IMO, Acura needs to put a lid on the can containing SH-AWD when it comes to a high end sports car and high end flagship sports sedan. At least temporarily. Give us normal enthusiasts something to consider over a Cayman S or basic 911S in the $80k price range. If they want to take on the Ferrari 430, Gallardo and 911 Turbo down the road with an AWD 500+hp version for $150k, fine. But the former market could produce sales in the 10's of thousands, the latter market will be in the low thousands or less.
On the sports sedan side, only the mid range, not-so-sporty models of the cars I would consider even have AWD as an option. Mostly due to the aformentioned weight problem. You can get a 530ix 6-speed, but not a 550i 6-speed in "x" form. No M or AMG models in "x" or 4-matic form. That isn't a coincidence.
1. Drive train (SH-AWD)
2. Engine
3. Platform (by this, I mean assembly line, not chassis)
4. Styling
As you wrote, with either front mid-engine (FME) or rear mid-engine (RME) you can use the SH-AWD. So that's common to both.
With a V10, neither layout can realistically expect to share the engine with other products. I can't think of any transversely-mounted V10s in production.
When it comes to platform, the FME car has a more realistic chance of being shared than the RME. Advantage goes to the FME.
When it comes to styling, the shape of an FME car is more akin to that of a FWD car. The styling of an RME car would not translate as well to other products. (Sure, you could share surface details, but the FME does it better.)
FME = 3
RME = 1
Even if they move to a V8, as you suggest, the FME can share it just as readily as the RME. The score changes, but the end result is the same.
FME = 4
RME = 2
I sorta agree with the notion that they develop the V8 first. If done correctly, that could provide them with a boost for the RL and MDX much quicker.
On the other hand, Honda building a V8 isn't as head-turning as building a V0. Headlines would read something like, "About time!" The idea behind building a halo car is to attract attention. The headlines for a V10 would likely be more significant and more positive.
The V10 vs V8 issue is one where I'm on the fence.
Furthermore, not all AWD systems are created equal. The ATESSA system is well-proven on the track. X-drive and 4-matic do not have the lateral torque vectoring capacity that makes SH-AWD unique.
The NSX is an exotic - build it from exotic materials and save hundreds of pounds, without having to "type-R" it. Can you imagine an all-aluminum and carbon fiber NSX? That would give them the weight reduction necessary to give it SH-AWD without a big penalty. But if they want to keep it RWD, I like that even better. :-)
It sure would be a good idea if they planned the powertrain to be share-able with the RL. Next comes platform - they should plan the platform to be stretched in future for the RL. Evolving the current model will never turn it into anything but the budget alternative to "proper" luxury sedans like Lexus LS and 5/7-series.
Let us assume that Acura could produce an NSX propelled by 450 HP/4.5-liter V8 and tipped the weighing scale at 3400 lb. No AWD system is necessary here. Technically, I won’t mind seeing an NSX-R weighing in at 3150-3200 lb with 450-500 HP either, but if it must also showcase SH-AWD as well, then the weight saving exercise is simply meant to compensate for added heft of the AWD system which would be fine, as long as the car delivers what it must to justify the technology and cost.
You end up with a not-so-super super car.
No, I think the best we can expect is one of two options.
1. The super car can be built on the same assembly line as other cars. (Thus keeping production costs in check and allowing more money to go into the engineering & materials.)
2. A second, less expensive sports car is based on the same platform. Building a large sedan from the basis of a super car probably isn't going to work. However, building a modest-sized 2+2 coupe might be possible.
I mean, the system used in the MDX is only about 205 lbs. Use a magnesium case, carbon fibre prop shaft, and other tricks... they can probably get it well below that. And it's not like a standard rear differential with an LSD is weightless to begin with.
