LR3 removeable tow hitch - how to get it off??
dandrews1
Member Posts: 184
Can anyone assist with this? I've tried everything I can think of.. no help so far.
There has to be a trick to this!
/DA
/DA
I am not sure if I can describe exactly how you orient the green release switch with words.
The key needs to be turned to the right position and the green release must be pulled slightly away from the hitch so that the orange ring is exposed.
You should pull out and twist the green handle down. That should make it release if the key is in the right position.
Keep in mind that the hitch is very heavy so be ready to catch it as it falls or just let it fall. DO NOT LET IT FALL ON YOUR HAND. It will break your fingers if it falls on your hand over hard ground or concrete.
The response I got was that they are vibration dampers - keeps the vehicle from shimmying...
I guess that's a good enough answer for me...?
