Chevy S10 - GMC S15 and Sonoma Dashboard Issues
passenger1
Member Posts: 2
I have a Canadian bought 2000 S-10 that I'm trying to sell in California. Is it possible, or advisable, to replace the instrument panel so it primarily reads in miles rather than kilometers?
kcram - Pickups Host
Put your key in normal
smack key with fist to get it in farther
turn key
works for me every time, changing a key cylinder is a pain in the [non-permissible content removed], cheap parts though, so either way its not a big problem if you know what you are doing and have the right tools.
Parked truck. Woulld not shift into park. Could not get key out of lock. Pushed hard and able to put shift into park.
Cannot get key out. Otherwise, shift and drives normal.
Does this chain of events suggest something new? Please advise.
They key wore out, then the cylinder was slowly chewed up and intermittent upon using a screwdriver.
The cylinder is now stuck in the ignition on position. So I disconnect the battery when the vehicle is not used.
I've had it parked for six months now, and need to start driving it again.
Anyone with 12 fingers of steel know how to get the column apart and extract the cylinder and install the repair kit?
I found the parts at 1aauto parts online.
Since this vehicle is a stick and not automatic, I don't think this vehicle needs the starter switch solenoid since it can't sense "park" and "drive gears", except neutral of course.
I'm tempted to cut out the lock cylinder with a large caliber handgun or a grinder and just wire key switches on the dash itself.
BTW, this truck has 174,000 miles and was not made on a Friday at 4:00 PM. Still runs great, and have put a plenty of replacement maintenance parts in this vehicle.
Alas, anyone successfully taken this column completely apart, especially when damaged, and reassemble with some certainty besides the dealers?
Thanks in advance, willing to trade electronics help and solutions gladly.
Curve? for Curb?
Cheb? for Chev?
You drove over curb, and left vehicles' Right Front Wheel pressing against curb?
That's against the law of physics for one, and forcing steering wheel and lock to compensate. OK, Good Job Oscar.
Don't hit post until you read it twice first.
I don’t understand the analogy, if the sender is bad the pump is too, never heard that one before.
Any ideas??
