Please specify what year is your car.
Can you indicate problem code number?
The only way to stop it is to slide the key into the ignition (without having to start the car!).
As soon as I close the doors and lock, either by pushing the door lock buttons down, or by using the key (once again, turining it right or left), the Deterrent system is activated by the single horn honking.
If I lock the doors while driving in the car, then stop and turn off the engine, the horns will go off once I pull the key out. I need to slide the key back in to silence the horn, then I can get out and shut the doors and the system rearms itself.
Anyone had ideas what to do? I can't keep waking my neighbors up each time I need to use the car.
tom
The link (and some others) can be found in the Online Repair Manuals guide.
thanks, den
I have changed the theromstat. This radiator has 117,000 miles on it. I am thinking about putting in a new radiator. Any thoughts?
Thank you for your time
Joe
Replacement is easy. After draining rad and removing upper rad hose and fan shroud, remove four nuts holding fan clutch in place. Remove fan clutch and replace with a new unit. Good luck.
