Chevy HHR Brake Problems
123457
  • pmahargpmaharg Member Posts: 1
    I've been a GM service consultant for 25 years and I own a 2006 HHR. I have had my rotors machined and have experienced pulsation. The pulsation comes from heat build up usually due to driving conditions and/or customer braking habits. People who drivve in hilly areas or are more agressive drivers and brake late have the pulsation most. A couple of suggestions: you can try to change your braking habits. Try to focus on traffic ahead and anticipate traffic slowing. This will allow you to start to brake earlier and minimize heat build uo. If you do not want to change the best alternative is to purchase a set of aftermarket drilled and/or slotted rotors. These dissipate heat much better than the solid rotors. I have seen peolple have outstanding results doing this.
  • hatemyhhrhatemyhhr Member Posts: 7
    I took my car for the engine light, service airbag light, and the AC not working. I explained to the guy the temp. gauge on the dash goes flat and the AC goes out at the exact same time. He was not beleiving me for some reason. He said he could run the diagnostics on the engine light & if it was the engine it would be covered by warranty - he suggested I run diagnostics on the AC aswell & airbag but that was not covered and I would have to pay for the fee - 96.00 - So, i do it and the results was the thermostat was not working properly. So I did not have to pay for that BUT to fix the AC, which he said was NOT related to the thermostat would be 200.00 and to fix the air bag light would be 293.00 ( for air bag it says tech found need sir coil ) They also said the light has been on since i got it " says the code " ?? but I would still have to pay. I declined. I cant afford that. I do not feel like I should have had to pay for the diagnostic with the AC b/c since they fixed the thermostat the air is working fine & has not stopped working. Thank goodness i dont have any money or I would have paid for something to be fixed that did not need it.
    The GM guy drives my car w/ me in it - he hears the clunky noise and tells me its the tie rod but says it is not covered. He says my rotors need turned, not covered, then he also tells me even if they are turned they will warp again. He was driving my car and he got right on the highway - of course hardly any braking until he goes off highway only to get back on and straight back to the dealer shop. I said " drive it in the stop and go traffic " It bothered me as I saw it was a deliberate move to avoid really seeing how bad the car is.... but what ever. I got the thermostat fixed & i really feel like I should not have been charged for the AC diagnotics because that is clearly the reason for the AC not working because since the thermostat has been replaced the air is working fine - just fine ! They had my car for 2 full days and fixed the thermostat.They said they were going to fix the recalls but did not fix them. I appreciate your advice. I will get some rotors and shoes or whatever they are called at advance auto parts. I went down there and a parts man that works there has an HHR - has the same breaking problems too. He said soft shoes fixed his problems. I swear it is not my breaking, it is not my driving. I can assure you without even knowing the others with the rotor problem it is not how there driving. I have drivin the way I drive with every car i have had. Even when i was a teenager, and im sure i wasnt the best driver, I have never had this problem with any car. i had tires put on a company truck and i asked the tire/brake guys about it and he said the parts they ( GM ) are JUNK. I know he is right. I also have a 1980 Z28 Camaro with drilled/slotted rotors but thats a whole different class - They sure do not make them like they used to.
  • snowmomansnowmoman Member Posts: 20
    Do you know how ridiculous you sound? I've driven cars for 41 years. You've
    just admitted your rotors suck. Incredible arrogance from you and GM. I've worked in an auto plant for 22 years--and your brakes are no good. Way to go GM!
  • drv4fun2drv4fun2 Member Posts: 2
    Really?! You are a GM service consultant for 25 years and you are going to make patronizing comments alluding that it is the fault of the DRIVERS that there are so many brake/rotor problems?! I find it ironic, that I have owned many new cars (Pontiacs and Chryslers) and even though I drive them in the same driving conditions and employ the same driving and braking habits, I have NEVER had a problem with any other car, like I have had with this HHR! I look forward to the day when a class action law suit is filed for this known problem and GM has to own up to the fact that they installed incorrect rotors and their arrogant refusal to do the right thing....instead of posting insulting comments to denigrate the intelligence and driving skills of their paying customers.
