Lincoln Navigator Electrical Problems
I have a '99 Lincoln Navigator. I'm in Northern CA. When it rains, my Navigator begins to have some strange electrical problems that last for anywhere from 2 to 7 days.
The symptoms are as follows:
1. When I shut the engine off, the ignition doesn't seem to want to completely shut off. The engine will shut down, but the ignition appears to still have some power. For example, I'll shut the door after getting out and the radio will turn back on or the lights on the dash will come on and begin flickering.
2. When I'm driving, I'll hear clicking sounds like a relay is going off. Today, the "Low Wiper Fluid" light would come on and go off several times a minute and the stereo would shut down...and yes, there is plenty of wiper fluid.
3. The battery will be dead after several hours of this electrical activity. I have to disconnect the battery to prevent it from draining overnight until water the problem is dries itself out. Then everything is back to normal with no lasting side effects.
The bottom line is there seems to be some type of water intrusion that is causing the ignition to remain on somehow.
Does anyone have any experience with this problem?
JohnV8r
JohnV8r
was after a car wash, and another was after a heavy rain.
When I first got it I hauled a bunch of kids, and one claimed water came out of the rear dvd player. I have yet to see that. I contacted the former owner, and they claimed they were trouble free for 58k miles. I see no signs of water leaks inside the Gator. Where exactly should I look for water intrusion into the electrical system. What is a method of testing for a short.
J
No problem. I think something in the player had to reboot. Every once in a while it does get confused and sticks out those running boards for no particular reason, or messes up the seat position. I just restart the gator and it straightens out. Nice Ride.
Can somebody clue me in on some of my problems,please cheers,Wilfr
My problems started right after I bought it a year ago. I've been trouble free since then.
No junk...nice ride.
Anybody got some solid advise ???? Cheers,wilfr
Is there a sequence that must be followed in this process?
Also there is a switch clicking (machine gun like) when I now open the door will this disappear once I change the alternator? Is there a reset sequence. The battery is currently drained, but should be fine once I change the alternator as it was replaced 2 months ago.
Any advice, Thanks
DCB
A/C check value.
replaced TXV per TSB (I am coping the tech. notes)
part # FMC 6LIZ 19849 B
valve asy- evaporat
good luck
Floyd
Also every time I unlock my navi with the remote my mirrors go down as if I was going to reverse.
Has anybody had any similar problems with there navigator?
In any case, thanks I learned somethin today. Now I wish I could figure out why BOTH of my 1995 Ford econolines have intermittent CELs and never a code?
Thanks, Mark
In the 3 years I've had it I think it was way over priced and not worth it because they have too many problems but from the looks of things I guess I'm not the only one that has to put up with these headaches. :confuse:
Good Luck
How do i go about troubleshooting this?
thanx in advance!
please HELP!!!!
I feel the same,I WILL NEVER BUY A POS FORD/LINCOLN AGAIN!
My 01 has the same problem from water getting in dash from possible windshield,roof weatherstripping or roof rack, water flows in drivers pillar handle. damaged my GEM modular costing hundreds last year and having same problem now again. SOME ONE SHOULD GET A CLASSACTION SUIT AGAINST FORD WITH SO MANY ON HERE WITH SAME PROBLEM.
i don't exactly know where waters coming in but have seen drips on handle and under dash.
How can so many people on here have the same problems and not be their responsibility? I have an 2001 with 70,000 miles and nothing but probelms
There are many defects in the TSB's and being such an expensive purchase only adds to the headache.
Besides that, best SUV i've ever owned.......
after the dealer ship replaced the security module, we were fine for over two months...then the problem fired up again. It would happen, then not happen, it would happend for 45 minutes, then not happen, then for 5 minutes, and so on with no pattern whatso ever. We figured out that after leaving it with dealership a few days (and the navigator was in the shop right next to someone the whole time)...it finally acted up in front of them. They figured out we had a defective remote...that was unlocking the hell out of it. It even broke one of our back lock cylinders. My suggestion to you if this sounds like something you are experiencing, would be throw all your remotes away and start fresh. They are about $50 a pop and its not terribly hard to reprogram the navigator. This frustrated the hell out of us because we couldn't figure out and neither did the dealership until they hung out with car for a few days. If you need more feedback, please post another message.
