1994 Isuzu Trooper ( Hard to start )
                    I have a 1994 Trooper (SOHC) with just 70,000 miles on it. I've done the general up keep on it like oil, plugs, air/fuel filters etc... Runs great and very few problems until latley. It's very very hard to start. In the last 2 months we've put in a new battery,6 plugs,PVC valve,wiring set,fuel filter,fuel pump,starter and fuel pressure regulater on hunches from a mechanic. It's still hard to start. To me it sounds like it's STARVING for FUEL. I now cycle the key about 10X's before trying to start it and after trying many times it will start and then runs like a champ. I'm into this about $1300 already and still the same problems. I just don't want my wife and grandkid stuck somewhere. What else could/should I try? Somebody told me a Oxgyen Sensor?, also that I may have a bad/leaking fuel injector? At the shop when they hook up the computer to it it says everything is OK, well that's because once it does start it's runs great. The computer does not show a bad code #, because when it starts it says all is well. Any ideas and/or help would be GREAT!  THANKS!!!!
Have you heard any peculiar noise like a vacuum leak or hissing when you shut off the Trupr? How about the vacuum lines, they OK, Not kinked or burned through? It is good that no codes are stored in the ECM, but it does make it hard to diagnose.
If you pull a plug wire and put a good grounded plug in it, do you get a good spark when you first crank it? Sometimes the ignition module or crank sensor can be intermittent, but they generally get so bad that the vehicle will not start at all. If no spark when you crank, then look at the ignition system.When they go bad, there may be no code stored. How about your EGR valve, is it clean and working properly? Did the mechanic change/replace the fuel pickup screen and clean the sump in the fuel tank so fuel will flow freely?
These are just some ideas to maybe get the answers for. Hope they help. I don't think it matters but is your trooper a SOHC or a DOHC? Let us know what you find.
Thanks! GpaBear
Does that sound like a final fix to my problem? How do I know that after putting in more $ that it's the final and real problem?
Thanks for any ideas and/or help!
GpaBear
Circuit Diagram
Circuit Description
The Fuel Pump delivers fuel to the Fuel Rail and injectors, where the system pressure is controlled from 280 to 320 kPa (41 to 46 psi) by the Fuel Pressure Control Valve. Excess fuel is returned to the fuel tank. When the engine is stopped, the pump can be energized by jumping the Fuel Pump Relay connector with a fused jumper.
Test Description
Numbers below refer to circled numbers on the diagnostic chart.
Use pressure gauge J-34730-1. Wrap a shop towel around the fuel pressure tap to absorb any small amount of fuel leakage that may occur when installing the gauge. (The pressure will not leak down after the Fuel Pump is stopped on a correctly functioning system.)
While the engine is idling, Manifold Absolute Pressure is low (high vacuum). When this is applied to the Fuel Regulator Diaphragm the vacuum will result in a lower fuel pressure at about 190 - 200 kPa (25 - 30 psi) .
The application of high vacuum to the Fuel Pressure Control Valve should result in a fuel pressure drop.
Fuel pressure leak-down may be caused by one of the following:
Fuel Pump Check Valve not holding.
Pump Coupling Hose leaking.
Fuel Pressure Control Valve leaking.
Injector sticking open/leaking.
Diagnostic Aids
Improper fuel system pressure may contribute to one or all of the following symptoms:
Cranks but will not run.
Diagnostic Trouble Code 44 or 45.
Cutting out (May feel like ignition problem).
Hesitation, loss of power or poor fuel economy.
Circuit Description
Test Description
Pressure less than 280 kPa (41 psi) may be caused by one of two problems.
The regulated fuel pressure is too low. The system will be running lean and may set Diagnostic Trouble Code 44. Also, hard cold starting and overall poor performance is possible.
Restricted flow is causing a pressure drop. Normally, a vehicle with a fuel pressure loss at idle will not be driveable. However, if the pressure drop occurs only while driving, the engine will surge and then stop as pressure begins to drop rapidly.
Restricting the fuel return line allows the fuel pump to build above regulated pressure. When battery positive voltage is applied to the Fuel Pump Relay, pressure should be above 450 kPa (65 psi) .