  • barbannabarbanna Member Posts: 6
    The violent pulsating that I experienced when braking my 2007 HHR began less than one day after I drove it off the lot in May 2007 (with less than 300 miles). If you check this website, you can read my May 2007 postings about this chronic and dangerous problem. After one year, and the dealer attempting to fix this problem a FOURTH time, I gave up and traded it in on a new '08 PT Cruiser (and I LOVE it!).
    I can't believe that GM hasn't done something about the pulsating brakes of their HHRs by now! Hopefully they will come up with a remedy before someone gets killed.
    Already been there with you guys. Your solution was for me to pay to have the dealer diagnose the situation.
    I know - i think it is so wrong on so many levels.
    The whole car is CLEARLY A DEFAULT IN THE MANUFACTURING AND DESIGN !!
    The GM service guy says to me when I declined to have my "service your air bag light " for 200+ dollars --- " Isnt your life worth more then 200 bucks "
    I said yes it is & I will sue you if it doesnt go off -- He says " you cant, you declined to have it fixed "
    I have no words that I can post on here for the way I feel.
  • rstruthersrstruthers Member Posts: 29
    I do not agree with you mr. GM. I have driven a hundred different cars in my 40 plus years of driving and have never had a car (my 2006 HHR) exhibit so many defects. This car drives like it is 20 years old and has 200,000 miles on it. From day one I have had to repair and replace componets on it at my expense. GM is of no help and I will NEVER buy another GM product. And hopefully my family and friends will not either. I tell everyone I deal with about this junk car and I hope GM loses many, many customers.
    Why don't you get with the rest of the competition and recall the junkers? :mad:
    Thanks for the info. I think there is also a suggested break-in after parts are replaced isn't there, like being easy on then for the first few hundred miles? I went with aftermarket also (nothing special) and mine have been fine. Problem fixed.
    Well --- I had to post this -
    I took my car to the dianogstics - cost me 96.00 -
    A WEEK later the engine light comes back on - AC quits working all at the same time again.
    Then another problem ( shocking ) the key gets stuck in the ignition and wont turn back. It wont do anything - its like the whole car is locked up.
    I call GM service where I just had my car a week earlier - I speak with the guy who " helped " me. I told him they did not fix the the problem. The engine light is back on -- blah blah blah --
    I said I am NOT paying for another diagnostic !! I am pissed at this point.
    I have MS , i am in severe pain & im on my way back from doctor in the 100 degree weather, afarid cuz the engine light is on, im sick and very hot. I couldnt wait another second to call this fool. I put my windows up ( surprised that worked ) call the guy, talk loudly that it is not fixed, nothing is fixed. I ask why didnt they even fix the recalls ? No answer from service man.
    He tells me i can bring it again but i would have to pay for another diagnostic.
    Now how is this fair ????????
    Also, how can they not fix the air bag thing when it is listed in a service bulletin ?
    Im so confused how they can be such complete jerks. :mad:
    I just cant take it.
  • lainieclainiec Member Posts: 3
    I did love my 06 HHR......reading all the posts on here, I'm beginning to think purchasing it was a huge and very costly mistake. I took mine into a service center this evening (not GM) for an oil change, tire rotation, and for a quick look at the front end to see if they could determine what was grinding/dragging and causing vibrations. First I was told there's nothing wrong with it-brakes and suspension are just fine....then they informed me that it was starting and running 'rough'. Really? Funny that wasn't happening when I took it in--no engine issues at all. When I tried to start my car to leave the service center, it would barely turn over, the traction control light was on, the service engine light was on....at that point they took it away again and then informed me that I need a new fuel pump and probably a new drive shaft and a new drive shaft sensor. Also claimed that both lights had been on when they took it. Now they think I should bring it back tomorrow so they can look at it again........My plan was to find a GMC dealer somewhere close and get their opinion on what the other place might have done to cause problems during the oil change and tire rotation, but from reading all the posts on here, I'm now very reluctant to do that. (and to think this all probably started with dust/dirt buildup on the rotors)... Suggestions anyone?