RSX: Sport Coupe
2.3T/I-4, AWD, 260 HP, 6AT/6MT, $30K-$32K (Option: Navigation)
TSX: Compact Touring Sedan
Base: 2.4/I-4, FF, 210 HP, 6AT/6MT, $28K-$30K (Option: Navigation)
Type-S: 2.3T/I-4, AWD, 260 HP, 6AT/6MT, $33K-$35K (Option: Navigation)
TL: Mid size Touring Luxury Sedan
Base: 3.5/V6, FR, 300 HP, 6AT/6MT, $35K-$40K (Option: Navigation/Sport Package)
Type-S: 3.5/V6, AWD, 350 HP, 6AT/6MT, $40K-$45K (Option: Navigation)
CL: Luxury Coupe/Convertible
3.5/V6, FR, 300 HP, 6AT/6MT, $35K-$45K (Option: Navigation/Sport Package)
RL: Full size Luxury Sedan
Base: 3.5/V6, FR, 300 HP, 6AT/6MT, $45K-$50K (Option: Navigation/Sport Package)
Premium: 4.5/V8, 350 HP, 6AT, $50K-$60K (Option: Couple of packages)
SSX: Premium sports car (a name I remember from the time S2000 was on its way)
3.5/V6, MR, 350-375 HP, Auto-Manual, $65K
NSX: The super car
Base: 4.5/V8, MR, 450 HP, Auto-Manual, $80K
Type-R: 4.5/V8, AWD, 500 HP, Auto-Manual or 6MT, $90K
There’s something for everybody PLUS the room to grow. There’s plenty of platform and engine and transmission and SH-AWD sharing too. A compact, a midsize and a full size sedan, a mid priced convertible/coupe for those who want some style with 2+2 seating and a performance oriented 2+2 entry level coupe. SSX would be to NSX that Boxster/Cayman are to Carrera, besides adding volume and allowing some parts sharing.
There’s another constant across the entire lineup (regardless of the orientation of the platform, MR in case of NSX, FR in case of TL/CL and FF in case of TSX).
Type-R: More power, track tuned chassis, SH-AWD, features stripped to save weight,
Type-S: More power, sport tuned chassis, SH-AWD, features retained
Except with the entry level cars, there would be none of that dreaded comparison with Honda. And I need to get a copyright on this virtual lineup of mine, just in case Acura decides to go for it. (although, I would gladly give it to them for free :P )
I agree. But do we really want a “sports car” to share a platform with a full size luxury sedan? BMW 650i is a good example about how cars can quickly gain heft. That thing tips the scale at 3814 lb. That is with a 360 HP V8 and without an AWD system. Starting at $74K, it isn’t inexpensive either.
I don’t think that is necessarily a good thing. Besides, styling elements are more important than overall shape of the vehicle. Audi R8 helps make a strong case here. Despite of being RME unlike any other car in the Audi lineup, it uses strong family tones.
On the other hand, Honda building a V8 isn't as head-turning as building a V10.
IMO, headline should be made via performance and in style. V10 isn’t a new story either, BMW has it, Dodge has had it, Lexus will too. V8 won’t be new, at least it offered a new ground to rest of the Acura lineup. As far as performance aspect goes, Honda is capable of getting 500 HP out of a V8.
Honda didn't feel compelled to build the S2000 with existing Honda FWD technology or spare parts. RWD, in-wheel suspension, X-frame etc. Far more new technology than I am competent to describe. But what I can say with authority as a previous owner, is that at $32k in 2002, it was a better performing sports car than the BMW Z3/Z4, base Boxster and SLK. The 350Z was/is a bad joke compared to it, especially among those (like me) that might someday be able to move up to an NSX equivalent.
If Acura attacks the drawing board with the same passion on the new NSX as Honda did on the S2000, they will likely have a winner. But if they start putting ANYTHING in the NSX because it comes from or is intended to be shared with other Acuras (engine, suspension, transmission, etc), I think they should just give up while they are ahead. I also know first hand that SH-AWD isn't "super handling" in an RL. Certainly not compared to a 5-series with sport suspension. Could the technology be refined, lightened up, etc. to make it better? I'm sure it could. But the Acura engineers should only do that if they think it will serve to make the end product significantly better in relation to a 911 or a Ferrari 430. Not because they have some other corporate mission to promote or baggage to carry.
