Best wishes
If anyone gets a classaction suit going count me in!
In the mean time, I have a complaint in with Honda (800 number) because I feel the dealer was negligent in diagnosing the problem. What are the key words to use that might get them to start taking all of these transmission failures seriously?
If someone does get the ball rolling as far as a class action suit, I'm ready to jump on the bandwagon. I think Honda has a much larger problem with these transmissions than they want to admit to.
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Details: ON SOME MINI VANS, SPORT UTILITY AND PASSENGER VEHICLES, CERTAIN OPERATING CONDITIONS CAN RESULT IN HEAT BUILD-UP BETWEEN THE COUNTERSHAFT AND SECONDARY SHAFT SECOND GEARS IN THE AUTOMATIC TRANSMISSION, EVENTUALLY LEADING TO GEAR TOOTH CHIPPING OR GEAR BREAKAGE.
Consequence: GEAR FAILURE COULD RESULT IN TRANSMISSION LOCKUP, WHICH COULD RESULT IN A CRASH.
Corrective Action: ON VEHICLES WITH 15,000 MILES OR LESS, THE DEALER WILL UPDATE THE TRANSMISSION WITH A SIMPLE REVISION TO THE OIL COOLER RETURN LINE TO INCREASE LUBRICATION TO THE SECOND GEAR. ON VEHICLES WITH MORE THAN 15,000 MILES, THE DEALER WILL INSPECT THE TRANSMISSION TO IDENTIFY GEARS THAT HAVE ALREADY EXPERIENCED DISCOLORATION DUE TO OVERHEATING. IF DISCOLORATION EXISTS, THE TRANSMISSION WILL BE REPLACED IF DISCOLORATION IS NOT PRESENT, THE DEALER WILL PERFORM THE REVISION TO THE OIL COOLER RETURN LINE. THE RECALL BEGAN ON APRIL 21, 2004, FOR PILOT, ODYSSEY, AND MDX OWNERS. OWNERS OF THE ACCORD VEHICLES WILL START RECEIVING LETTERS ON JUNE 28, 2004, AND ON JUNE 29, 2004, FOR OWNERS OF THE TL AND CL VEHICLES. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Units Potentially Affected: 1099796
Recall Initiated By: MFR
Date added to NHTSA datbase: 04/20/2004
File Your complain online -NHTSA
http://www-odi.nhtsa.dot.gov/ivoq/
Worst of all, my extended warranty just went out a month ago at 99K. I have 101K on it now.
Has anyone had any luck with the "Goodwill Repair" or ANYTHING for that matter to get some kind of assistance from Honda?
My check engine light never came on which is really weird as the jerking or high RPMs before moving to the next gear are both really severe.
I am Sooooooo disappointed in my Honda now and I loved it just last week. I'm trying to figure out how much this is going to set me back and if I do use someone outside of the dealer to fix it, who I should be talking to.
Looks like I'll be driving less one "arm & a leg" by the end of the day.
I too am very disappointed that my transmission went at 75k miles. My 5 year extended warranty ended one year earlier (had not max'd out on miles ... just years).
Good luck with the Goodwill repair. My dealership said they were willing to work with me since I had been a loyal customer ... but I think they realize there is something wrong with their transmissions ...
Suggest everyone with the tranny problem file a complaint to NHTSA
It is not just us... This was not random, I saw a lot of 2003 -2004 having the same problems and these were just the once reported. Any filed action lawsuit?
Have to call Honda back tomorrow so will let you know what happens.
kijam99@yahoo.com
I love my Pilot but will my next car be a Honda? Probably not. Honda needs to own up to this problem!
Tranny fluid replaced with Honda original, looking on the service records - previous owner serviced it at Honda dealer. Tranny shifting hard and slips sometimes. Gets worse after long highway ride.
Filed complain with NHTSA cause hardly missed another car when slipped when merging highway.
That's curious. Did you notice any other signs of damage on the underside of your wife's Pilot?
SUVs and Smart Shopper
Is honda going to help you out at all on the cost?
Do you also have other lights on, like check engine light?
Do post your current miles and transmission maintenance history
Good luck