  • calnmadsmomcalnmadsmom Member Posts: 24
    Is the vibration in your steering wheel?? I have had new sensors, drive shaft, multiple turns of the rotors on the lathe. Just to have the vibration in my steering wheel come back. I read on another blog that many have the same issues. If you can tell me about the vibration and if its in your steering wheel I will tell you what I was told to do to fix it..and thus far it has worked. But, along with my vibration was also a clunking noise. Do you have that?
    It may be affecting the steering column, but if it is, it isn't bad enough that I've noticed it yet. The noise and vibration in the gas pedal are the 2 big symptoms for me right now. Happy to say that when I started it up a few minutes ago, the traction control system was back online........It did have a terribly clunking noise when I test drove it--made the dealership replace the front brakes before I purchased it 7 months ago and haven't had a recurrence of that issue.
    The only way you are going to stop this brake shudder is with aftermarket rotors. I recently installed drilled rotors onto my 2007 HHR and now it is flawless, no shimmy, no shake, stops on a dime. The stock rotors are junk. As far as the traction control problem, consider this. About 2 months ago my wife was driving the car and it went crazy, clunking, braking problems, with the Traction Control light on. I checked things out and noticed that the emergency brake lever was just slightly on. When the hand brake is on the TC light is on. When the brake is on and you drive it apparently it faults out the system. This may not be your problem, but it's worth a try. Get in the car and engage the brake and disengage it a few times. Shut the engine off, restart and see what happens. Sounds minor but its real--trust me.
    Not the emergency brake--although the cable could have bin a little wonky and may have caused one of the sensors to mis-read. When I started it late last night, the traction control system was back online.....haven't driven it yet this morning, so who knows what today may hold. As for the brake system--the car is vibrating whenever it is in motion, not just when the brakes are applied. I'm not sure if it currently has the standard chevy parts on it or not--the Dodge dealership I purchased it from last October put new brakes on the front.
  • warvinwarvin Member Posts: 10
    Thanks so much for the recommendation. About a year ago I took it to a local car shop that took cars under warranty and they actually fixed the problem. However, the warranty on this work was good only up to June, 2011. It started shaking two weeks ago. Go figure...thanks. I will take it to another mechanic who comes highly recommended by my sister to fix this problem one more time. I do love my HHR thought.
  • itfiguresitfigures Member Posts: 1
    Well, I have had this problem on and off since I got the car in 2008. I know it is the Rotors getting warped. GM dealership explained that the rotors are made with cheap metal to keep costs down. They cannot handle the excess heat and warp. I believe that the real issue is that the rear brakes are out of adjustment. The rear brakes (especially if you have drums) need to be adjusted regularly. Every couple of months. Most people do not due a hard brake adjustment in reverse to have the automatic adjusters do their job. The rear brakes can get dirty and rusty and then don't work properly. Therefore, instead of the brakes being lets say 70% in the front and 30% in the rear when you make a brake application. They are probably something like 95% front and 5% rear. This will cause the front brakes to overheat and warp due to the above mentioned issue of metal quality. Check your rear wheels for rear brake adjustment. It is simple to do and if needed make the adjustment yourself. Otherwise have your dealership check the rear brake adjustment at every service.
  • bstruebstrue Member Posts: 1
    WOW. I'm sure the info you included in your post was useful, but,geez....
    Have you ever heard of a period?
    :confuse: That's got to be the LONGEST sentence I've ever read.......It's hard to make sense of it.
  • azygosazygos Member Posts: 9
    Thanks for this post finally found some real information that i can use!
  • sjdude10sjdude10 Member Posts: 1
    Can you tell me where you bought the power steering motor. Thanks!