My ideal NSX should be a cheap man's supercar like the original was. It should have a V8 with 400 HP, 350+ lb/ft of torque, all aluminum chassis, carbon fiber hood, truck, roof and even the fenders. The most important, it should come with manual tranny and RWD.
If Acura really want to get into the luxury GT coupe market that's fine with me but that car shouldn't carry the NSX badge.
"Honda didn't feel compelled to build the S2000 with existing Honda FWD technology or spare parts."
No, the S2000 did not share a layout. It was, however, the ultimate expression of VTEC and their style of high-revving performance.
"If Acura attacks the drawing board with the same passion on the new NSX as Honda did on the S2000, they will likely have a winner."
That sums up a perfect approach to building a great super car. However, Acura is not building a great super car. They are building a great halo car.
A halo car must be both a great performer and shine a bright light on technologies used by the other cars in the line-up. It can't shine that light if it doesn't use those technologies. And based on what we've been seeing from Acura over the past several years, it looks like SH-AWD is the technology they want to showcase.
Or do we call Ford GT a super car, while Cobra R is Ford's "halo car"?
Back to S2000, a screaming VTEC was only a part of the whole picture. S2000 was a new approach to showcasing performance unlike any other Honda around. And going for a unique platform was an integral part of it. Honda could have just as well showcased VTEC in a front driver, but didn't. Clearly, there was more to showcase than just VTEC.
In common usage, the term "supercar" refers any high performance, street legal production car that can compete in the top tier of its day and age. As a result, these car are typically hugely expensive and very rare.
A "halo car" is a car which exemplifies the ideals of a line of cars. Many halo cars are also supercars. This is because most car companies wish to highlight performance as the ideal to which they aspire. However, that is not always the case. For example, the Wrangler Rubicon could easily be considered the halo car for the Jeep brand. The Prius works as a halo car for Toyota's hybrid program.
Now, there are plenty of companies who go out and build supercars, without expecting them to serve especially well as a halo car. The Ford GT you mentioned is a good example. The car highlighted the brand's racing heritage, but it shared nothing unique with other Ford performance vehicles. It was expensive, didn't help them sell other models, and got discontinued. (Which was something they either planned or suspected would happen right from the start.)
Something like the Audi R8 looks to be a good halo car. It appears to offer good performance, has styling that says "Audi", and it shares technologies which Audi would like people to appreciate: Quattro and FSI for starters.
That's sorta ironic given how you so frequently mention that the S2000 is kin to the S500 and S600.
VTEC was not the only interesting part of the S2000's design. It was, however, the thing it shared with other Hondas. A halo car can do plenty of other things, too. But sharing something (anything, so long as it's salient) is a requirement for a good one.
Though, honestly, I'm not sure they ever intended the S2000 to serve halo car duty. It was built as a birthday present to the company.
If they added variations on that same engine to other vehicles like the Explorer or Fivehundred, it could become the foundation for a line of halo models. I'm not aware of any plans to do that, what with the GT supercar being on its way out, but they could.
Also, honda could bring back or remake the 5cyl engine. My guess is the 2.5l 5cyl. That makes a 5.0l W10. Someone say acura NSX? If honda can pull 250hp out of the 5 with a turbo, do the math. 250hp+250hp= 500!! If the weight is kept low enough, it would be PERFECT!
This entire Idea came from me reading about the 2005 vw phaeton w12. Smart of vw to make a 12cyl out of 2v6s! Also the 16l in the Bugatti Veyron. I'm guessing that its either 4 turbo(d) 4cyl, or 2 twin turbo(d) v8s. It seems like a good idea that would be cheaper than building a whole new engine!
