actually went out when I frst got the S.Fe back in '07, but I'll get it replaced again with the recall, just because.
I have a 2007 Santa Fe, and have experienced the problem of gas pump nozzles shutting off prematurely when filling the tank. On the last 2 fill-ups though, I have had fuel spray out of the filler neck and the pump doesn't shut off at all.
This has happened on my last 2 fill-ups, at 2 different gas stations, Has anyone else experienced this?
However they say the numbers are not in the book. Has any one else had this problem.
I took to a dealer today, and they told me that the rear brakes are sticking in the caliper and they would have to rebuild the brake system, but it is not a warranty item. I would have to pay around $150 for this repair. The service advisor agreed it should be a warranty issue as he has seen this become a common problem on the Santa Fe. But he said they could not do this under warranty as he said the brakes are not covered under warranty. I was not happy. He gave me the # to contact Hyundai.
Anyone else have this issue and have any luck getting Hyundai to cover it. THis is my second Santa Fe and I have been generally happy with both. But the service advisor was really critical of Hyundai, and all the crap they are putting out there. Especially now with all vehicles prior to 2007 going to bve recalled for frame issues rotting and falling apart.
Labor cost are at $95./hr ny suggestions
