Lexus RX Homelink Garage Door Activation
This is the second time this has happened to me. I walked into the garage. Pressed the button to open the garage door. Got into 2004 RX 330. Started the vehicle. When I put the vehicle in reverse and started to back out the garage door started coming down. This time it damaged the light housing above the back window. I have not activated the Homelink system or whatever the interal system is called. I finally had to disconnect the door and back the RX out and then reconnect the door.
I haven't activated the homelink on my '07
RX350 yet, mainly due to the fact that the last
time I did that with a past vehicle, it
deactivated my garage door remotes. I'm not sure if there's a way to get both the remotes
and the internal homelink to work at the same time. Are you sure something isn't accidentally pressing on a garage door remote,
since I assume you probably have your remote
somewhere in the car?
programming my homelink along with my garage
door openers. However, I've noticed that my
second garage door opener has stopped working.
I thought it was the battery, so I put a new
one in it. It still doesn't work. I don't
know if I need to reprogram it, which would
probably mean reprogramming the other one that
is working. I'm not sure what the best approach on this one is.
Now...the original problem of the door closing on the vehicle...I'm pretty sure the lanyard of the opener was getting caught in the luggage rack.:) I shortened the lanyard and I've not had a reoccurence.
loaner RX for almost a week now, as they're still working on some issues. It's nice to be able to drive a loaner that's the same as what you drive. At least it didn't take any time out from my work day or anything. They gave me the loaner and I've been driving around ever since. The only thing I'm missing is my satellite radio.
So I was wondering if anyone has had problems with their homelink working properly in their
Lexus.
Thank...
Jon :confuse:
When you say that you just can't push the buttons in the Lexus, you have to press for a couple of seconds, what do you mean by that?
"still frustrated"
Jon
the directions from the dealer and the home link website was just a bunch of bull .did not help at all.you made it very simple.read your notes,drove out of my garage,programmed the #1 button like you said the sales man did.,came back and did exactly what you did and it woked.thanks a lot.its very simple took less than 5 mins.
