2007 Honda CR-V Rear Main Engine Problem
Bought car 12/23/07. Oil on floor 12/30/07. Took car to dealer & tentively diagnosed as above. Only 200 miles on odometer. Waiting for parts. Any others with same problem.
Honda dealer, not the one I bought it from as I did not want to drive too
far not knowing the cause of the leak. Tentively diagnosed as rear main
engine seal leak. Dealer rep told me NOT to drive it home to wait for the
parts to come in as I might experience other problems. Parts to be ordered
1/2/07.
The rear main engine seal was replaced on 1/4/07 and on 1/6 I found oil on
the garage floor. This repair was done by the closest Honda dealer not the
one I bought the car from. Which dealer do I go back to for further repair
in order to possibly qualify for replacement or money back under the Lemon
Law?
At some point you might be justified in giving up on them. But not yet, imo. I had a similar problem with a 4-day old 1998 Accord. After a week to get parts, the problem was fixed permanently. I replaced that Accord with a new CR-V. Good luck.
the rear main seal seal is pressed into the rear of the engine,the inner circle of the seal is where the crankshaft
goes through the seal (this is the sealing portion of the seal).it appeared when the engine was assemblied
gasket adhesive used on the oilpan had got onto the crankshaft where it contacts the seal,thus the leak
hope this explains it ok,if not e-mail me back or call me
I thought Honda was one of the best. I guess not.
Still waiting on diagnosis.
Similar postings on crvownersclub.com.
The guy that told his service center they couldn't drop the transmission while the car was in his name got a replacement.
The sequence is similar. First they'll check it out and tell you that sometimes there is oil on the motor from the factory. Second step they replace the oil pan gasket. Then bingo, they have to drop the transmission to replace the rear main seal and possibly some other bolt inside the engine.
My service department is great, but my engine doesn't sound like a tight new engine. It's got a low hum like a motor that has lost compression.
There are several websites that have input from owners that have this problem.
Good luck! Keep us posted as to your progress. We don't have to get nasty but we all need to stand up for our right to a new car that performs like a new car!
http://www.in.honda.com/Rjanisis/pubs/SN/a070300.PDF
i have a 2009 CRV with 3000 miles and there is leakand the dealer said it was the drain plug. Well it was not ,, i told them if it is a leaky seal i don't want the car anymore. we will see what happens
I drove my new '98 Accord home from the dealer and found oil on floor the next morning. Not happy, to say the least. The seal between engine and transmission was bad. It took 4 days to replace, but the dealer provided a loaner car and gave me several free-service coupons. The car never had another problem in 10 years.
Funny you say that, we were considering the new Equinox. However, then I looked at the reliability of the previous Equinox which got me to thinking about the GM cars I owned in the past - next!
