Chevy S10 - GMC S15 and Sonoma Oil Questions
my oil gauge on my 93 s10 moves rapidly up and down at low rpm and when the clutch is engaged at first I thought the problem was in the gauge or sender unit but i noticed when this is happening the engine idles rough.When I first start it up or when I get moving its just fine.would anyone have a solution for this problem?thanks
It Starts out an Oil Problem Question, and becomes a door hinge and dash light issue.
Steve
Al
My 99 runs 60 psi hot at 1500 rpm, rarely goes under 40 psi when idling hot.
Al
Al :sick:
That engine works best with factory plugs, I know they are expensive.
