Sport Trac Engine Problems
Having issues with your ST's powerplant? Discuss them here
kcram - Pickups Host
You don't need to change a timing chain.
Mark
As far as your miss. Check that all the clamps and hoses are connected leading from your air filter box all the way to the throttle body. Your Mass Air Flow sensor [MAF] is inline on the snorkle intake. If there is a slight leak after your MAF, it can cause all kinds of running problems. The MAF gives info to the PCM as to air flow demand to the engine. Good luck.
Rich
Your white smoke was probably steam that the engine was making when the gasket for the cylinder head gave way when it was too hot. My little four cylinder did this once I kept pouring water in it, but it was burning it up so fast, I had to pull over before I maxxed out the temp gauge and damaged the engine more. If you did pull over it might just be a new gasket and no major machine work needed.
Id talk to a local engine rebuilder or NAPA parts store for any recommended machine shop that could check the head for warpage.They can do it in front of you for no charge when you get the cylinder head off.
I have a 2007
