Mazda known for certain type of problems?
Is Mazda as a company known for certain type of problems? Electrical, Engine, or other? Or are they pretty reliable for the most part?
http://www.miata.net/garage/tsb/1103foglightinspectionandrepair1.pdf
Never heard of headlight problems. 01+ uses projector beams style lights, but I'm not aware of any issues with them. I'd go the junkyard route. Dealer quote sounds ridiculous.
The Mazda MX-5 Miata is still the standard of reference for people who care about driving. It's the best car with which to learn about driving, and nearly everybody you know has driven one or wants to drive one.
So our current long-term MX-5 surprised me a little. At 17,000 miles, our MX-5's brake pedal doesn't feel quite right. The pedal action is initially very light and lacks any feedback, and then the brake pads really bite. The overall braking action is not abrupt exactly, but it's not smooth, either.
It's not an issue when you're braking hard, but it can be difficult to brake lightly and smoothly in traffic situations. It's probably only something I'd notice, since I'm the kind of guy who doesn't like to stand the car on its nose under braking.
Our test car hasn't led a very hard life, and it's never even been to a race track (so far), so I'm pretty mystified. I have to say that this is the first MX-5 I've driven that has any reasonable amount of mileage on the odometer.
Turns out, this braking issue seems be apparent in the new-generation MX-5. Our sources tell us that it's difficult to know which part of the braking hardware is responsible. But apparently it's something the Mazda engineers plan to address.
So I guess it's not just me after all. A refreshing change .
Posted by Michael Feb 8, 2007 12:50 pm
The Mazda 626 with the 4 cylinder/automatic combination had the dismal Ford CD4E transmission. Those were so bad it's a matter of when, not if, they will fail. Rebuilds also fail. They're just that bad.
Oddly the V6 model did not use that trans and was fine. Both manuals and clutches were also OK. Only the 4 cylinder/automatic was affected.
First year Miatas had that crank issue, but that's long been resolved (replaced or failed by now).
I think 99 Miatas had some clutch chatter issues.
Few and far between for the whole Mazda lineup, basically.