That new 3.7l v6 for example, if combined with another one when both make 300hp in the MDX equals 600hp! I think W is now my favorite letter now!! Hopefully honda Trys the 4.8l W8 1st.
-Cj
Without a doubt, Honda is capable of engineering a 4.5/V8 that can deliver 350 HP in mainstream applications to 500 HP in a top of the line super car. Instead, we have heard enough about a 500 HP V10, and virtually nothing about a V8. I hope, if Acura does get a V8, it displaces at least 4.5-liters.
I am not so much thrilled with ASC also because it doesn’t promise a direction Acura SHOULD take, and that is a move to FR platform for most of its lineup. And if true, that will not be a good thing.
We’re talking FWD family movers or sport coupes. S2000 was an aberration in the lineup, pretty much like NSX was to Acura lineup when it arrived (and at the time, only Legend and Integra existed).
S2000 was chosen to celebrate Honda’s 50th anniversary as a company, and rightfully so. Perhaps because it’s soul defines Honda. And what is that soul? Why couldn’t it be represented with Honda’s best selling car, the Accord?
Halo car might be a fine word, but it must represent a company’s soul. S2000 did.
The marketing idea...
This automobile would become both a rolling showcase for the firm's technical prowess, and also establish the "performance/luxury" image the Acura Division needed to achieve if it were going to be recognized as a leader in that market segment.
I would say, just like the NSX, ASC is capable of achieving the point above.
The Honda Spirit...
Historically, Honda has always been a "racing" company. From its initial interest in motorcycle racing in the '60s , to its current dominance in FormulaOne, Honda has always taken racing as a serious endeavor. And its involvement with motorsports was never an afterthought or promoted on an occasional basis as an adjunct to the latest marketing strategy. It was an integral part of Soichiro Honda's philosophy, a philosophy that was nurtured and encouraged and placed at the core of Honda's approach to building cars.
Things seemed to have changed. LMP2 is bearing an Acura nameplate more as an advertisement with about as much commonality as Taurus and Monte Carlo did on NASCAR circuits to their showroom counterparts.
Engineers at work...
In their survey of the extant exotic and sports cars, the project leaders saw a clearly delineated map. One section contained the limited-production exotics such as Ferrari, Lamborghini, Lotus, and the more rarified versions of the venerable Porsche 911. Aside from the mid- or rear-engine configuration, this class of car is characterized by a heavy emphasis on engine power and the first priority is given to packaging the mechanical components
On the other end of the sports car spectrum are the lightweight, mass-produced sporty cars like Miata and MR2. While these vehicles provide a high degree of reliability and fun at an affordable price, they don't possess the very high levels of performance the project leaders envisioned for the NSX. Their most desirable traits are light overall weight and good ergonomic packaging
Occupying the middle ground are the middle weight mass-production cars like Corvette and 300ZX. These are certainly livable sports cars with sufficient performance to satisfy an enthusiast. Their priorities include comfort and convenience. And while they can excel in certain areas, their overall performance is compromised due to their high overall weight and abundance of luxury features. The Acura NSX was envisioned as stretching the current sports car envelope. It would occupy a segment that was philosophically much closer to the lightweight, highly responsive characteristics, of a Formula One car than either the traditional heavyweight sports cars or the middleweight sports/touring machines. It was to be a synthesis combining the light weight of a "sporty" car, the power output, looks, performance, limited production, and packaging of an exotic, and the ergonomics and livability of a middleweight sports car.
Now I can't wait to dissect Acura's excuses to shift its focus with the ASC, an attempt to use styling first (not that it is much to write home about either), high power next, and a complete disregard for heft.
A person on another board (you know where), took a picture of the ASC and made it look like a mid-engined exotic. IMO, ME cars have far more room for creating curb appeal and wow factor than do front engine cars.
That is how the S2000 is able to serve as a halo car for the FWD line-up at a Honda dealership.
Sure there is more power, and a V8 that could be used in lesser vehicles, but is it "better" in strictest terms that Honda takes pride in?
