Nissan Quest Door & Window Problems
Hi, I puchased a new 2006 quest March 24, 2006. It had 100 miles on it. Since then I've had it in the shop 8 times trying to repair the passenger door. Going over bumps in the road the door sounds like it is not shut. The dealer has replace the lach, adjusted the dove clips, and I am once again going there today for them to look at it again. I love my quest! Has anyone had this same problem? Help Me!
Also, we can not unlock the drivers door with the key, because the alarm will go off. We can unlock the passenger door with the hey with no problem.
A mechanic I talked with thinks it might be the chip in the key or a loose connection in the driver's door.
When you get in the van and lock the doors, try the key insertion into the ignition a bit slower, but still more than six times in ten seconds. Remove the key completely each time.
The alarm going off when you use the driver's door lock sounds like a ground issue or a bad door key cylinder switch, per the troubleshooting chart in my service manual. Try resetting the alarm system - put the key into the driver's door. Turn it twice to the left, then twice to the right.
SUVs & Speed Shop
Initially, it wouldn't close when used; It would close nearly all the way, click a few times like it was trying to latch and the beep & re-open.
Now, its doing the same when it opens. It reaches a certain point and then beeps and tries to close.
Fortunately it works when disabling the power option and closing manually.
I've checked the tunnel for obstructions as well as lubed the trench.
Its under warranty, but I'd rather fix it myself it is something simple.
I got a 2004 Quest S model. The car runs great and never has any problem since November 2003. For me, Quest is powerful and easy to handle. The powertrain is wonderful, except I wish it got 5-speed on transmission instead of 4.
I had some rattle door problems even after the they applied the re-call. But someone mentioned WD-40 on this forum and I used couple of bottles to spray almost every where near the door, and under seat, etc. And it did a great job. I bought those bottles at Autozone, and it costs less than 2 bucks.
http://www.wd40.com/Brands/wd40_faqs.html
Tom
You could try an auto salvage yard if you can find on in your area - unless they have a whole door to sell, they may have pulled the switch out and have it sitting around for sale. I don't know of an internet parts source off-hand; sometimes they show up on eBay.
Steve, visiting host
In general, you want to spray every couple years, and it has been 12 years for your 99 villager, not sure if previous owner did this maintenance work.
Can't remember ever cleaning my locks on my '99 though. I use the FOBs pretty much exclusively except for when I accidentally trigger the alarm - guess I'm lucky the locks still work with the key.
I use electrical contact cleaner around switches.
Is it possible to buy just the bearing and replace that part of the assembly?
