Have you recently used your tax refund (or are you planning on using your tax refund) toward the payment of a new or used vehicle? Or, are you planning on using your tax refund toward any expenses related to your car?
If so, a reporter would like to talk to you. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Are you the parent of a generation Z child (born in the mid-1990s to the early 2000s)? Do you have differing opinions on the importance of buying a car, what types of vehicles you're interested in, or just how you view cars in general? If so, a reporter would like to speak with you and your child. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Jeep Wrangler Towing
2»
  • bruleubruleu Posts: 1
    I own a 2008 Wrangler Unlimited. The handbook says the GVWR for towing is 3500 lbs, with a 350 lb tongue weight. An RV salesman showed me the sticker inside the drivers door, which says the GVWR is 5460 lbs, so I can tow heavier. I figure he's just trying to sell me a larger RV...right?
  • mac24mac24 Posts: 3,910
    Right! :D
  • erickplerickpl Posts: 2,735
    Keep in mind, even the Wrangler Unlimited isn't a long vehicle. The biggest factor in what you tow is the vehicle's wheelbase. The shorter the base, the lower the rated towing capacity. You do NOT want the tail (trailer) wagging the dog (Jeep). It would get ugly REAL quick!
    -Paul
  • I have posted here before. I had a 2006 Unlimited which I sold, now I have a 2009 4dr JK. New Jeep, New questions.
    This is for anyone who has modified their 4dr. JK to use as a tow vehicle:
    I have 2009 4dr X automatic which has 3:27's and factory tow pkg. We installed a 4 inch lift but kept the stock rims and mud tires (32's). We have purchased a 16 ft. Funfinder travel trailer which weighs 2,500 lbs. empty and will be pulling it with sway bars. My husband has already installed the 7 pin and Prodigy brake controller. I have several questions because we would like to optimize the JK for towing the trailer:
    1. Should we re-gear? To what ratio? Does it improve MPG and Power
    2. Should we install air bags?
    3. Also, I have seen several discussions regarding the tranny cooler and the placement of the stock cooler. I am afraid to install an aftermarket cooler because it may void the lifetime warranty. Is the aftermarket cooler necessary? :confuse:
  • That should read "3.73".
    1: You probably will have to, not just for mpg but for general driveability. 4.88:1 will probably be the best choice unless towing will be the major part of your driving, in which case you might consider 5.13:1.
    2: It's not essential, especially if the trailer tongue weight is correct and the trailer is balanced. Won't hurt though.
    3: An additional transmission cooler, correctly installed, will be almost essential.
    It's mere existence on the vehicle cannot affect your warranty, and as it's impossible to over cool the transmission, the only way it could invalidate your warranty is if it caused a transmission issue by leaking fluid in some way.
    If you use a stacked plate design cooler, properly installed, and with the correct type of automatic transmission hose (not fuel line or water hose), you'll be fine.
  • akcijasakcijas Posts: 13
    edited May 2010
    Does anyone know what the Trailer Sway Control for a 2010 2-door Wrangler Trailer Towing Group really is?
    The online brochure says that the Trailer Towing Group Option includes:
    - Class 1 receiver hitch (since it's a 2 door)
    - seven-to-fourpin adapter,
    - Trailer Sway Control, and
    - 3.73:1 axle ratio
    What exactly is "Trailer Sway Control." I know what the words mean, but is it a separate pice of equipment like a shock absorber mounted somewhere? Or is it a system that pulses the brakes to compensate for any sway in the trailer? Or ??
    I'm asking because I plan to buy a 2010 Jeep. I don't need to tow frequently and may just buy an aftermarket hitch versus having to special order a Jeep with the tow package from the dealer. And the salesman is telling me the Trailer Sway Control provides added safety, but couldn't explain how it worked.
    Seems I can't find a salesman that knows his stuff ....
    Any ideas?
    What exactly is "Trailer Sway Control." I know what the words mean, but is it a separate pice of equipment like a shock absorber mounted somewhere? Or is it a system that pulses the brakes to compensate for any sway in the trailer?................
    ...............Seems I can't find a salesman that knows his stuff ....
    I must admit i didn't realize it was a separate option. It's part of the programming of the various stability and ABS functions that will detect trailer sway by the motion of the Jeep.
    It will then try to correct it by reducing power and braking the wheels independently as necessary, though it's not foolproof.
    I often tow a 3Klb+ utility trailer with my older TJ without any problem, but I'm careful to keep it balanced.
    Even though you wouldn't use it to its full rating, a 2" class three hitch is much more versatile than a class one.
    As for the salesman, it's usually the case that an informed buyer will have much greater product knowledge than the salesman.
    Your poor excuse for a salesman should have at least known where to find the information, i.e. the Owners Manual in the glovebox, which gives a complete explanation of how and when TSC works.
