Toyota Hybrid Highlander Interior & Passenger Comfort Concerns
I have a brand new (1 week old) 2007 Highlander Hybrid Ltd. It came with "heated" seats, although heated is a misnomer. They simply do not come on until at least a half hour passes and then they are only on for about 3 minutes. My commute is 15 minutes so they are essentially worthless. Our other vehicles with heated seats, all BMW's, work great - the seat is hot within about 1 minute of driving. The dealer says our seats work fine, although their gauge indicates the seat only gets to be about 77 degrees, which is barely even noticable to my bare hand (the pre-heat temp was 68 degrees). Anyone else have problems with their heated seats?
It does not seem to heat the entire seat cushion nor the whole seat-back. On cold mornings, <=30-F, I can barely feel it on my bottoms and only feel it around the center to mid back, nothing around the sides or shoulder blades.
We found that if we wear no more than a shirt and a sweater, the heat comes through the clothings OK and does heat us well enough. If we put on a jacket, then we can barely feel any heat at all.
Wes
FYI - It is 18 degrees (high) today here. I am now using the heater also.
the regular heating system is somewhat worse... usually I turn the fan on myself to get it going as the auto seldom starts up in the first 4 minutes, even though the outside temp is reading -17!
buddy of mine has a Mazda 6 whose seats start warming up as soon as the button is pressed...
I'm with you on the regular heating system - even though the auto was on and working when I turn off the car, the next morning, I have to change the "mode" for it to come back on. I'm just thankful it barely gets freezing up here in Seattle. Negative 17 sounds horrible.
BTW - to top it off, my gas mileage is no better than what I get when I drive my wife's X3. The dealership service department told me that I don't have a long enough commute for the hybrid system to work, WHAT???? So our X3 gets 15 MPG on my 4 mile commute (about 10-15) minutes, and is rated at 17 MPG city. The hybrid gets 15 MPG or worse for the same route and is rated 31 MPG city??? I would be happy with something in the mid-20's, but I'm certainly not a happy hybrid owner at this point.
Regenerative braking CAN result in the anti-lock system becoming inoperative on a extremely slippery roadbed surface, just as would/might actual engine braking result in an unsafe situation on a FWD vehicle. And, obviously, as the OAT declines the potential for loss of directional control due to POWERFUL regenerative braking at the front on an icy roadbed increases dramatically.
Suppose Toyota and Lexus have recently licensed and adopted these same procedures?
In the wintertime the engine already needs to run more often to keep you WARM and the catalyst HOT. With the adoption of the patent techniques the engine would need to run even more often, or at higher power levels, to keep the hybrid battery recharged.
I could see that reducing the level and duration of seat heating might be a good move considering these circumstances. Are even like operating two A/Cs with a too small genset in a MH, lock one out while the other runs (heats).
Cloth seats, here we come...!
Are you sure it isn't a "feature"? My Ford Freestyle auto climate control keeps the fans off in cold weather, until the engine heats up, at which time the fans come on to blow (warm) air. I can over ride the fans if desired, but I personally don't like cold air unless it's hot outside and I need A/C!
Dealership (Michael's in Bellevue, WA--we bought from Burien, but Michael's is closer to us) said nothing is wrong. I can't believe it.
Today is the fifth time in (maybe fourth...who knows by now..).
They tweaked the computer and the amount the seats cycled and it worked for about 1/2 a day. They then got in a Toyota rep who said, yeah, the seats aren't working. They replaced the seat covers and elements and the drivers side bottom started to work well, but the backs did not heat up and the passenger side didn't work at all.
Yesterday, they took the car again since the Toyota Engineer was coming in and after a day of working on it, he found that 2 pins in the junction box were not connected.
SOOOOOO, they SAY they work and they test well, but we shall see (I should get car back today.
This has taken farrr too long. If you think the seats aren't heating up enough, they aren't. They should be mighty toasty.
:mad:
You are driving a hybrid, you know....
Keep pushing back. Toyota Corporate is involved in mine. If more people complain, they'll have to do something about it.
