Land Rover OBDII Codes
                    Hi - I have a 97 discovery. The service engine light came on, but rather than pay the dealer $100 to check it I bought a code reader. It shows p0430. This code indicates that the "catalyst system efficiency below threshold (bank II)" I just replaced one sensor not long ago (for $900!!!)- do others need to be replaced, or is a whole new catalytic converter needed? Is there any danger in driving it? thanks, Carl
/DA
___________________________________________________________
Trouble Code Chart
DTC
Fault Description
P0101
Mass Air Flow Sensor Signal Error Fault
P0102
Mass Air Flow Sensor Low out of Range Fault
P0103
Mass Air Flow Sensor High out of Range Fault
P0111
Air Temperature Signal Error Fault
P0112
Air Temperature Low out of Range Fault
P0113
Air Temperature High out of Range Fault
P0116
Engine Coolant Temperature Sensor Falling Temp Fault
P0117
Engine Coolant Temperature Sensor Low out of Range Fault
P0118
Engine Coolant Temperature Sensor High out of Range Fault
P0121
Throttle Position Sensor Output Signal Error Fault
P0122
Throttle Position Sensor Low out of Range Fault
P0123
Throttle Position Sensor High out of Range Fault
P0125
Engine Coolant Temp Sensor Warm Up Fault
P0130
Oxygen Sensor Cycle Fault *codes* A U
P0131
Oxygen Sensor Low Voltage *codes* A U
P0132
Oxygen Sensor High Voltage *codes* A U
P0133
Oxygen Sensor Slow response *codes* A U
P0136
Oxygen Sensor Cycle Fault *codes* A D
P0137
Oxygen Sensor Low Voltage *codes* A D
P0138
Oxygen Sensor High Voltage *codes* A D
P0139
Oxygen Sensor Slow response *codes* A D
P0150
Oxygen Sensor Cycle Fault *codes* B U
P0151
Oxygen Sensor Low Voltage *codes* BU
P0152
Oxygen Sensor High Voltage *codes* BU
P0153
Oxygen Sensor Slow response *codes* B U
P0156
Oxygen Sensor Cycle Fault *codes* B D
P0157
Oxygen Sensor Low Voltage *codes* BD
P0158
Oxygen Sensor High Voltage *codes* BD
P0159
Oxygen Sensor Slow response *codes* B D
P0171
Oxygen Sensor System Too Lean Fault Bank A
P0172
Oxygen Sensor System Too Rich Fault Bank A
P0174
Oxygen Sensor System Too Lean Fault Bank B
P0175
Oxygen Sensor System Too Rich Fault Bank B
P0181
Fuel Temperature Sensor Signal Error Fault
P0182
Fuel Temperature Sensor Low out of Range Fault
P0183
Fuel Temperature Sensor High out of Range Fault
P0201
Injector 1 Circuit Fault
P0202
Injector 2 Circuit Fault
P0203
Injector 3 Circuit Fault
P0204
Injector 4 Circuit Fault
P0205
Injector 5 Circuit Fault
P0206
Injector 6 Circuit Fault
P0207
Injector 7 Circuit Fault
P0208
Injector 8 Circuit Fault
P0300
Misfire on Multiple Cylinder
P0301
Misfire on Cylinder 1
P0302
Misfire on Cylinder 2
P0303
Misfire on Cylinder 3
P0304
Misfire on Cylinder 4
P0305
Misfire on Cylinder 5
P0306
Misfire on Cylinder 6
P0307
Misfire on Cylinder 7
P0308
Misfire on Cylinder 8
P0326
Continuous Knock Fault Bank A
P0327
Background Noise Low Fault Bank A
P0328
Background Noise High Fault Bank A
P0331
Continuous Knock Fault Bank B
P0332
Background Noise Low Fault Bank B
P0333
Background Noise High Fault Bank B
P0335
Crankshaft Position Sensor Signal Error Fault
P0336
Crankshaft Position Sensor Out of Range Fault
P0340
Camshaft Position Sensor Signal Error Fault
P0420
Catalyst Efficiency Low Fault Bank A
P0430
Catalyst Efficiency Low Fault Bank B
P0441
Evap. Purge Valve Incorrect Flow Fault
P0442
Evap System Small Leak Detected Fault
P0443
Evap. Purge Valve Open or Short Circuit Fault
P0451
Fuel Tank Pressure Sensor Signal Error Fault
P0452
Fuel Tank Pressure Sensor Low Out of Range Fault
P0453
Fuel Tank Pressure Sensor High Out of Range Fault
P0461
Fuel Tank Level Measurement Not Valid Fault
P0500
Vehicle Speed Sensor Signal Error Fault
P0506
Idle Speed Control Engine Speed Low Fault
P0507
Idle Speed Control Engine Speed High Fault
P0560
Battery Voltage Below minimum Fault
P0562
Measurement Circuit OK Battery Voltage Low Fault
P0563
