Let me know thanks.
*oh, also, hitting the preset buttons dont make the seat move n any directions....THANKS
Can anyone help me or has anyone hadthe same problem?
In both cases, opened the hood to make sure the battery cables were tight. They were and closed the hood. Attempted start... nothing. Tried moving the steering wheel different directions nothing. Tried putting in and out of partk and restarting... again nothing.
In both cases, finally gave up and made a call to AAA to have it towed back home. Each time 30-45 minute wait. In each case simply tried to start the car again and started up instantly along with the radio.
Does anybody know what the common link would be between the starter and the radio? Is there a common fuse or harness that I can check. Appreciate the help!
SUVs and Smart Shopper
then all the sudden the mirrors, driver seat and adjustable pedals all no longer work. Help!!! Any one else have this problem?
Can you help me find the fuse on the board in any way.
Even a description will help at this point.
It's all surface mount and non labeled so it's pretty tough to find.
Now it makes sense.
It's the larger fuses in the box.....
Thanks for the update.
Now it makes sense.
That should measure 12V. I just finished repairing mine, it only measured 7 volts at the connector and my battery was being drained daily. Basically the corrosion was shorting the connection to the chassis ground. I ended up running a new line from the fuse box to pin 1 on the seat module power input. That fixed everything.