  • dariuss1dariuss1 Member Posts: 1
    Hi I would also like to know where the power steering motor was bought -I'm having problems also .I also contacted Chevy asking why the Colbalt had a recall and the HHR did not as they are basically the same car .I also got the run around saying because they are made in different plants . Typical GM . Being a retired GM tech. I know a bit more than the average person ,I am not paying a crooked dealer for something I can do myself . I have searched all the major auto parts stores and no one stocks or knows anything about the GM electric power steering -any help is apprecaited . thank you
  • curlylccurlylc Member Posts: 2
    After reading some of the other comments I don't know if i can take comfort in other's having similar issues.
    My car has been checked and rechecked by a dealer that says there is nothing wrong with my brakes. And now that it is turning cold it has gotten worse. It sounds horrendous. I swear it is waking the neighbors when I hit the brakes as I pull up to my home. And now it also is shuttering. Last year I must have taken it in 4 to 6 times for the brakes only to be told they are fine. And sometimes the noise improved for a while. Well the noise is back any suggestions. Does the shuttering mean that that it is the rotors? I don't have the funds to keep going to the dealer to have them do nothing but charge me for looking at my brake shoes. My car has less than 30,000 miles on it and this seems wrong.
    Maybe I should just trade it in for a FORD.
    If you are reading the posts then you should know--your rotors are bad. Forget about the dealer who is only going to lie to you and cost you more money. You need to buy a set of slotted rotors that will dissipate heat and a new set of pads. You can buy the set on Ebay for about $125 or less. I did this and have zero problems now. It's easy to do it yourself.
    Don't even listen to anything else. Just do it.
    The stock rotors are cheaply made and are warped.
  • laserbluelaserblue Member Posts: 313
    I had a similar problem on my 2005 Equinox and the problem was the "Rotors".
    Every time it happened the dealer had to machine them because they were warped, afterwards everything was fine and then the same thing happened until the dealer couldn't machine the rotors because they were to thin. Had to change them (the originals) and then...no more problems with "warped" rotors. Go Figure!
    Don't spend to much money letting mechanics say that everything's normal...change your rotors once and for all.
  • up_for_lifeup_for_life Member Posts: 4
    edited December 2011
    i have to agree with the HHR being a total piece of junk.
    i have a 07 LT2,
    its been to the dealer under warranty 8 times sense i purchased it new.
    one time under 5000 miles? no start with the remote start with check engine light on. dealer fix? replace gas cap.
    two times were under 5000 miles? for brake issues. dealer fix? to turn front rotors.
    after 5000 miles? i was told sorry about your luck sucker, you bought it you fix it.
    under ten thousand miles? front sway bar links needed to be replaced. (bad clunking fix)
    under 15,000 miles? no start again, another gas cap.
    under 25,000 miles? gear selector busted, couldnt get the key out of the ignition. dead battery.
    32,000 miles? left front hub and bearing shot, warranty replacement.
    under 34,000 miles? no start with remote start again, (Fix?)all 4 injectors needed to be replaced, ecm reprogramming and left lower control arm bushings. how did they see these from the engine compartment?
    under 35,000 miles? needs right front hub and bearing replaced, will be going back to the dealer soon.
    under 35,000 miles contacted lawyer? you bet, im tired of playing with these people (GM). was told i have a claim
    my girl just had to have this piece of crap because it was sooooo cute.
    i`ll NEVER buy another chevy as long as i shall live. you can take that to the bank.
    so lets see, sold a paid for conversion van for down payment for this junk.
    after a year and a half of payments, lost job and sold a paid for s70 volvo to keep this piece of crap.
    yep im a dumb sucker for sure, why? because i still have this piece of crap HHR.
    OH,
    did i mention the driver side front door is rusting out where the outer and inner skin was welded? yep clear as day.
    did i mention the bowtie is all but gone on the rear gate? yep
    did i mention im on my 5th set of brake that i bought out of my pocket? yep. 4 new sets of rotor, first set turned once, 2 new rear drums, needs a new set now.
    replaced both rear wheel cylinders twice, and rear shoes twice.
    pulled the main 30a abs/traction fuse, still have vibration from the rotors in the steering wheel, but way less now with the abs off.
    vibration so bad at any speed, but over 45mph it will rip the steering wheel out of your hands.
    with all the vibrations, im sure the outer tie-rod ends needs replaced now as well.
    waiting on drilled rotors and metallic pads to arrive. will try these without the abs/traction during break-in, then will replace fuse.
    if i still get the abs vib, dealer will see me again.