Battery Voltage Above Maximum Fault
P0605
ECM Self Test Fault
P1130
Oxygen Sensor Fuel Trim at Limit *codes* A U
P1131
Oxygen Sensor Lean *codes* A U
P1132
Oxygen Sensor Rich *codes* A U
P1137
Oxygen Sensor Lean *codes* A D
P1138
Oxygen Sensor Rich *codes* A D
P1150
Oxygen Sensor Fuel Trim at Limit *codes* B U
P1151
Oxygen Sensor Lean *codes* B U
P1152
Oxygen Sensor Rich *codes* B U
P1157
Oxygen Sensor Lean *codes* B D
P1158
Oxygen Sensor Rich *codes* B D
P1171
Oxygen Sensor System too Lean Fault Banks A & B
P1172
Oxygen Sensor System too Rich Fault Banks A & B
P1176
Maximum Positive FMFR Correction Fault
P1177
Maximum Negative FMFR Correction Fault
P1178
Maximum Positive AMFR Correction Fault
P1179
Maximum Negative AMFR Correction Fault
P1185
Oxygen Sensor Heater Circuit Open Upstream
P1186
Oxygen Sensor Heater Circuit Short Upstream
P1187
P1188
Oxygen Sensor Heater High Resistance Upstream
P1189
Oxygen Sensor Heater Type 1 Low Resistance Upstream
P1190
Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1191
Oxygen Sensor Heater Circuit Open Downstream
P1192
Oxygen Sensor Heater Circuit Short Downstream
P1193
P1194
Oxygen Sensor Heater High Resistance Downstream
P1195
Oxygen Sensor Heater Type 1 Low Resistance Downstream
P1196
Oxygen Sensor Heater Type 2 Low Resistance Downstream
P1199
Fuel Level Sensor Circuit Fault
P1201
Injector 1 Open Circuit or Ground Short Fault
P1202
Injector 2 Open Circuit or Ground Short Fault
P1203
Injector 3 Open Circuit or Ground Short Fault
P1204
Injector 4 Open Circuit or Ground Short Fault
P1205
Injector 5 Open Circuit or Ground Short Fault
P1206
Injector 6 Open Circuit or Ground Short Fault
P1207
Injector 7 Open Circuit or Ground Short Fault
P1208
Injector 8 Open Circuit or Ground Short Fault
P1313
Misfire Catalyst Damage Fault Bank A
P1314
Misfire Catalyst Damage Fault Bank B
P1315
Misfire Persistent Fault
P1316
Misfire Excessive Emissions Fault
P1317
ABS Rough Road Line Low Fault
P1318
ABS Rough Road Line High Fault
P1361
No Ignition Coil Activation Fault Coil 1
P1362
No Ignition Coil Activation Fault Coil 2
P1363
No Ignition Coil Activation Fault Coil 3
P1364
No Ignition Coil Activation Fault Coil 4
P1371
Early Ignition Coil Activation Fault Coil 1
P1372
Early Ignition Coil Activation Fault Coil 2
P1373
Early Ignition Coil Activation Fault Coil 3
P1374
Early Ignition Coil Activation Fault Coil 4
P1440
Evap System Purge Valve Stuck Open Fault
P1441
Evap System Purge Valve Flow 1 Fault
P1442
Evap System Purge Valve Blocked Fault
P1447
Evap System Purge Valve Open or Short Circuit Fault
P1448
Evap System Purge Valve Flow 2 Fault
P1508
Idle Speed Control Open Circuit Fault
P1509
Idle Speed Control Short Circuit Fault
P1514
Neutral Drive Load Fault
P1516
Neutral Drive Gear Change Fault
P1517
Neutral Drive Cranking Fault
P1607
Malfunction Indicator Lamp Short Circuit Fault
P1608
Malfunction Indicator Lamp Open Circuit Fault
P1620
Reprogramming Code Learn Fault
P1621
Serial Data Link Dead Fault
P1622
Repeated Wrong ECM Security Code Fault
P1623
P1621
P1622
P1623
P1701
Transfer Box Line Fault
P1703
Transfer Box Line Open Circuit Fault
P1708
Transfer Box Line Short Circuit Fault
P1775
Gearbox Fault
P1776
Gearbox Ignition Retard Request Timeout Fault
P1777
Gearbox Ignition Retard Request Line Fault
checked air cleaner, mass air flow sensor, fuel pressure is 40 psi. compression check 160 to 170 psi, spark is hot to each plug. No check engine light on but did check for fault codes. Codes were p 1194, p 1191, p 0158,p 0138, p 1138, p 0300, p0307, p 0302, p 0301, p 1316, p 1314, p 1313. Codes indicate miss fire to plugs, and o2 sensors. The engine acts like air intake leak but can't find any.
o2 sensors should not have any effect untill the come up to temp.
Any ideas?
Timing chain job will be about as I see it from Atlanitc British a kit is 109+ shipping and labor I would think would be about 250-300$. Knowing Rodney.
