Most commonly (in order):
1: Wheel imbalance.
2: Worn steering or suspension joint.
3: Worn universal joint.
4: Propeller shaft imbalance.
1 & 4 usually caused by a lost balance weight.
Bought new wipers for her H3 and the JK. H3 no problem. Remember reading about JK rear wiper on other forums. Picture of sombody standing on a stool leaning over spare tire but no flame here we all have brain farts sometimes. Anyway, opened rear gate unbolted the arm and the blade came apart. Sure the rain x blade fits but it has to have something other than missing, broken, or whatever plastic clips still in the arm. Even a new old caravan blade is $60 full retail, so $60 and new plastic JK arm. Jeep please look at the rear wiper on an H3 and maybe learn something.
On a side note, either plastic pieces for the holes in the firewall where the cowling grill clips go were missing from the JK or never built. The squeak came back. Cut off all the braces on the plastic cowling grill and plastic bolted the grill to the cowling. Unless some heavy weight or a ton of frozen slush bends it, it should be ok. But since it is high strength thin steel with modern flexible paint, I'll just bend it out again. Again, sorry jeep engineers. Maybe the big boys need to quit hiring college grads with computers and hire people who drive and better yet wrench and been aroung the block a few times.
And yes the area under the cowling looks like some paint got on the dust, rust, weld splashes or whatever, so the cowling will be easy to remove to repair future rust holes or add to the dealer list of things to do sometime down the line.
Also going round and round about new shocks. At least one bill stine rear is shot and the others are just too soft. Drove the guys nuts at 4wp and they drove me nuts for weeks saying their shocks should be shipping. Past performance of kumho's on vehicles years ago reminded me of good kyb's I had years ago. Have no idea if I goofed by ordering gas-a just but they are ordered. Toyed with ideas of new non lifted springs but the only choice appears to be arb springs with a small lift that doesn't raise a rubicon as much as a sport jk as per arb. But saving that for a later day if needed.
Oil:
Have used synthetic and sometime time last year when motor seemed to get noisy (not as bad as mobil 1 was in a previous vehicle) started blending 50 syn/50 dino. The small savings wasn't that important. Sometimes gassing up twice in the same day with the option of RUG without alcohol in OKC. That meant a lot of oil and many oil filters were used last year. I also kept up with posts at bitog and other wrangler forums.
Oil useage:
About the time I noticed a drop on the dipstick at ~60k miles , posts started to show up about oil burning. Even a local poster who was using 5w30 started using oil about the same mileage. Oil use on early jk's has been identified as manufacturing problems and the original pcv's. Bitog posts have shown up again with the thin as possible and as thick as necessary. Thin oil with high hths, is interesting. One post claimed the piston rings were weak and to keep the rpms down. Could it be carbon from the pcv blow thru.
Oil in the intake:
I posted about this a long time ago (and catch cans) and went thru the lousy crd design and still can't believe it should even exist. Had the dealer change out the working pcv valve just to see if things would change. Who needs to pull a suction thru the crankcase (a little bit of less resistance on the bottom end?) and suck oil into the intake plenum. I clean the throttle plate and reach in to clean some of the gunk but will not touch the screws and disassemble anything should an issue ever arise. Also there is the discussion about too frequent oil changes with oils having higher noack numbers aggravating oil in the intake with the pcv systems out there.
Oil change chime;
After the first reflash, my chime/message would go off ever 2499 miles no mattter what. One service person didn't know anything and another dealer's service manager said don't worry about it you are using a good synthetic and changing within the 6months 6K miles per the manual. Months later a post mentioned the dealer can change that oil change message to very 3k miles, hence the chime at 2499 for the oil change within the next 500 miles. Bingo come back to the dealer for that 3k mile change baloney.
Gas:
Two summers ago used mid grade and noticed better performance. Last summer bought RUG. Now with the last heat and humidity, went straight to premium since gas mileage has been dropping. Motor sounds better mileage still stinks. Gas climbing again so back to RUG for now. Yes I understand premium is for high compression and using it can cause carbon buildup and reduced mileage but it felt like the motor had a heavy 5w30 oil in it. Can the systems be messed up. Is the computer unable to effectively control timing. Is the knock sensor not working correctly. Someone posted that jeep can retard timing(but how far) but not advance the timing if things change, don't know. One can always do the disconnect battery trick to reset the computer. On a side note on another forum, someone posted about mileage dropping. Someone answered that so did theirs right before the tranny ate its' guts. A respected poster at bitog slipped in using mid grade gas in a civic in a post about something else. One response questioned that decision. I think that's where it ended. Even though alcohol has high octane rating, I believe he like others feel/know something too. Two years ago when I mentioned the 89 octane usage, an informed person said others are doing the half tank fill with premium then when down to half tank buy RUG.
Who knows other than the shadow. Just ramblings...
Now the good part, load range E. No thanks even if only 48lbs.
You also lost a sale from me for new tires for the wife's H3. Have your load range D AT now and hate to watch the air pressure in the sweet spot where the steering doesn't feel like one is driving through glue or the center of the tire wears out.
Good bye toyo.
Slid in the rain with the 3k miles on the kumho's today as bad as the duratrac's did when they were down to 7/32 tread and 40K miles on them. But oh the duratrac noise after the weardown.
I guess maybe one should never buy a little duty anything if it has load range C tires from the factory if one isn't going to mod the heck out of it. Or the search goes on.
