Towing with a Honda Pilot
Other than the obvious fact of adding a trailer hitch and the electrical hookup, are there any changes/modifications that need to be made to the drivetrain to ensure that the vehicle is ready to tow?
See Also
Honda Pilot Specifications
See Also
I tow a 19Ft Stingray Bowrider total weight 3,600 lbs (boat, trailer, full gas-gear) Above post is correct, with factory towing package is 4500lbs. It tows alright but on highway, transmission is constantly shifting gears. The boat is usually docked for summer and boat ramp is 4 miles from my house. We did not want a minivan or a full size pickup and the Pilot is the best compromise!
Hope this helps out any.
Odie
Odie's Carspace
The dealer that I purchased my Pilot from installed my hitch at no charge.
Odie
Odie's Carspace
Thank you, in advance, for your replies. ABSAV
Any experience with this?
Also, what does it cost to get the factory-approved towing package installed on a used Pilot? Anyone know?
So, how about my other question? How does the Pilot suspension handle towing a boat that may be about 3500 lbs? I know that it's rated OK for that weight, but in real life, how well does it handle it? Does the back end sag and cause your headlights to shine too high (and irritate all the drivers who think you have your brights on?). Yeah, that happens with my Pathfinder.
The problem is with the electrical plug in the rear of the Pilot. It is a 4 Pin connector for towing utility trailers and boats. Travel trailers require a 7 pin connector and a brake controller.
Any ideas on who, can install the 7 pin connector or the wiring for the brake controller?
Kip
See the postings over on the Pilot Maintenance and Repair forum last page.
Bottom line is that the Pilot has a 4 pin electrical connector. A four pin connector will operate the trailer external lights; tail lights, Running lights, brake lights, and turn signals.
Travel trailers also require wiring to operate the electric brakes and to charge the "House" battery. That involves a 7 pin connector. Therefore a 7 pin connector is standard for travel trailers and will not plug in to your Pilot. Honda does not offer a 7 pin connector. Or any type of wiring for the electric brake controller that mounts under your dash.
That type of wiring would need to be done by a trailer or hitch dealer. Any problems that might/could occur with the Pilot wiring could possibly be traced back to the aftermarket wiring and void your warranty on electrical issues. Be careful!
Common trailer towing practices suggest the trailer weight {loaded} not be over 85% of the maximum tow rating of the (tug) tow vehicle. That would dictate a maximum loaded trailer weight of 2975 pounds. The 15% margin is there to deal with mountains, strong head winds and the like.
It is real easy to add several hundred pounds to a travel trailer without realizing it. Even at 3072# you are over the suggested "Safe rate"! Many TT published weights are for the basic trailer and do not include options such as AC, Awnings, Stabilizer jacks, antennas, spare tire, and such. So be absolutely sure of your "as equipped" weight plus things you add, such as water, dishes, electric heaters, and such.
Other Problems! Trailer tongue weights should be at least 10-15% of the TOTAL TRAILER WEIGHT. Therefore a 3000+# trailer could have a tongue weight of 300-450#. Even when loaded properly, upright hard sided trailers will find any excuse in the world to "SWAY". Cross winds and 18 wheelers being the major causes. A sway can get out of control and result in an accident. To deal with the weight and sway there are Weight Distributing Hitches and sway controls available. Good news?
Not with Honda! For the Pilot and the Ridgeline, They say, "We do not recommend the use of Weight distributing hitches". Yet they say to check with your trailer sales agency for proper equipment. The problems could be that the Pilot is basically a Front wheel drive. Pathfinder and 4Runners, which are rear wheel drive, offer the stuff necessary to tow. 7 pin connector, wiring pig tail for the under dash brake controller, and a serious tranny oil cooling radiator, instead of the pipe with fins offered by Honda.
Fixing up the P/U truck and towing with it just might be the best bet!
Kip
We are thinking of TTs now, and are considering one option to stay real small, and keep our Pilot. This is probably our 3rd or 4th potential avenue
used 3/4 truck - 5th wheel
used suburban - ~30' heavy travel trailer
used escalade - ~28' lighter travel trailer
and now I am going to see if we can agree on a 20' hybrid weighing about 3000 lb and stay with the Pilot - going to burst my wife's bubble cause she has been on cloud nine thinking she could get an escalade
Would either a Pilot or an older MDX be able to handle that amount of towing? Has anyone had experience with towing slightly outside the ratings?
