07 Tahoe Interior Noise
coupfivecoupfive Member Posts: 2
edited March 2014 in Chevrolet
My 07 Tahoe seems to have a lot of wind noise coming in from the driver's window. If I pull the door in to me it helps a little. Is it possible the rubber around the door is not installed properly or the door is off. Also a lot of noise from all the doors, rattling noise as if the rubber stops are rubbing on the doors. Most noticable when the body is twisting either when entering a driveway or bumpy roads. Anyone else experience this?
  • rat55chevyrat55chevy Member Posts: 19
    I have interior noise but mine is coming from the rear window area. Is louder when I pull my trailer or boat.
  • ammoaicammoaic Member Posts: 1
    I have an 07 Suburban, which is basicall the same, and I have the same issue. I think you may have more of a problem if you can pull your door in. I took it to the dealer a second time, drove another 07 burban, and it did the same thing. It starts at around 50 mph. When I take it in for it's first oil change, I am going to have them run a chalk test on the rubber seal, to make sure it is fully sealed. The dealer told me it was the large sideview mirrors, but that's a little excessive. It's a huge vehicle, and I am thinking I gotta get used to it. I also noticed the rattlingin the door, especially at lower speeds. Lots of rattles around the air vents... cheap plastic. Gotta take it one step at a time with these dealerships, but it will be under warranty for a long time. Oh, they can also do an interior air integrity test... I just didn't get to that point yet. All in all though, It's a great truck. I just don't know if it was worth the money with these air integrity and rattling issues. It was still much more comfortable and larger than the toyota, nissan, chrysler aspen and Honda Pilot.
  • coupfivecoupfive Member Posts: 2
    I will have to ask the dealer about those tests. I am kinda at the point of getting used to it. They also said using a silicone grease on the rubber on the back lift gate. That should help the sqeeking. Let me know if you find anything else out.
