What I think is undisputed is that Toyota agreed to replace the headlight assemblies in '08 Limiteds, if there was a history of either bulbs shattering/melting, or premature failure of the high (halogen) bulbs. In the letter from Toyota there was no mention of any self-leveling system issues as justification for the replacement. Do you have information that would support that notion? It's a confusing idea, since, as you know, the self-levelers work on the HID low beams, not the halogen high beams, so it's a bit surprising that a high beam problem would lead to a low beam system failure. But, they are all crammed in there together.
I would be happy if the self levelers were replaced, as mine failed on two occasions before the recall.
As for the reason for premature failure, I think wwest has in earlier posts clearly identified the real problem--running the halogen bulbs at suboptimal voltage in order to use them as DRL's, a really dumb idea. Interestingly the new headlight assemblies on my Limited appear to have a much dimmer DRL. I wonder if they dropped the voltage even lower, sacrificing lumens to reduce heat?
Since the NEW headlight assemblies INCLUDE all necessary components including ALL bulbs and the self-leveling system, all components would be new. There is no "parts substitution", everything is new.
Some posters have had dealerships that are difficult to deal with. First off, my dealer submitted my information to Toyota for approval before I was put on the list for replacement. I can understand the process since the dealer doesn't want to get stuck with paying for something they won't get reimbursed for.
Google around for "fixes" IIRC holding in the eject button for a few seconds should make the unit spit out (one by one) any discs it has in it.
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
The stereo/CD player is one unit. I had one replaced under warranty on my 2007 Avalon. Service Mgr. said cost would have been $1200-$1300 without warranty.
Info -- Adjust Clock -- Auto Adjust set to ON -- Daylight Saving set to ON -- OK
My '07 Limited just went to Daylight Saving..... it should work...
Do you live in a border area for time changes? Is your clock set to the proper time zone for where you spend most of your time? fin
Good luck
Skip
PS My 2008 went through 3 in the left hand side, before it stopped doing so, and worked fine and trouble free. At least until I traded it in.
Both of my low beam hid headlights started flickering at one time or another and I eventually replaced both. I purchased identical HID's off of the net. To date I have only replaced each bulb once. The current general high beam bulbs have been in for the past 3 years. I have 222K miles on my 2008 LTD. No other problems - it is a great car and will give you many, many more miles of carefree driving.
In the example:
DOT U2LL LMLR 5107
51 Manufactured during the 51st week of the year
07 Manufactured during 2007
Hope you get it figured out as bad tire are really annoying on an Avalon.
She rarely uses her brights and none appear to have exploded or damaged their housings. I don't get it, except to know that trying to replace her dead high-beam bulb is sure to make me remove the battery. The dealer wanted $100 to do this job and I think that it smells. After cycling all the lights, my impression is that the little amber guys are her daytime running lights and that the brights are not; also, that the discussion about that does not apply. Am I wrong?
I bought a used 2008 Avalon last Fall and my wife, who does not use high beams very often, discovered that they both were not working. Both of the bulbs were broken, I assume from a mini explosion. I replaced both the bulbs with the $46 bulbs and the drivers side did require battery removal. I was not aware of the 9011 bulbs being a replacement bulb. Wondering if these will work as the DRL in low voltage mode. I would be interested in what you find.
2008 Limited...changing the HID bulb...passenger side. I was able to get the cap off and assembly out, changed the bulb but can't seem to get the assembly back in the fixture. I spread the "fins" back a little. It seems like something needs to line up so the assembly will engage with the fixture. Any advice? Thanks!