This test determines if the high fuel pressure is due to a restricted Fuel Return Line or a Fuel Pressure Control Valve problem.
(12 code refers to the reference signal that indicates motor is running....since memory is checked with engine off....12 code)
If a 12 is the engine running with only the key on?
Following the output of diagnostic trouble code 12, the "Check Engine" malfunction indicator lamp will indicate a diagnostic trouble code three times if a diagnostic trouble code is present, or it will simply continue to output diagnostic trouble code 12. If more than one diagnostic trouble code has been stored in the engine control module's memory, the diagnostic trouble code(s) will be output from the lowest to the highest, with each diagnostic trouble code being displayed three times.
refers to the heated oxygen sensors in the exhaust system
Circuit Description:
The engine control module supplies a voltage of about 0.43 volt between terminals "B3" and "B2". (If measured with a 10 megohm digital voltmeter, this may read as low as 0.32 volts.) The Heated Oxygen Sensor (HO2S) varies the voltage within a range of about 1 volt, if the exhaust is rich, down through about 0.10 volt, if exhaust is lean. The sensor is like an open circuit and produces no voltage, when it is below about 360°C (600°F). An open sensor circuit, or cold sensor, cause "Open Loop" operation.
Test Description:
Diagnostic Trouble Code (DTC) 44 is set, when the O2S signal voltage is fixed below 0.100 mV and the following:
Throttle position sensor greater than 9.8%.
No DTC 21 or 33.
The engine has been running at least for 180 seconds.
System is operating in "Closed Loop".
Oxygen signal voltage is steady between 0.347 volt and 0.547 volt.
Engine Operation Temperature 69.5°C (155°F).
All of the above conditions present for 25 sec.
Integrator not at 128.
Diagnostic Aids:
Using the "Scan tool", observe the block learn value at different revolution per minute. The "Scan tool" also displays the block cells, so the block learn values can be checked in each of the cells, to determine when the DTC 44 may have been set. If the conditions for DTC 44 exist, the block learn values will be around 150.
Check for ground in wire between connector sensor.
Fuel Contamination - Water, even in small amounts, near the in-tank fuel pump inlet can be delivered to the injector. The water causes a lean HO2S signal and can set a DTC 44.
Fuel Pressure - System will be lean if pressure is too low. If may be necessary to monitor fuel pressure, while driving the car at various road speeds and/or loads to confirm. See Fuel System diagnosis CHART A-5.
Exhaust Leaks - If there is an exhaust leak, the engine can cause outside air to be pulled into the exhaust and past the sensor. Vacuum or crankcase leaks can cause a lean condition.
If DTC 44 is intermittent, refer to Diagnosis By Symptom.
Fuel Injectors - The wrong fuel injector(s) could be the cause of a lean HO2S signal condition. Verify that the correct fuel injector(s) are installed in the vehicle. Refer to the service parts manual for correct part and part number.
I think it is too early to assume the starting and smell are related, but it would help to know which engine you have SOHC or DOHC, and whether you have changed the fuel filter and air filter since you bought it. Information like this will help others pinpoint areas of concern. When you say you really had to gas it, do you mean that it started but would stall, or that you held the accelerator to the floor and or pumped it?
Welcome to the forum, there are good people here who will offer their input once a good description is provided. Good luck.
Lately, on occassion, it has been chugging, stalling, blowing a lot of smoke and even backfiring. Then it runs perfecly except it seems to be running rich. These symptoms srarted a couple weeks after a complete exhaust system was installed from the manifolds in the fall.
Now it is colder and my trooper has flooded itself out twice now. I pulled the plugs to let it dry out and replaced the O2 sensor.
I've read your blog before (jfrozenh2o) and am leaning towards your idea of leaking fuel injectors, or some other fuel delivery issue. I've also read of others with hard starting issues and many trouble shooting possibilities, but no solutions or successful attempts to remedy these problems.
I love my trooper and just want it to run like it did a few months ago...and would like the gas mileage to go back to normal.
If the new O2 sensor helps, I'll post it. If you changed the injectors on yours, did the problem go away? My local dealer suggested a wiring harness at the front under the rad that typically turns green and cases problems. thanks, Kenny.