I have a 2006 Pilot with the dealer installed tow package. I will be towing a boat and trailer weighing around 2800-3000 lbs. The electrical connection at present is a 'four-flat'. One male ground and three female power for lights, turn signals, brakelights, etc.
The surge brake actuator on the boat trailer comes with a solenoid lockout that, when you place the vehicle in reverse, the solenoid engages and inserts a pin behind the coupler and prevents the actuator from engaging the brakes so you can back up. This configuration requires a 'five-flat' plug.
My question is: Can I safely tie into the reverse light wiring without screwing up something in the vehicle to provide the voltage to the solenoid to engage the pin?
Are there any other options? The parts guy at Honda didn't know what the term 'five-flat' meant. I found that curious though not unexpected.
FC
FC
Is this normal???? I had a Chevy Astro van that would get 15 mpg while towing a similar size trailer.
Tx.
Mark
I am getting ready to ditch my 1994 Pathfinder and I am looking at the Honda Pilot as a replacement. Does anyone have experience with towing off road? I have a weekend cabin where 8 to 10 times a year I need to tow a garden tractor on a utility trailer. I know there shouldn't be a problem towing 20 miles to the cabin, but I have about 100 yards of a (fairly solid) gravel and dirt lane that is moderately up and down hill. The total towing weight of the tractor and trailer etc. is 2000 to 2500 lbs.
Occasionally my tractor will fail (from dead battery etc.) and I will need to drive to a spot where I have been mowing and pull the tractor out in order to get it on the trailer and in for service.
So what do you think, is the Pilot up to this kind of task? (95% of the time this will be an around town vehicle).
I thought that might be the case as I never needed the 4L on my Pathfinder for getting up, down and around.
We were looking for something nice around town, esp. in the winter, and the better half wished for a car like crossover before she thought about the needs at the cabin.
I purchased a 4WD EXL a couple of weeks ago. While I am sure the vehicle will suit my needs for the little off-road towing I need, the manual does state that the weight limit for towing off-road is 1000 lbs.
Are there any other options with the existing Honda 4 pin wiring that I can tap and connect to a blue wire of the 5 pin connector.
It will be used to tow a small box trailer with my Harley and some other kit in it, 2.5k lbs max. Newly handicapped I'm towing rather than riding my bike around now.
Then I read about the trans problems w/2003 :-(
Is there an easy way to see if the necessary transmission modification has been made?
The Honda Service Department hasn't seen the car since 90k mile check-up. Copies of their service records are on the way. They want $2k for timing belt, water pump etc. and once they have it they'll surely hit me up for brakes, shocks, etc. My trusted mechanic can do this for much less of course and I'm leaning that way.
Thoughts solicited. Thanks!
Bill
Also, I read that I shouldn't use my included anti-sway weight distribution bar with the Pilot...is that true?
You will kill your transmission and need $7K in repairs in 6 months. That is my prediction. Should you sell your trailer? Yes, or your Honda. If you tow something that exceeds the rating of your vehicle, you will void the warranty, and put yourself and your passengers at risk of injury in an accident.
By the way, we rented a large Toyota Sequoia SR5 and that thing had a hellacious towing capacity. Maybe you need a different SUV or a pickup truck. Just saying.
Odie
p.s. - the main picture on the website is a GMC Terrain pulling it, which in turn is smaller than the Pilot anyway.
Do I need to look for a particular kind of hitch on the Pilot?
Would towing wear be extremely detrimental to the Pilot?
Thanks for any advice; I don't know very much about the topic.
Cheers,
Travis
Odie
With a good set of opposable thumbs, the hitch and wiring harness can be installed. Three bolts on each side. Open the rear driver side tire jack compartment to find the plug n' play harness wiring receiver. ~$140 eBay, 1 hr
As for the tranny cooler (VIP) & Power steering cooler (LIP; Less Important Piece), one must progress to the Anthropithecus Era. See this great install vid https://youtu.be/T0MTQiLi_i4. ~$50 eBay, 2-3 hrs (curse you bumper clips!)
