Scion tC Audio System Problems
i have a 2006 scion tin can.
stock head unit blew out, some kind of electric malfunction, works when it wants to (blinks on and off, dials work, when its on). checked for a faulty ground, but the odd behavior still continued. check all the fuses, everything seems fine. there is no output sound from the speakers, i do not thinik they are blown, because i installed an aftermarket cd player, and there was power to theh cd player, but no sound out of the speakers.
someone tell me what i need to know, please.
i dont know if anyone ever had to drive around with no music.
help!
http://www.scion.com/#referenceGuides
One (the easier way)-
Change the Welcome Screen Greeting. To "Scion" or to your custom.
Look for Audio System owner manual. If you have the basic radio (volume button is in the middle), its on page 22.
Second (Harder way)
Disconnect battery (make sure the temp. is turned to cold. One time: I had it on heat and I connected the battery. All of sudden the car started funny and noticed the A/C automatically came on while giving hot air.)
Wait for 10-20 minutes and reconnect. Radio goes to factory settings (You'll need to re-program stations, Scion Sound setting. "Scion" is your greeting.)
But...you'll need to re-program power windows, sunroof. Which is tricky to do. Cause timing is the key. If you don't do it right; your sunroof won't auto open with one touch.
Here's a help link to anything....
http://home.cfl.rr.com/icdedppl/faq.html#c14
JMahon :mad:
If you could help that would be great. Thanks.
The post you're responding to is about a year and a half old, so I'm not sure the original poster is here to see it. You could try asking in the Owners Manuals discussion here, or try looking at Scion's reference guide downloads if you're just looking for the audio system manual.
Thanks for your offer of a radio manual. Could you tell me what year model it's for. I've got a 2009 tc and I see there are different radios for different years.
Jack Mahon
Does anyone have any suggestions?
Does anyone else have this problem?
Anyone know of a part I could buy?
And how to install everything so it sounds good without affecting the current quality?
