Dodge/Plymouth Neon Thermostat Problems
                    I am leaking Anti-freeze from the where thermostat housing and cylinder head meet. My father-in-law told me it was the thermostat housing gasket that was leaking but i can not seem to find that part anywhere. The only thing that i can find that is similar is a thermostat seal. this is just a small white circular piece of rubber not the traditional rubber seals that I have seen before. Can anyone tell me if this is the correct gasket or is it some special order part? It is a Fel-Pro Thermostat Seal part # 35588. Thanks.
When you drain a cooling system and refill it. There MAY be more than what you took out. Provided you didnt spill or have a leak. The reason is that when you are putting the coolant back in, there is air inside the motor. And as your engine fills the air becomes trapped inside the motor with the coolant. Usually on the "backside" of the thermostat.
To prevent this problem this you should bleed the system as you are refilling.
You can do this by adding coolant then starting the engine and as it the engine warms up you add a little more at a time. To do this properly it should take about 10 - 20 minutes, watching your gauge periodically at the same time.
This could also explain why some of the other people on here are having overheat problems after certain fixes.
And you would be totally correct when you said no heat means no or low coolant levels!
Happy Motoring
changed it had no problems, not today got below zero again, and now the same problem i have not yet taken the thermostat out but i bet it will be the same, any reasons why it keeps happening like this. thanks. :mad:
