Volvo V50 Interior & Passenger Comfort Concerns
Does your V50 fit you like a glove? Are you looking for something that will help get that stain out of the carpet? This is the place to discuss anything and everything regarding the layout and upkeep of the interior of your V50.
All other things aside, has oneone tried flattening the rear and passenger seats and tried sleeping in the car. At 6'2" I'm sure i will fit in the car nicely. My only concern is about how flat the seat really gets. And does it have any kind of bump between passenger and rear seat when folded.
Please advise if any other wagon falls in this category if V50 does not.
Do you think the rear seat is roomy enough for two car seats and an older child? I'd love to find a V50 with integrated boosters, but can't seem to find any on a dealer's lot.
Thanks in advance for the input!
The specs listed on a couple different forums list the cargo capacity on the V50 to be well below that of the Mazda3 wagon. How can that be? Edmunds, for example, lists its capacity at 14.7 cubic feet, while the Saab 9-2x is listed at just under 28. Is the storage in the back really that small?
This sort of stuff always has to be taken with a grain of salt, and a little common sense. The people who compile these numbers sometimes don't do a logic check before entering the data. These cars are all within inches of each other in exterior and interior dimensions.
The 14.7 cu ft is for the area behind the seats, but below the cargo cover [about window line].
The 28 cu ft [or 27 and a fraction for the V50] is behind the seats, BUT FILLING THE CARGO AREA ALL THE WAY TO THE ROOF [no rear visibility, but rear seats still in place].
When you fold the seats down in any of these cars, the number gets up into the 40+ range, more of less, again depending on whether the measurement was taken above or below the window line.
The point is, I guess, that the V50, Saabaru 9-2x, or A3 are all similarly sized - each has a few inches here or there in either the back seat or the cargo area that are different, but none of them is going to be significantly bigger than any of the others.