It isn’t required that a super car or halo car (as one may choose to put it) share everything with lesser cars. S2000 doesn’t, and NSX didn’t. They both demonstrated Honda’s spirit (S2000 goes back in history to represent Honda’s first cars and NSX was a representative of Honda’s heritage in racing in Formula One circuit).
That said, virtually every car from a brand will share at least something with the rest of the lineup. And that makes narrow focus on one or two technical feature even more trivial. Do you really think VTEC needed S2000 to be a part of Honda lineup?
S2000 wasn’t designed around the engine. 1995 SSM concept was powered by 220 HP 2.5-liter/I-5 DOHC VTEC. 2.5/I-5 was ditched in favor of 2.0/I-4. Apparently the original idea was to target 220 HP (IIRC, this was mentioned in the very first article in R&T sometime in 1999). With minor gain in weight, the output was bumped up to 240 HP from the same engine. If these claims are true, Honda certainly didn’t start with engine. They started with the concept and the car as a package.
NSX wasn’t designed around “VTEC”, or as a styling exercise. It was designed around a concept that represented Honda’s philosophy. On the other hand, so far, ASC has been all about styling and V10. That’s quite a departure.
And just like S2000, for NSX, engineers had power/weight target, not necessarily a specific engine in mind (V6 was a done deal). They had started with 250 HP, but as the design showed potential of being heavier than original target, the output was bumped up to 270-280 HP, and VTEC was used to achieve that.
Essentially, what you're asking is whether or not I think a real high-tech V6 that has been produced is better than a fictional low-tech V8.
What does that have to do with anything? I mean, just for the record, what's better... a V6 producing 280 hp or a V10 producing one billion horsepower with pzev emissions and a cappuccino maker built in?
What does an answer to a question like that prove? It has nothing to do with the ASC.
Because they wanted to build a good sports car.
You don't build an SUV with a sedan body style. You don't build a sedan with only 2 seats. You don't build an American minivan with a pick-up bed on the back. The type of car sets certain aspects of the design in stone.
Going with a classic-style roadster meant a lightweight, RWD layout. It must be a roadster first, then unique Honda technologies and characteristics are added to make it a Honda roadster.
When you get into building supercars, there are many ways to build them. FMR, RMR, AWD, and there's even Covini's 6 wheel supercar. There are I4-powered Lotus cars and V10-powered Dodges. In fact, it would seem the more exotic the design, the more curious people get. When you get into that price range, the options open up.
The only thing about my ideas is the cost of it. My idea was to put it(them) in an AWD vehicle for better distribution of power. Think of an SUV with the prowess of an FX45, interior volume of a ford explorer, and agility of an x5... Acuras MDX with a 340hp V8 and SH-AWD.
As a side note, acura could go bmws route by putting two of the 2.3l turbos in the tsx for a shot at the 335i or tl for the upcoming 535i. But should require SH-AWD or a LSD.
Is the W configuration expensive?
-Cj
To me, 4.5-liter displacement looks like a sweet spot. With VCM, the engine could be made to cruise in four cylinder mode (an equivalent of 2.2-liter I-4). And that should work!
As far as TSX is concerned, my hope to see Acura’s move to put TL and RL on a different platform also brings a potential benefit to TSX. Being the smallest car in the lineup today, it is likely carrying more weight than it needs to (if you notice, BMW 3-series is about as heavy as 5-series). With the bigger and more powerful cars out of the way, Acura should be able to optimize the platform for TSX (and Accord) which might allow maintaining curb weight (if not reduce) with the next generation.
So, the current base engine with minor tweaks for power and torque, and use of 6AT would be just fine for base trim. For more, as I have suggested earlier, 2.3-turbo with SH-AWD will be nice for the Type-S (IMO, “Type-S” moniker should be reserved for performance variant of every sedan/coupe in Acura lineup with more power from the engine, sport tuned chassis and SH-AWD).
