Toyota Camry Interior Condensation
I have a 2004 Camry LE which I love but now that einter is here, find that interior glass of the car (windshield, windows, rear windshield and moon roof) all seem to get excessive icing on the INSIDE of the car. Somehow moisture is getting into the car and I can't identify the source. Has anyone else had this problem and if so, how did you fix it? Could it be that windshields/windows are not properly sealed causing moisture to get into the car? This even happens on cold dry weather.. very strange
Else, I'd look for some window/trunk gasket not sealing correctly, or possibly a clogged drain in door window, or leaking moonroof. Somehow liquid is getting into the car.
Moisture is getting in
Read about the EED, Electronic Evaporator Dryer, at airsept.com
It also helps tremendously to lower the windows slightly during the night in your garage.
