Grand Cherokee Multiple Injector Codes
OK hopefully somebody can help .. I just bought a used "AS IS" 2000 Grand Cherokee Laredo ... when we went to look at it I took it for a test drive a few blocks and everything was great .. bought it and on the way home 25 minutes later while running in overdrive at around 2000rpm 55 mph it started bucking a little, hit the gas a lil more and it took off no problem, running at the same speed started bucking again and check engine light came on. I got it home and put it on my computer i was getting p0204,p0203 injector circuit open malfunction cyl 4&3. Car sat overnight and got in it the next day started and and the idle ran really high like 3000rpm for a few seconds and dropped off, also no check engine light drove it again again around 25 minutes later while running at a steady speed in overdrive it started bucking again this time p0203,2,1,4,7&8. Til this day you can go out start it and idle is fine initially after a minute or so starts to idle high low high low, drive it and shut it off and restart idle shoots to 3000rpm and still bucking while driving(getting worse) and throwing codes for injector circuit open on numerous cylinders. I find it hard to believe that like all the injectors are bad and I dont want to start throwing money to all kinds of different things if im not sure its the problem ... hopefully somebody out there has a idea. Thanks
Anyone have any suggestions, short of the dealer,
on what may be causing the problem?
Got another question...I get a Throtle Position Sensor code,
(got 156K mi. on jeep), Pep Boys has one for $29 and dealer wants $85...any difference?
Kmitch
This mechanic's diagnostics found the fan drawing too much current, which was the probable cause of the connector meltdown. If the fan had been replaced the first time, (it wasn't), I would have saved $1400! Just a heads up.
kmitch