My issues with ASC are primarily due to:
- A disregard for weight
- A disregard for power train efficiency
- Whether building on an existing foundation or trying to start from scratch, there is nothing that ties this new super car concept to Acura’s racing efforts (another example of corporate inconsistency)
- Styling first (what else did we learn about ASC?), engineering to follow
Virtually all of this is a complete departure from Honda’s philosophies, and in many ways, exact opposite of the ideas that can be tied to development of previous benchmarks (NSX and S2000).
The rumor about next S2000 is another area where you may have seen me whine. ASC is no different.
Of course they did. That’s why they designed something completely different from the rest of the lineup. The point was to build a benchmark, not help sell Accords and Civics. S2000 had the virtually every ingredient expected in a “sports car”. Does the Acura “Sports Car” concept have it? It sounds more like a muscle car than a sports car, actually.
There is nothing exotic about front engine vehicles. While mid-engine formula is old, it still maintains rarity AND allows a far greater curb appeal (a must have in super cars). Yes, Dodge Viper has a V10 and is front engine. But when it comes to pure art of performance, mid-engine is where things are at. There must be a reason Acura LMP2 currently lapping in Sebring has a mid-engine chassis.
And at that price point, things need to be different in ways that they represent something unique about the brand yet be able to share some internal features. ASC doesn’t need to a high performance (future) RL coupe.
"Virtually all of this is a complete departure from Honda’s philosophies..."
This is Acura. The brand is supposed to have a different image and different values than Honda. I know that you understand this. Otherwise, you wouldn't be writing stuff like the quote below in other forums.
"A purist's form of sports car is unlikely to wear an Acura badge. It makes more sense as a Honda."
Yet, you keep arguing here for a purist car to be the halo for the Acura brand.
ASC for Acura and NSX for Honda. Of course that's given that Honda has the enough resource and cash to sustain 2 "near super car" in its lineup.
I am drooling just to image seeing S2000 and NSX shown side by side in my local Honda show room with the ASC parked next door (or down the street).
Just to make things clear, I am not blaming the stylists. I might be using assumptions, but my points are around what I have seen, read and heard. Things like “NSX successor”, “rear wheel based SH-AWD”, V10, front engine. Do you know something different?
Explain to me, what do you think has prompted Acura to enter Le Mans with its LMP2? It appears to me, the Honda spirit is alive and well in Acura. Image isn’t quite the same as core value of a corporation. If it is Honda takes pride in engineering and practicality, do you think Acura shouldn’t?
Acura doesn’t need to try too hard to differentiate itself from Honda. It just needs the right ingredients. And that won’t happen automatically, and certainly not if Acura continues to rely on Honda’s formula of FF platforms (supplemented by SH-AWD). I don’t see Acura coming up with its own technology similar to Honda’s VTEC either. There are some things that can’t be changed. Then there are things that should be. That’s where the fix for image appears.
Now, to address the issue of purist car, that reference was for S2000, a Honda. How exactly does this apply to the conceptual differences between NSX and ASC? Are you suggesting that ASC is more of a luxury coupe as opposed to laying emphasis on performance? Perhaps the RL-coupe I suggested earlier. Believe me, nobody thinks of Ferraris and Lamborghinis and Porsches as purists cars. Those are the targets Acura’s super car should focus on, and perhaps become one, instead of 250 lb of sound proofing and just enough room in the back for a child seat.
Regarding the w engine, Honda does almost everything right the 1st time (Think insight or even the 1st Legends & integras. Sh-awd too )Whos to say they cant get the W engine right the 1st time or at least within the 1st 2years? Vw has been having problems with everything for some time now. Honda on with the transmissions but that been fixed on the newer models. I think honda should give that a try. Its better to try and have a possibility to succeed than to never try at all.
Yes honda does need platforms. The accord, civic, and s2000 platforms are great but should be more s2000 and less accord IMO. I guess diesel engines are the top priority now for honda. Imagine a 40mpg TL, 45mpg tsx, or even a 35mpg RL! The best fuel efficiency in the class, best value for the money, and stellar reliability are the things to be known for now.
