the dealer said it's normal and its just the ABS
only happens when I first start the engine
anybody have the same experience
08 v6 access with automatic and 4wd
I'm really disappointed. Thanks for sharing your story with the rest of us.
Marty
vibration, Had mine replaced with heaver mount,Moter was vibrating
at 20 mph.Call your deler new bullitin out on this.
rear motor mount,With new heaver mount to stop motor from Vibrating at low
speed Had mine replaced stoped vibration.
hever mount,Stops drive line vibrations also.
this
None of that has resolved the issue. Only one thing resolved the issue. Removing the rear drive shaft and driving it on the front drive. And in some sort of, well I don't know, they have decided to obtain a lift kit with an angle to adjust the drive line angle to factory. (despite it still having the issue when the brought it to factory height with factory tires) :confuse:
I have been telling them that I think it is the transfer or transmission, but they are refusing to look at it at this point.
No, I am not a mechanic, and no I did not stay at a Holiday Inn Express, but I think that the transfer and/or transmission should be looked at.
Anybody have any ideas or wisdom? Any good lawyers want to take this on? LOL
8 weeks in the shop is a bit excessive, especially because the loaner they give is a Corolla, which an 8ft ladder doesn't quite fit in.
Good luck with yours.
It is very annoying when drivin gon the highway. I will be forced to drive at 70 to avoid this vibration!
What should I do? Can I return it using the lemon law? :lemon:
1) Drifts right - don't notice this
2) vibration in drive line - don't notice this
3) front brake squeal - don't hear this
4) rough idle - seems smooth to me
5) transmission or transfer case leak - don't see a one drop of fluid
6) muffler weak - sounds just fine, quiet
7) wires corroded on 4 wheel drive switch - said he don't how my 4 wheel drive is working cause the wires are corroded totally off
8) A.C. low on charge - works great for me
So what's up with them? Are any of these detrimental requiring immediate servicing?
