Moisture in front headlights of 07 Outback
snowbelter
Member Posts: 288
I have a brand new 07 Outback and I've noticed that there is moisture in both headlights (think of a mirror steamed up by a shower). It is mostly around the sides of the beam and the amount of moisture varies and has disappeared at night, but comes back. Rain and car washing don't increase the moisture.
The dealer has seen it, but has no clue of the cause, and has had a call in to Subaru, but no reponse from them yet. Anyone else have this problem?
Not much you can do other than have them replace the whole headlight assy. what I would do is drop a grain of rice or one of those silica packs from an electronic device in there, should clear up the problem.
-mike
We has a Mistu that did that and eventually the inside got rusty and stained.
-juice
I intend to follow up on this although I am not pleased to hear that the headlight assemblies will need to be removed.
Martin
In my experience, SOA will do you right. I understand the frustration, especially with a new car, but hang in there and I'm sure you'll be taken care of.
Ken
-juice
On my next trip there will be paperwork. Lots of it.
Martin
You too? I noticed it in mine (quite dramatically in both as the entire assemblies were fogged up other than directly in front of the low beams) on Tuesday night (picked it up Sunday) when I was installing the block heater. It was -36F that night and it was just a large series of ice "droplets". I'll have to look again today, but it might not be there since it warmed up so dramatically over the last 48 hours - we will have to hit the dew point again I suspect.
I will follow up with SoA. Hopefully multiple reports will prevent others from experiencing the same problem down the line.
I will contact SOA right now (while they are open!) to open a case, though I really hate to take my cars to dealerships for work. It always worries me.
My dealership is usually very competant, but gets sloppy from time to time on simple things like oil changes (unless you don't mind oil dripping from the bottom of your car after an oil change).
I finally managed to call SOA while they were open (hard to remember that darn time differential!!) and they issued me a case #, but did say I would have to take it to the dealer prior to any further action.
-juice
As I mentioned in another post, the SOA reps tell me that moisture in the headlights is new for them.
After driving home, I once again found moisture in both front headlight assemblies. There's strike 1. I updated my case # with SOA so they are aware.
So far, the backup light assemblies look to be moisture-free. Good. :sick:
I am getting the feeling that this car may end up being long-term rental to me. :mad:
Hope your car gets fixed correctly. I've read that the fit and finish of the 05 and later Outbacks was first class. Thats not what I'm experiencing with my car.
-mike
I will be taking my Outback in again on 3/6, but I have little confidence that additional replacements will alleviate the issue. So far, I am not sure about the long-term implications of the moisture being there, but if the water vapor is getting in and not able to get out, then it is probably only a matter of time before I have algae, at the very least, along with it.
I'm not impressed with SOA's resolution even though the basic warranty should cover any problems moisture may cause to the headlight system.
It rattles worse than a heavy metal band again, and just this morning none of the dash/instrument lights came on when I started the car. They finally sprung to life about 3 miles down the road. :sick:
Go to NHTSA's ODI section and file a complaint, if enough people do it they'll be forced to take action:
http://www-odi.nhtsa.dot.gov/ivoq/
