Subaru Forester Electrical Problems
Wifey took it too do some errands and shut it off and it failed to start jumped it it and it ran fine for a bit. The battery was bad so we changed it but prior to that it would fade the radio out in between shifting. Changed cables they were corroded tried to start it and nothing just the litttle sound telling me that the key was in the switch not lights no accessories nothing at all? Hoping someone can give me a lead I heard something that it might be the ignition not sure just tired of searching and coming to dead ends.
-mike
aftermarket stereo?
Sounds like some kind of draw on the system although I think your mechanic may be taking you for a ride with 3 batteries and 2 alternators. Batteries may get run down but they don't go bad in a month.
-mike
-mike
-mike
Len
Mike
-juice
-mike
Thanks again. Mike185
off after driving my 1998 Subaru Forester.
Only solution I've come up with so far is to
remove the specific fuse.
That works, but is not real convenient.
Is there any alternative to replacing the full switch
assembly (lights, turn signals, brights, etc)?
-mike
I've had my car for nearly five years now, and I never noticed that switch. A few minutes ago my husband decided to clean the inside of my windshield When he came back in, he told me my lights were still on (guess he bumped the switch). We were scratching our heads trying to figure out how to turn them off, when I decided to come back inside and try the forum. So thanks again for clear and timely info!
Sandra
-mike
My dog must have switched it on.
I thought I had checked it, but obviously not
well enought.
Cheers.
Plus, I have been having some general electrical issues lately. My compass was crazy for about a month this past September (never provided the correct orientation). I tried everything the manual said and it never fixed itself. The one day it did, go figure. The drivers heated seat switch light keeps going out as well. It was out for three months or so and now is working again. Dealer told me that was a $90 part to fix. I can do without the light. Is my electrical system going out or am I just loosing my mind?
Michael
2) At this mileage, the rear pads/shoes could need replacement.
3) Ice on the rotors or wheels.
4) Was everything put back together properly when they were serviced?
Take the wheels off and use some sand paper to wipe down the rotors and remove any pad deposits.
-mike
That's the easy fix, so let's hope it's that.
Beyond that, I bet the rotors are warped, 83k is a lot of miles, depending upon how hard you are on the brakes.
-juice
-mike
I never get rotors resurfaced, if they are at a point where they are that bad, then it's time to replace them. A relatively cheap solution considering they are your brakes.
I would say get the rotors, pads and fluid replaced, can't hurt and should be ~$500 even using "expensive" parts.
Also make sure the torque on the lugnuts is correct at about 85lbs if they are overtightened they can also shake.
-mike
-mike
Dad's heading out on a 2400 mile road trip, so I helped do a little check up. We changed the brakes, bled them. The only other thing I told him to get was new tires, and he just put those on two.
Bon Voyage. Off he goes on Sunday to NC, then GA, FL, and back.
I've been getting bad reports on the C320 so now it's back to LGT or 3.0R I can't ever make up my mind. I'm on the Fence with you Juice!
-mike
-mike
-mike
-mike
