Land Rover LR3 Air Suspension Problem?
I have a 2006 LR3 V6 SE. I have noticed that the front passenger side of the truck seems to sit just a wee bit lower than the driver's side (maybe by an inch or so).
I don't know if this situation might be caused by a leak in the air suspension, or perhaps there might be a simple suspension adjustment the dealer can make.
I was wondering if anyone else has run into this issue and might know the fix???
Keith
Keith
I was searching suspension information and ran across your posting. I have a 2005 LR3 and am experiencing the exact same problem. Did you ever find out what it was..?
Thank you,
Nicole
i also have a 2005 LR3 and i have been noticing that once the Truck is parked, i hear a Deflation Noise from the suspension( As if Air is been let out) and the Rear of the Truck goes down. The dealer has replaced somethings in the Air Suspension but this Action is still Ongoing. I was wandering if anyone was experiencing the Same Problem Or should i just Overlook it????
Tej
Tej