-CJ
Fact of the matter is folks like Robert here probably would be cheering the ASC if was wasn't billed as an NSX successor. The current negativity surrounding the ASC might be applause f two cars were produced. They'd be proud of the company for taking on yet another group of stuffy car companies who need to be put in their place. Just like Acura did with the original NSX.
As it stands, many fans want more of the same and have trouble with growth/change. It was the same story when Honda started producing minivans and SUVs. For all we know, the folks at Honda HQ may be saying, "Ferrari, Porsche...? Been there, done that. Why conquer the same territory twice?"
- Adds weight which hurts performance
- Adds to the drivetrain losses which hurts performance and worsens fuel economy
- Adds to the cost
It does help achieve a work around the shortcomings of a FWD chassis going around a corner and helps improve bad weather traction.
Are the pros worth my dime? Do the cons make it look like an afterthought? Is there a way to maximize the pros and reduce the cons? Yes there is, and thats something I want to see.
As I have indicated earlier, I am not averse to SH-AWD being applied in every car in the lineup. I have actually suggested it be a part of every Type-S model in the Acura lineup. Type-R could do without it, as could standard models. I am opposed to it being the cure to fix existing shortcomings when it comes to "performance".
And at 25, I almost brought home an NSX, thanks to special lease deals that was being offered in 1999. Unfortunately, at the time, I couldn't afford two cars to go with that one, and 7500 miles/year wasn't going to cut it. Now that I can, there will have to be more in ASC than just being dubbed an NSX successor. So far, things don't look good.
As for the car I might purchase from the rest of the line, I would prefer if the choice was between saving $2-3K, 250 lb without the peformance aspect taking a back seat.
If Acura thinks that they can get by with FWD TL forever, like Lexus does with ES350, well, I am afraid they might be in for a rude awakening. Unless Acura KNOWS that a ES350 buyer is the kind TL gets and vice versa (have they not learnt from been there done that?). In Lexus' defense, they do offer a different flavor, in addition to ES350, the IS.
G35 is gaining popularity, and there are obvious reasons for it. Infiniti has already shown Acura with its M35/45 about how mid-priced luxury should be done.
Yeah Infinti beat Acura with the M35/45. The RL is toast sales wise next to the M35/45. However Acura still topped Infiti in units sold in 2006: Acura sold 201K and Infinti sold 121K. The RL was supposed to be Acura's answer to the BMMW 5 Series but instead the RL is a second tier competitor with the Lexus GS and Caddy STS and I don;t think thats what Acura had in mind for the 05 RL in terms of competition.
Yeah the IS is Lexus's answer to Acura's TL/TSX and Infinti's G35 I guess.
More people are likely to compare TL to IS, G35 and BMW 3-series. The competition’s fundamentals allow aggression when it comes to pushing the performance envelope without adding the cost and weight of an AWD system. I am sure a TL Type-S with SH-AWD would make for a great sport sedan, but it won’t do much if it costs $42K and weighs 3850 lb.
One of the problems with Legend (before its transformation into 3.5RL) was rapidly increasing price tag and that slowed down the sales.
And since then, people have jumped on the Vigor/2.5tl/3.2tl bandwagon.
"Most of Acura’s sales are from MDX and TL..."
Acura the TSX sold more than the Mdx. The TL sole 80k units, the tsx sold 64*** and the MDX sold 58***.
-Cj
TL : 71.3K (35% of Acura's total sales)
MDX: 54.1K (27% of Acura's total sales)
TSX: 38.0K (19% of Acura's total sales)
As far as Vigor/TL of the mid-90s go, they never were great sellers. I was talking about Legend. Between 1992 and 1995, Acura raised the price substantially by the year and reduced number of available trims. Eventually, only one trim was released with 1996 3.5RL.
