Lincoln LS Vibration
Has anyone had a vibration that could not be solved ??
I recently bought a 2006 LS. right off the bat i felt a vibration, Lincoln checked the tires for balance, tires OK, Vibe still there, Lincoln checked again, 1 wheel out of balance, Vibe still there, Brought the car to Michelin to check, all 4 wheels out of balance, Vibration still there. Went to a Ford Dealer instead of Lincoln, they found that the Drive shaft was balanced, but out of alignment. Fixed, Vibration still there. I need Help, I cant even do 65 down the freeway without my fillings falling out of my teeth. And apparently Ford and Lincoln have no clue. The car has only 12,000 miles on it. Any help would be apprecitate, Thanks, Tim
Tire bubble?
How long since you had the wheels balanced? How old are the tires?
Have tried EVERYTHING........................ Can't get rid of it.
Maybe it wasn't greased well from the factory? Wow, $700 for a driveshaft, but parts aren't cheap for these cars. Good luck.
