Anyways, the changed my door jams thinking I had gotten Armor-All or something jammed in there, even though I told them this was not the case. They did this only after I complained to the GM about the service department.
They also said I could try replacing the BCM if that didn't work. I have the number for Saturn Corporate who I am going to ask to pay for the new BCM since the individual stores do not do that.
I have also lived with this 4 winters and have documentation of each time I took it to the dealer and they could never recreate the problem. I'll keep you posted if I can get Saturn to pay and if that works.
I currently drive an 02 Vue, 5spd 2.2L. My DRL's didn't come on yesterday while driving home from work. The DRL indicator light on the dash blinks a couple times, then goes out. All the fuses are in good order, but were replaced anyway. The relays also are in good working order. My dad works for the company that makes the relays, and they are in good shape. I remember seeing a voluntary recall on this DRL issue, but cannot find the slip for it. Anyone know where I can find the recall info for ones not made mandatory by the government? It would make life much easier.
My 03 Vue 5spd 4cyl 107K mi is asking to go to the auto auction. Many front end problems, but most frustrating are the electrical issues starting to show up.
Random security horn blasting and lights flashing, electrical door locks cycling on and off, interior and instrumentation lighting triggering on and off, wipers turning on randomly...
Sounds like what many of you have experienced. Is there a way to reset the computer? Disconnect the battery for short time?
Bad body control module? $800? Ugh..."> :lemon:
Shortly after we got the vehicle (It was 2 years old and had 17,000 miles on it), the sunroof was left open during a rain shower. That seemed to trigger interior lights staying on and coming on while we were driving. Banging on the lights themselves didn't seem to help, but working the switch on the driver's side of the dash board (the one the door pushes) seemed to help. It hasn't acted up for a while now.
We're happy enough with the vehicle for now, but I'll think hard before I get another Saturn.
Yesterday afternoon, our '04 Vue freaked out like so many of you said. Shifting from 1st to 2nd, it died. Restarted, and drove downhill to town. It repeated this behavior a couple times, and we decided to turn around. Up hill on the way home, it really lagged on the power. If it was in neutral a little, I could rev the engine and get going. I hate to do that to my transmission and clutch. Also experienced the weird electrical stuff: turn signal indicator on dash would blink really fast or really slow when the turn signal was on.
I HAD NO IDEA SO MANY OTHERS WERE EXPERIENCING THESE PROBLEMS. WHAT'S IT TAKE TO GET A RECALL ON THESE THINGS?
Thanks for all your comments. I guess, in some warped way, it's comforting to know we're not the only ones suffering from these things.
Basically, I believe it all stems from my sunroof. Both drains to the sunroof have had issues, getting clogged or broken. This causes water to be leaked down the pillar and into some electrical component. Eventually the water dries and the electrical issues disappear. I live in Florida so dont have an explanation for the "cold" issues.
A summary of my issues throughout the years that have corrected themselves with time once the vehicle had time to dry out: Every door lock had issues not working at somepoint, thankfully not at the same time. Interior lights coming on & flashing w/o any prompting. Alarm going off for no reason. Transmission not shifting out of second gear. Rear wiper staying on when in the office position.
After leaving the sunroof propped up in the rain, I am now struggling with my latest battle. No dash controls & No power steering. The check engine light/ service engine light comes on. My mechanic couldnt figure it out and said I would need to go to Saturn as it was likely the Body Control Module. I refuse to go because I know it will dry out over time. I'd rather save my money then contribute it to the ponzi scheme of dealership service!
Does anyone know where the BCM is? If I could figure out where it is and put a cool blow dryer on it, I am confident I could fix the issue.
i have the same issue and suspect it is from water getting into the electical components from my sunroof.
i am hoping it dries out bc i really dont want to donate a significant portion of my saving to the dealership! but driving around w no dash controls and no power steering is getting old quick!
What I have done is bypass the place where the ground contact is broken. Although it works, I believe I would be better off to actually find where the ground is broken and get that point working again. Right now, all the stuff on that circuit (turn signals, compressor, horn, etc.) are using the horn ground and my patch wire to get enough ground to operate properly.
Restarting engine removed everything but check engine light. Is there any possible connection between the lights and the belt slippage? I have read enough nightmares about chronic problems with the reduced power light... this is my first
any way water could be leaking in through your sunroof? thats what gave me the problem.
1. The BCM needs to be replaced - Dealer only repair as they have to program it to your make and model. Since there are no Saturn dealers left, go to a Chevy dealer, the Equinox is essentially the same vehicle. About $ 600.00 give or take...Its located behind and just below your radio.
2. The grounds for the BCM need to be checked. They tend to get corroded on early models and will cause the same problems that you describe. They are located under the hood on the right as you're looking from the front.
Good Luck
I am from GM Customer Service. I know you don't want to go to the dealership, however I would recommend at least going to get the vehicle diagnosed. It could very well be something from the wiring from your trailer plug but, you cannot be sure without someone looking at it. Thank you,
Mariah GM Customer Service
M
I am from GM Customer Service. As far as the warranty is concerned it depends on who it’s through. If it’s a GM warranty then any GM dealership should honor the warranty on the vehicle. GM warranty transfers to the new owner. However, if it’s a dealer warranty, you will have to have the work done at that specific dealership in order for it to be covered under warranty. Thank you,
1 - Body Control Module failure - A dealer only repair about $ 600-700
2- Body Control Module grounding issue - a lot cheaper than # 1 since they have to clean the grounds under the hood.
Is there another fusebox that I need to check? Or does anybody have a suggestion that will help me fix this?
good luck..... :shades:
