2004 Malibu Cruise Control Issues
in Chevrolet
2004 Malbu cruise control works intermittenly. Dealer has replaced +/- switch with no change. No codes are stored in the computer related to cruise. Anyone else had this problem? Solutions?
When you say it works intermittently does that mean it "drops out" or it just won't engage at times?
It was probably me!!! You name it, my cruise control has done it. It is easily the worst such system I've had in any car I've owned.
Last winter was an absolute nightmare, with the thing quitting unexpectedly while driving on long trips, or failing to engage at all, or refusing to accelerate or decelerate in response to the steering wheel switches.
Things have improved considerably since my dealer finally replaced the BCM. Every once in a while, though, pressing the + or - switch will cause the system to disengage. But this is now extremely rare. Most of the time it works OK although my big complaint, the reluctance to disengage when applying the brakes, continues.
Follow e2helper's advice, and good luck!