    Thanks for the reply. I appreciate it. Why the saleman didn't know that is ridiculous.
    Looks like I'll have to order a Jeep, as I cannot find one with the options I want.
    Thanks again,
  • brent59brent59 Posts: 2
    Need help as to how to remove steering wheel lock. I have a 97 wrangler tow behind motor home. Manual says to tow with key in ACC . Ocansionally the steering wheel locks on me. Happens when I go through a good size dip in th road followed with a turn. Any suggestions or help ?
    If the steering lock actually does lock up in the ACC position then you need to replace it.
    However, that would be an extremely rare occurence. What often happens is that in the circumstances you describe the load on the Jeep front wheels becomes very light coming out of the dip; and when you turn, instead of tracking the path of the motorhome, the Jeep front wheels flip over to full lock (in other words, fully to one side).
    They aren't actually locked by the steering column lock though, but you have to stop and center them up manually as you know.
    There's little you can do about it though, except drive according to the conditions and slow right down when approaching and driving through a dip/turn.
    It does lock as I have to move the key to on while turning the wheel back and forth to release the lock.
    I found a shop where they remove the lock pin in race cars and will do this for me. I just don't feel safe thinking this might happen at high speed.
    thanks for your help
  • h2odogsh2odogs Posts: 2
    A couple of questions I have a new 2010 4dr with 35 inch tires and body lift... First which is my biggest problem is I have lost allot of performance in power and MPG due to the big tires and when on the freeway going up hills etc it slows down to much and I have to take it out of overdrive any suggestions on upgrades for the motor or gearing??
    And I plan on towing it behind the RV and need to make sure my RV can tow it what is its tow weight??
  • jeepguy48jeepguy48 Posts: 9
    go gears it takes alot of power upgrades to make up for the power lost. check owners manuel for vehicle weight. also call the stealer.
    Thanks for the suggestions. Gears are what I was expecting would be needed just need to decide what ratio. I wont be towing allot of weight maybe trailer with Wite Water Raft and accesorries on occasion. The air cleaner and exaust are just to load... Thanks
  • I was towing my 1995 Jeep Wrangler 4X4 to utah this past weekend. Around the flagstaff area i had to make a u-turn and the wheels only turned a little bit and stopped turing so i atarted to drag the front end. The key was in the on position but i had the battery disconnected. I also had the T/C in the neutral position as well as the manual transmission. I also noticed the the front drive line was locked in to gear is it supposed to be locked even when the transfer case is in neutral or do i have to go and get it looked at.
  • We're considering buying a used Wrangler and using it to tow our 2,000lb sailboat on a 4-wheel trailer. The boat is 20' long. Last summer I used a friend's Wrangler and while towing the empty trailer, had a difficult time avoiding excessive sway... especially on the curves. The Jeep owner said he needed to replace the sway bar. Would this have solved the problem, would I need to add additional towing gear, or is the Wrangler incapable of towing a 2,000 lb sailboat or was the empty trailer the issue?
    On a regular TJ, max towing in 1500..
    Even if it was 2500, I wouldn't do it. The TJ's wheelbase is just too short to be stable enough for a 20' boat. The tail WILL wag the dog.
    The sway bars (on the suspension) won't do squat. You'd at least need a beefed up connection between the trailer and the Jeep, but again a short wheelbase TJ pulling a 20' boat is just a disaster waiting to happen - IMO at least.
    -Paul
  • I'm moving from Alabama to California, i have two cars to get out there. Can i tow a 2011 Hyndai Elantra on a car dolly behind a 2010 Jeep Sport Wrangler 4wd 6 speed?
  • pstraubepstraube Posts: 2
    I have a 2008 Wrangler Sahara Unlimited. The owner's manual says I can tow 3,500 pounds (which is far more than my camping trailer weighs) and have a maximum tongue weight of 350 pounds. This is where my problem lies. I had the tongue extended on my trailer and they put a large, boxed in tray on front. I don't know what the new tongue weight it but I'm guessing a couple hundred pounds or more beyond the 350 limit.
    I asked my dealership about changing the suspension system or something else on the Wrangler but they didn't seem to know what to do. I am concerned since the back bumper drops about 3 inches when the trailer is hooked up.
    If I missed a similar thread that you can point me to, great. Otherwise, any suggestions for me so that I can safely tow my trailer and keep the Wrangler a little more level will be greatly appreciated.
    The solution is simple. You don't increase the tongue weight capacity of the Wrangler, instead you reduce the weight on the trailer tongue.
    First, here's how to measure the tongue weight using a bathroom scale (without breaking it ;) ): Tongue Weight
    Next, adjust the load on the tongue by rearranging to contents of the trailer.
    Move or add weight to the rear to reduce the tongue weight, move or add weight to the front to increase it.
2»
