Ford Expedition Climate Control Problems
I replaced the battery in our 03 expi and now the A/C controller wont turn on. i checked the fuses under the kick panel inside the truck....any ideal what it could be?
See also: How to Check Your Car's AC System
I recently took replaced the front heater core myself. I was getting luke warm air, but not hot. Then the heater core blew. After talking to a Ford repair man, he informed me its very common for the blend door to go out in Expeditions. I need to fix this.
At one time, I was trying to swap a turn signal relay and the fan conrol stopped working. The dealer says the problem is the dashboard climate contol unit.
Have you found the issue? Is there a loose connection somewhere?
Every time the engine is over about 2,000 rpm's the a'c switches from panel to the Defrost vents.
any idea why? any tips would be greatly appreciated
joel
If the air from the vents gets colder at highway speeds, then this is the likely culprate.
Mark.
I have a very similar problem as to these other postings I have read,I have a 1998 ford expedition xlt with a 4.6 ltr engine,any ways
I just realized that my heat is not blowing hot air it is blowing luke warm to cold air & I am freezing in the a.m.!! even when I start the truck in the am I let it run for like 20 min & still no heat!! I changed the thermostat and did a radiator flush with top of the line anti freeze,on the high way it does get worm thats about it,but when i slow down it gets cold again. I am starting to think the heater core is on its way out!!
does anybody have any idea why this is happening? is my heater core on the way out??
is it easy to change?what else can it be?
Thank You
I would like to fix asap as I do have kids to bring to school in the am!
I have a 2004 Expedition. My air only blows up by the window, and not out the vents like it is supposed to. The switch that controls where the air will blow doesn't seem to be working properly, because I only get air flow at the window ( like defrost) and off. Do I need to replace this switch or is it some vacuum line or something that is not allowing the air to transfer to the proper location that I select?
i have a 2003 ford expidition xlt ,no heat front no matter where you put the control, so i took it to ford, they charged 77 bucks to tell me it needed a blend door controler motor. then the shocker ,1300 dollars and takes all day to pull dash . the rear heat is probably a vacume line stopped up. i took a pic of the blend door but I am not shelling out 1300 bucks . The part cost 53.50
SUVs and Smart Shopper
Thanks for any input
Thanks for the advice, Vic.
I tested the switch by putting it in my buddy's expedition and it worked fine, so i'm thinking it's something a little more serious. Please Help :confuse: :P