    ONLY +
    i actually get 31mpg in town with the 2.4L motor. still doesnt out way all the bad this car offers.
    Sorry to hear this. Mine is a 2010 LT2 and went cross contry (east/west) twice = 12,000 miles and (north/south) once = 3,000 miles + local driving in traffic, hills, curves, gravel roads, mud, snow and not a single problem.
    The best G.M. product (because it's my 8th one) that I ever owned.
    Planning to go (north/south) again next summer and (east/west) in summer 2013.
    Yours must have come out from the "lemon" departement and mine surely from the "creampuff" departement.
    im glad yours is doing well, i sure wish i could say that about mine.
    i told my girl after the third visit to the dealers for repairs, to just let them keep it. i could see the way this was going to end.
    But NO she just had to have this car, as i said in my previous post. it will be my LAST GM purchase.
    the car actually drives out good, its the stopping and suspension issues that have me at my wits end.
    Just waiting for the attorney to ring my phone as i type, i can not keep throwing money at this car.
    my girl is 5`4", the car fits her perfectly. im 5`11" and its not comfortable enough for me to ride in it that long.
    after a hour, im so sore i can hardly stand. no way i could trek across the country in it.
    Coinsidence...I'm 5'11" also and fit and feel real good behind the wheel, my wife is only 5'.
    I was realy disapointed when I heard that the 2011 models were the last of the HHR's. I intended to trade mine in 2015 for another one because they're so good, economical and reliable.
    I am looking very closely to the new arrival the "Chevrolet Sonic" as probably being my futur purchase. It not a new name for the Aveo like people think, it's completely a new car and much better than the Aveo.
    Follow UP.
    My car went from bad to worse. Yesterday the dealer said you have plenty of brake pad it is fine. And since I didn't buy it from them it wasn't their problem. I drove home, they failed, and i had a small fender bender. I called GM they called the dealer. Dealer agreed it was the rotors and they would fix it on MONDAY but as long as i didn't try to go to far i should be able to drive it around town (like to work).
    After work today the break light and traction lights come on, on the way home from work. The right hubcap is covered in something brown. The brakes go to the floor. Bottom line it was TOWED to the shop. I really hate this car. If i wasn't so upside down in it I would trade in a heart beat.
    The upside is GM agrees the bill is on them b/c i have had it in their dealer shops 5 times for same complaint over the course of 18 months and 30,000 miles.
    Hopefully they will be able to fix it tomorrow. I don't know what caused the extensive problems today but I suspect the warped rotor broke the brake pad which broke the brake fluid hose. I will update tomorrow.
    Just an update,
    New drilled front rotors and pads installed, and new rear drums and shoes.
    i left the abs/traction main fuse out. so far its better, but i only have a little use on them today.
    I`ll report back in a week, this should be plenty of time for them to show issues if there will be any.
    after a weeks use, i`ll put the abs/traction fuse back in. if the vibrations comes back, off to the dealer i go.
    Oh,
    i need to bleed the brakes tomorrow, for some reason the brake peddle is almost to the floor now.
    got a few weeks on the new brake, they are actually holding up pretty good.
    i had to pull the rear drums once already to clean out the brake dust. i was getting a bad noise and grabbing out of the right rear, but after cleaning the dust out the noise grabbing went away.
    looks like so far i wont need the electric vacuum pump.
    right front hub is getting worse, so i`ll be taking it back to the dealer soon.
    ordering a g-force performance chip in a week or two, going to see if i can squeeze a few more miles per-gallon out of the 2.4L. if the chip saves me 4 gallons per-week, thats 20 bucks left in my pocket.
    anyway, the chevy hhr is still a piece of crap. GM knows it as well, thats why they stopped production in 2011.
