Hyundai Sonata Windows Fogging
I just bought a 2007 Sonata. I love it so far. However, on the way to work this morning, my windows were really, really fogged up. Even with the defrost pumping full blast, the back windows remained fogged. Is this a known problem? Thanks.
the full window setting on the heater control dial. Does this help?
Then for whatever reason, excessively humid air is being processed. If you're operating the system with fresh air entry, reset the controls to "recirculate" mode. If you're already doing that, then it's time for a trip to the dealer to find and correct an extraneous air or (shudder!) coolant leak into the heater core casing. Check the drain hose from the heater core casing underneath the car - if it's plugged, condensation won't drain and you'll also end up with fogged windows regardless how you manipulate the HVAC controls. FYI
A good "windex" of all interior glass may do the trick--or not. Even though your car is new, it may have "stuff" (a film) on the glass.
How can this be?
It's a 6 cyl curse dave.....you should have bought the 4.
I was planning to buy the 4cyl...... until I test drove it. It was just too underpowered.
What do you think the problem might be?
