Cadillac Deville speeds up by itself
I have a 1998 Cadillac Deville that just yesterday would speed up on its own while driving on a rural road. I had to keep the breaks on intermittently to reach my destination. After about 1 hour it way time for the return trip home. NO problem untill the same time had passed it did it again. My breaks were smelling and I had to put it in neutral as I stopped. The engine raced and I cut the engine off and then put it in Park. Have any of you experienced anything like this? It was scarey! What should I do?
It was the floor mat bunched up and catching the accelerator.
I'm not kidding, this is the very first thing I would check if you are having 'unexpected acceleration'.
Other than that, has anyone worked recently under the hood? Could have messed up the linkage under there.
And, looking again at your message, I see it's a 1988 vehicle. This is a 19 year old car. The linkage could be failed/failing because of the age of the car.
The car hasn't been driven regularly for 2 yrs.
I'm going to take the car in within the next few weeks. I hope the engine revving on the Cadillac Deville is not indicative of larger and more costly repairs.
There are ways to diagnoise this and see which one has the problem. Replacing is no big problem, but getting the new part 'set up' is somewhat complex. You just can't tighten or loosen a screw to set it up.
Find an independent garage that has worked on early-90's Cadillac and has seen this problem. They should be able to replace the part and get the new one set up.