    In a more "positive note"...I think the HHR is a great vehicule.
    The HHR started in 2005 and G.M. will end it's production in 2011.
    I've owned 8 vehicules, all G.M. products (cars/trucks/vans/S.U.V's) in my 37 years of driving in all kinds of weather and for your infomation...the HHR is the best one of them all and I was disapointed when I heard about it's last year of production being the 2011 model because I was planning on trading my 2010 HHR 2LT for a 2015 HHR.
    Do you think that I would trade my HHR for another HHR if it was a "piece of crap" like you mention?.
    My 06' (bought in 05) has also been pretty good so far (have 130,00 miles on it). Only time will tell if it ends up being good for a long time. Avg MPG display is down to 30MPG with winter temps (last reset late last summer)
  • imdisgruntledimdisgruntled Member Posts: 6
    Personally I think the last 2 statements were from GM employees, I have had a Chev car my whole life and have never owned such na piece of crap. Yes, I complained on here and got a quick "Take it in" replay and they fixed it, so Customer service was alot better once a Public complaint was seen. I just don't see or have heard anybody that thought the car wasn't crap.
    Nope!
    My job consists of being on the road across the United States and Canada (nothing to do with G.M. by the way) and since 2005 I saw a lot of happy HHR owners with incredible mileage on their vehicles, (that's why I decided to buy one).
    Some days I could see 20...30 or more HHR's passing by.
    Must be because lots of people out there like to buy "crap" as their family car?
  • chevygirl_09chevygirl_09 Member Posts: 1
    Hi, I am having the same problem, but my car is a 2010. Could you please forward me all of the contact information you used to get your car fixed?
  • cowboyhhrcowboyhhr Member Posts: 1
    I have a 2007 HHR. It has 40,000 miles on it. I love this car (of course it's not a good as my camaro was). The only problem I've had with it is the the brakes. I hear a noise while my windows are down and the whole front end vibrates when I push the brake pedal. I'm getting ready to replace the rotors and pads. I was told NOT to replace them with OEM parts, because the problems I'm having will just come back. Does anyone have any recommendations on where I should buy my parts and/or specific brand I should buy?
    Ebay. Look for cross drilled rotors. Don't waste your money on anything else.
  • msjpmsjp Member Posts: 1
    I bought the 2006 HHR new first year they came out, actually 6/06, in 07 had brake problems, dealer fixed front rotors, was still under warranty, 2009 same problem, dealer fixed front rotors cost $300.00, 2010 same problem, dealer fixed front rotors at a cost of $400, now 2012 same problem, front rotor problems, besides other problems, leak in transmission line, shift arm breaking away from assembly, brake flush besides brake problems, trans. fluxh and the list goes on & on for a cost of over $1200.00 or more, only 47717. miles, not even 10,000 miles a year, are they kidding or what, chevys are not what they used to be. :cry:
  • burgliburgli Member Posts: 1
    I know that your post is old, but I've had the same problems too with my '06. I can't afford the $1,500 it's going to cost to replace everything and was looking to see how many others out here have had the same problems. I'm hoping for a recall. I've had the problem for about three years now. It's ashame because I do like the car with the exception of everything about it is more expensive to fix than most cars.
    Yes my '06 is the same, I have fixed it a couple of times already and had GM fix it once even after the 4 yr warranty expired, because I complained on here.
    I now have the same rattle and shake front end issues yet again. There definitely should be a recall.
  • gmcustsvcsarahgmcustsvcsarah Member Posts: 1,964
    msjp,
    I'm sorry you've encountered so many difficulties with your HHR. How is everything going on the most recent repairs (rotors, transmission line, and so on)? If you should need anything, please let us know!
    Best,
    Sarah
    GM Customer Service
  • koderjm1koderjm1 Member Posts: 1
    Does this brake problem carry over into newer models, like 2008 or 2009 HHR?
