Honda Odyssey Warning Lights
I just purchased my very first minivan, a 2007 Honda Odyssey EX-L. I drove it 50 miles and the engine light and "D" (for Drive) light started flashing at me. I immediately took it back to the dealer. They returned the car to me 2 days later saying it was the 3rd gear pressure switch, which they replaced. I drove the car two more days and again both lights came back on. The dealership has had the vehicle now for an additional week and has put over 200 MORE miles on it to try to 'fix' the problem. They've flushed the transmission twice and traces some electrical wire in an attempt to troubleshoot the problem. Have any of you experienced this with your new '07 ODY? The dealer has had the car more than I have AND driven it further than me; I am deeply concerned that I just made the biggest purchasing mistake of my life... What can I do?
They are now on number two and, it seems, trying hard to get it right. It sounds as though they are doing what they can to avoid replacing the transmission.
This is why new cars have warranties. Unlike certain other manufacturers, Honda (at least in my experience) does stand behind its products.
Keep all the work orders to prove it had problems shortly after delivery in case it can not be satisfactorily repaired.
Both problems have similar characteristics & are common problems with the '99-'01 Odysseys.
Have somemone check the error code with a diagnostic computer.
If you have a bad trans...make sure you are well informed about the class action lawsuit + surf Edmunds for advice. Don't pay for a replacement.
The first was the low tire pressure warning light, which has come on 2-3 times when the car was cold and first beginning to be driven after being left outside for 3-4 hours (I should add that the temperature here has been in the single digits and low teens for the past week). I attributed that to marginally low pressure to begin with that further dropped when the car sat out in the cold (if she'd stop driving it for 30 min. or so, I'd add air to the tires). The light went off not long after she started driving (presumably b/c the tires heated).
The second light she described said "Side Airbag Off" and came on shortly after she went through the car wash with the car and began driving again. It stayed lit for a few minutes and then went out too. She was alone in the front of the vehicle with nobody else in the car and I believe had no things on the seat.
Car is going in for its first service early next week - I already have a laundry list (2000 rpm drone, loose glovebox, transmission shift delay) and would like to know if there anything else I should know or is this just likely extreme cold-weather related jitters?
-FS
My Passenger airbag light does not stay lit either and will be checked at the next oil change.
It could be something as simple as a loose gas cap or an overfilled tank. You need to get the code read to determine what the issue is.
On a humorous note, they gave me a FORD as a loaner vehicle.
Jere
I can not find any reason. Recently oil and filter changed. I bought it in Jan 2008.
Check your owner's manual - it has specific information on this light.
The dealer changed the transmission fluid 3 days ago and now I have the problem. I was hearing a whizzing noise from the engine compartment in front of the driver and was having trouble starting the car prior to this happening. That's why I went to the dealer to have them check it out. They tested the battery found no issues and also checked the fluids and recommended a transmission fluid change - now I have this problem. The transmission is slipping and the check engine and D light went on.
Could the dealer service have caused this problem or was it already there?
The car has 130k miles, I had the transmission replaced under warranty around 30k and then checked during the class action suit but they said it was fine. How bad off am I? I was hoping for 160K+ miles.
NH Bob
Any thoughts on
Or follow these instructions:
Turn off the engine.
Press and hold the select/reset button in the instrument panel, then turn the ignition switch ON (Position II).
Hold the button for at least 10 seconds, until the indicator resets.
Manual says emissions issue? I have driven it another 400 miles ( had to get home!). Light is still on.
What is it telling me? Fuel cap was tight.
What the...? I plan on taking it in to the dealer (duh) but I am not the happiest guy around. Remind me why I bought a Honda? Anyone else out there with a similar issue. It's a Honda - not a Toyota (joke).