From Calgary, Alberta Canada:
Have 06 Highlander, with same heated seats activation problems as described here. (very long, sometimes never to activate, just barely starts to activate, then cuts out and cycle repeats) Nothing like any heated seats I have ever seen (including previous SIenna)
Has anyone found a resolution to this? Would your dealer (who solved it) help by passing to our dealer?
We are being bounced back and forth from Dealer to Toyota Canada who assert this is "normal"!
Since delivery (now over 1 year) have had over 35 contacts with Dealers/Toyota Canda. (This is ridiculous!)
I've come to terms that this is just a poor design. This time of year, I keep them on all the time and every 20 minutes or so--if my trip is that long--I get some toasty seats.
Luckily, I live in the relatively mild Puget Sound Area. I feel for you in Calgary!
Toyota Corporate was MISERABLE with this case and finally just dropped it. I don't know if its an open or closed case. This summer they never called me back (didn't need the seats this summer).
The guy at my new dealership said that they do suck and this is just how they work. Terrible, I know. But, since I don't expect them to work, when they come on, it's a nice surprise.
Isn't that terrible?
Really appreciate your response post, sincerely.
While I would agree its a poor design (or poor choice of parts, some heating pads are identical to that [useless], There appear to be owners of Highlanders whose seats work as you would expect. (and our Sienna they were fine).
I'm not sure I am prepared to leave this as is.
I am absolutley shocked at Toyota corp. terrible response.
If by some miracle you find out something, please post it.
I certainly will.
can anyone out there reading this pass along a solution?
Are you reading this: someone at Toyota Corp?
Thanks again to susannamp
It just caused me SOOO much stress for months, I wasn't able to enjoy my new totally cool hybrid SUV!
And they may have licensed Ford's patented technique that results in less regenerative braking capability duirng the winter months, as a SAFETY matter, thereby requiring them to make extra/additional fuel conservation measures.
Now I understand why our Prius has cloth seats.
Thanks in advance.
What ashtray?
Perhaps it's because that car wasn't as aerodynamic as newer cars and the airflow across the rear windows not as smooth.
The entire effect is much like blowing across the top of a sode bottle and creating a tone. only in this case teh "bottle" is the interior of the car and the opening is the window. The frequency of the vibration is so low you feel it more than hear it.
How so very correct....
Manufacturers have been addressing the issue of ventilation loss for about 15 years now. The idea is that once the cabin air is "conditioned" don't let it flow "out". Bottom line is most new cars are so well insulated and sealed that the only air outflow path is the smallish exhauster port provided, usually in the bottom of one of the rear quarter panels.
Stand up for your rights!!!
Bob
I wish they had a high/Low switch.
Thanks for the info.,
Bob
You may have already noted this as it sometimes results in sudden and unexpected fogging of the interior windshield surface.
The ONLY reason for having the A/C operational when the OAT is significantly below your comfort setpoint is to (hopefully) dehumidify the incoming FRESH airflow.
There is a group of C-best options available for the Lexus series that may also be available for you that can be of great help.
a) The A/C can be disabled indefinitely (multiple restarts, etc.) by turning it off just once.
b) The A/C can be "unlinked" from operating automatically in defrost/defog/demist mode.
c) The climate control can be prevented from automatically switching from "heating" into "cooling" mode. Absent this setting the climate control will automatically switch from footwell outlet into footwell/dash and then dash only as the cabin temperature rises closer and closer to your comfort setpoint.
In footwell mode some slight level of "warm" airflow is intentionally routed to the interior surface of windshield to keep it (hopefully) above dewpoint.
The most recent "lot" of Toyota/Lexus products will now automatically switch back into heating mode if the OAT declines below ~34F where the A/C is disabled and thereby cannot be used for dehumidification.
Prior to (back to ~1968) these C-best options becoming available I simply disconnected the A/C clutch electrical connector throughout the winter months.
Google for:
wwest denso demist
or
Denso "two layer airflow"
or
Denso "ventilation loss"
Remember that the 2008 HH has side airbags built into the front seats. Seat covers would have to be designed to allow them to deploy.
I bought a back seat cover from these folks , for the dog,
decent.
They have a good web site, I'd recommend calling them for verification once
you locate what you're looking for.
They send you 20% off coupons after you buy something from them.
You may be able to negotiate up front with them .
www.autoanything.com