    I love this car too. I finally took it to a autoworks shop that works on European cars (how funny is that) but a friend of mine is a mechanic there and he fixed it by redoing the brakes, pads, and replacing the rotors I believe. I have not had any vibration problems for a year now. I think that GM should make a recall on these models. GM should step up to the plate because it is all about taking care of their customers which they don't seem to get. I think the GM that my parents knew truly did believe in their customers. When one hears a constant problem that involves the same model car-hello is anybody at GM listening?
  • txdayetxdaye Member Posts: 1
    I recently purchased my 2006 HHR LT this week with 114k miles on it and quickly discovered that my steering wheel shakes/vibrates when I apply the brakes. I took it to the tire shop to make sure the new tires that were on there were balanced. They were not so I had them balance them. I still have the shaking problem. I love love love this car already but I am very concerned about this problem and how much money it is going to take to find and repair this problem. HELP!!???? :cry:
    The answer is throughout this forum. Replace the rotors yourself. GM is not going to help you. I bought rotors from Ebay which were cross drilled for cooler running, new pads, all for about $130. I did the work myself which was easy. Demos are on YouTube. The stock rotors are absolute junk and there is no other answer. Believe me.
  • pacrat707pacrat707 Member Posts: 1
    I had the same problem and my deaer would not honor my extend warrentee, brakes being a wear item. I went on-line to "Autoanything" (saw an add in a magazine in dealers waiting room.) I ordered "POWERSTOP rotors and ceramic break pad kit #K3116". Installation is straight forward. Good instructions, quality parts. Rotors are drilled through and slotted. Break in is unusual, so follow the instructions closely. I installed mine November, waiting to see if all would go well over a few thousand miles. My HHR's braking is as smooth as silk. braking is strong and steady. I love my car again and I think you will too. Cost last year was $179.89 which includes Calif. taxes and shipping. Got order in 3 days. Good luck. Bob
  • raceyjnkraceyjnk Member Posts: 1
    Well as many of you have found, we too had a big problem with the front brakes on our 09 SS. We have 19k on it, we bought it new and its still under the bumper to bumper 36mo. The front brakes were metal to metal this week! Back brakes are still over 90%. I took it to the dealer where we bought it, at first they claimed "normal wear". I pointed out all the forums I had discovered, didnt mean much to them, at first. Service manager told me he just did his front brakes on his HHR at 85k, I asked him why mine didnt last that long and he was a bit flustered and couldnt answer me. This is my 56 yr old wifes car, I could understand part of it if it was a 19 yr old guy driving it........Anyway, the dealer called me last nite and offered to turn the rotors and replace the pads for free, customer goodwill. They got it done this morning and it drives fine. We had no shake or other tell tale sign till it was metal to metal. The big thing that convinced them was, 2k miles ago it was at their dealership for an oil change and they marked all the brakes as in perfect condition during the 29 point check, so they wore out in 2k miles? Not likely. We have been buying cars from this location since the 70's and when they considering the big picture, well they came to the right conclusion. They stepped up. Now I know this isnt the overall fix and in a few thousand miles I will order 4 slotted and drilled rotors with ceramic pads and do the whole brake system. Jim
  • maintxmaintx Member Posts: 1
    I am starting to feel a slight shake in my steering wheel and my back, driver's side brake grabbed when I had to stop quick. Rear of car started to do a jack-knife motion until I let up off of my brake pedal.
    Rear wheels are making a slight squeaking when I start off at slow speeds until I drive faster. Then it seems to stop until I park and start again.
    Just adding to the complaints. Any advice/suggestions? GM please recall before someone gets killed. :sick:
  • patolivajpatolivaj Member Posts: 1
    Yes I have a 2008 hhr ,the fix the brakes 6 time or more and they can found a solution and they don't care ,last time the GM said they will no pay for the fix but the dealer manager take care of the bill for me, I never come back but the car don't make noise only for a few weeks and then the problem back, I never buy a Chevrolet in my live again, he car was only a 1000 miles the first time now is 37000 without solution
