Owners Manual Maintenance ??'s
Hello
I have a beautiful 2003 Xr I love it Prob. the best car I've owned.
When I bought it I didnt realize that it didnt have an Owner's amnual or service log.
If there's any1 out there with the 03 matrix Xr tell me the mfg maintenance schedual up to 60K?
Mainly looking for
Auto Trans Fluid
Timing Belt
and any other major stuff
Mainly looking for
Auto Trans Fluid
Timing Belt
oil and filter change, every 5K
tire rotation, every 5K
cabin air filter replacement, every 20K
underhood air filter replacement, every 30K
The coolant is the 100K-mile stuff, and the plugs are due for replacement at 120K. No transmission oil/fluid replacement is recommended at all for routine use, and I remember from my '03 there is actually a sticker on the auto trans dipstick that says that too. Now of course, there have been many skeptics on these boards that have said you'd be crazy not to change it, but the manufacturer has not said you need to, so you be the judge. As for me, my new car is a manual, and I will probably change the transmission oil somewhere along the way before 100K miles, even though it isn't called for in the schedule.
Finally, these are NOT the dirt road/towing intervals. If you do either of those regularly, you need to do other stuff as well (including transmission fluid changes every 30K if you tow).
I was losing faith in some1 responding.
It sounds like Toyota has an easy service maintenance plan.
I will prob. flush out the coolant and trans (Auto) b4 100K miles. Why not be on the safe side.
My Kia Sorento plan is crazy
Timing belt change @ 40K and again @80K
Trans Fluch @ 60K
Diff. Fluid @ 20, 40, 60K
Very expensive to maintain the warranty on it.
Thanks again for the info
In reality the sprockets and chain tensioner typically get noisy ~200-300K miles.
