Chevy Silverado and GMC Sierra Exterior and Body
New to this forum, but not to forums, so here goes.......
I curently have a 2005 Silverado K1500 Crew Cab 4x4, and would like to replace the grille assembly with the 2006 Grille Assembly. Is this possible, will the mounting points line up? How difficult is it to take off the old grille assembly? I already have the grille assembly, have painted the ears and inserts white to match the truck, now I would like to put it on my truck. (I work in the auto supplier/manufacturing industry, so I got the grille for free, if it won't work, then no harm no foul)
:shades:
Is there somewhere I can go to online that would give grille removal instructions, or can somebody give me the Readers Digest Condensed Version?
Other than this issue I love the truck.
Surveyorguy
I had numerous vehicles with factory installed sunroof over the years, but all of them either had a solid metal sliding sunroof panel with headliner trim underneath, or a glass panel with a solid sliding sunshade. One exception was my 95 Nissan SE V6 pickup which had a factory installed flip up manual glass sunroof. It had a mesh screen moulded into the bottom of the panel, but there was also a solid sunshade, which attached to the glass panel and could be manually removed.
GM should have provided at least such a sunshade panel. This panel requires that some fasteners be attached to the glass panel bottom for attachment. In case of my Nissan there were two slotted fasteners in the front, and two locking type fasteners in the back.
I have an '06 Silverado Z71 crew cab, but it does not have a sunroof. Now I am glad it does not.
My suggestion would be to buy a factory sunscreen for the '95 Nissan SE pickup from a Nissan dealer, and then adapt it with some fastening system to use on your sunroof. It cannot be that expensive. Unfortunately, I do not know if it would fit properly without trimming.
It looks pretty good.
Go to link it has before and after pics of truck.
This is just a sad example of our peoples "its someone else's responsibility" attitude. People PLEASE take responsibilities for your own actions, as it will make this country a better place to live, and maybe someday re-claim the "balls" we once had. :mad:
-mike
Ever seen a Cavalier with a moonroof ....ROTFLMFAO!!
-mike
Could it be that it was so long ago that GM forgot about it? Nah, more I think about it the bean counters figured not including the shade will save several million more so since the moonroof isn't included on most trucks.
I’m just curious if you bought a can of tuna fish, a TV you name it, and you got it home and it was obvious that it was spoiled or just didn’t work correctly, what would you do? Would you just say “Oh shucks the darn thing just don’t work right I guess I’ll just live with it.” I think not! I think you would do just as I’ve tried to do and that is to get the problem corrected. Maybe a “recall” isn’t the correct terminology, but what ever I think GM should be responsible and have the “balls” to make sure the “sun” screen is actually shading the driver’s eyes from the sun before someone has an accident as a result of it. And if GM wanted to do a recall to replace all of these worthless sun screens, so be it. If they wanted to just replace the screen for those “whiners” like myself that is their prerogative too. Maybe I should have bought a convertible instead of a pickup then I could have all of the sun I wanted.
Other than the sun screen issue I still love my Chevy diesel.
surveyorguy
That would be like buying a house on a lake at night and not realizing there was no dock!!!!
Guy, I'm sorry but you are plain old wrong, you should have checked it out before signing for it and if you didn't like it could have bought a Ford or Dodge or Nissan or Toyota!
-mike
As for the options of vehicles, sure that was a possibility, but I liked the Chevy best. And you very right, in hindsight I should have checked it out before signing for it. Or at least made it part of the signing agreement that it was corrected. But I still think GM should do something to correct the problem. Someone said the newer version (07 1/2) doesn't have this mesh screen anymore, so obviously GM figured out it was ineffective and changed it.
"GM Plant" haaa hardly, I'm not a big fan of American car makers mostly because I usually get burnt in terms of reliability on them.
As for you not buying a Ford, Dodge, Nissan, or Toyota pickup because you "liked" the GM one, then you have to take the bad with the good!
-mike
As for my own experience, I life in southeast Texas, and certainly see quite a bit of sun. The shade, in my opinion, is more than adequate. Later models (such as mine) still have the semi-translucent shade. The 4-door cab model has the full cover which blocks all light. I think this has something to do with the amount of available space in the headliner between the extended and 4-dr cab models.
Anyway, Im glad to see that people agree you should pay attention to what you buy, before you buy it. And no, Im not a GM employee either. I am in the military, protecting your freedom to complain about your "crappy" sunroof shade.
Side note, I work 3 blocks from Ground Zero, so I'd like to personally thank you for your efforts in protecting my Freedom!
-mike
1) The sunroof/moon roof/whatever you want to call it (the glass) works fine and isn’t a problem. It goes up and back and doesn’t leak and functions just like it’s supposed to.
2) The sunshade/sunscreen is made of an open weave mesh material that is on a small roller much like the old window shades. It pulls out and retracts just like it was designed to do. But it does not and I repeat does not block much of the sun coming in the sunroof. I wished I had a light meter to compare the actual difference between the sunscreen open and the sunscreen closed.
3) I’m not sure exactly how long GM has been using this particular type of “mesh sunscreen”, but I understand it may have been since the 2006 model and possibly ended with the 2007½ model. I also understand that possibly it’s only in the crewcab models since there is more headliner area and they can also install DVD players behind it. I have not heard of any other manufacturers using this particular type of pull shade (there might be but I just haven’t heard of any).
I think everyone should or does have the expectation that when they buy something be it a toaster or a pickup truck that everything will or should work as designed. Therein lies the problem, the design of the “mesh” sunscreen, it doesn’t function as a normal one would expect. It only partially deflects the sun! If this was such a good idea why wouldn’t car manufacturers have used this sort of sunscreen for the last twenty years or more with their other sunroofs? I can tell you because it ineffective as a sunscreen it doesn’t block out the sun from coming through the sunroof! It probably saved GM $5 (or less) per vehicles by not having used an opaque material, which by the way would have totally solved this issue. Of all the other vehicles with sunroofs I owned or sat in, they all had a “solid” or opaque material to close off the sunroof area, EXCEPT for my 2007 Chevy crewcab. So why change to the mesh sunscreen now. Like the old adage says “If it ain’t broke don’t fix it”.
I too would like to thank jhansen27 for protecting our right to complain about “crappy” sunroof shades. I salute you and hope you stay safe and out of harms way. Luckily for me I was too tall to be in the military during the Vietnam conflict. Maybe that’s why I’m complaining about Chevrolet’s “crappy” sun shade, because my head is so close to the roof.
Oh and my $100 solution is pretty basic and not totally functional if you wanted to use the sunroof frequently. I had a piece of hard board upholstered with material to match the headliner color and then it is sort of sprung into place between the glass and the screen. It works, but surely isn’t perfect by any means. Maybe if I live long enough to need to buy another pickup truck GM will have figured out how to make a better sunscreen by then too! Sorry to have ruffled everyone’s feathers over this issue but seemed like there must have been a simple solution short of just “sucking it up and living with it”. That has been GM’s answer so far obviously.
-mike
Interesting point on the screen issue... After some research, it would appear that the sunshade, is in fact not a shade at all. Seems GM intended it to be a screen, functioning much like the screens in out houses. So, wanting to test my newest hypothesis, I opened my sunroof in the light rain, and was quite pleased to find that I didn't feel a drop. Now, I wouldn't suggest the same in a downpour, but you get the idea. It filters out debris and moisture, yet allows normal airflow, and as we ALL know, plenty of light.
I am going to verify this with some GM folks I know, but I think Im on to their method behind their madness. And yes, even I plan to tint the sunroof darker, along with the rest of my windows! Thanks for a good debate. JH
Speaking of NY Harbor, I'm looking out at it right now. Statue of Liberty on my right and the Brooklyn bridge on my left! Thanks again!
-mike
I would suggest that if your new truck does in fact have the "mesh" sunscreen, make it part of the deal/contract that the dealer replace it with an opaque vinyl material so as to make it effective. That was an option I was thinking about to do on my own, but it would have cost me about $500 out of my pocket.
The only reason I wound up with the sunroof in the first place is because I was told I could not get the "home-link" package. This is the overhead console with the lights and the buttons which you can then program to operate your garage door remote, your gate openers etc. That was a feature that I've had on several Tahoe’s now and thought I couldn't do without.
Bottom line make sure you go physically check the sunroof "mesh" screen out and see for yourself if it works for you. Good luck!
All along we have been talking about the "Classic" 07 truck? There is a ton of time I've spent reading this thread that I'll never get back, not realizing it was the "Classic" 07 we were talking about! Jeezzzzzzz
-mike
So the screen for clarification is only on the extended cab, the Crew-cab has the traditional cover?
-mike
I like the earlier posting about using duct tape on the sunroof, I think he's on to something since the grey color of the duct tape would blend in pretty good with my head liner color. I should have thought of that before spending the $100 on the upholstery shop “fix”. Oh well!
I would just advise anyone who is remotely thinking about purchasing a 06’, 07 or 07½ crew cab or extended cab Chevrolet to thoroughly check out the sunroof and the mesh sunscreen. The service manager at my dealership, told me that he has had several complaints about the “mesh” sunscreen at their small dealership. But Chevrolet told him and me that they weren’t going to do anything about the sunscreen at this time. That is my only gripe about the Silverado, other than that, it’s been a great truck.
-mike
You may want to wait until you get back in the states before ordering a new Chevy, unless you can get that information on line somehow to avoid the "mosquito" screen problem. Good luck!
-mike
So if you have a 06 or 07 Silverado Classic your sunroof will have the roll-up type “mosquito” screen. The options for making it opaque and actually blocking some or all of the sun are to:
1. Wear dark glasses and a big brim hat and ignore it while driving.
2. Put duck tape over the inside of the glass.
3. Have your sunroof glass tinted.
4. Have something made to put in between the screen and the glass to block the sun.
I hope this clears “everything” up about the Silverado Classic sunscreen questions. :shades:
Thanks all..
