Welcome to the Edmunds forums! We are changing the way you sign into our forums. Click here to learn more.
Honda Pilot Wet Carpet from Leaks
2»
  • How can I access the photos of where to fix the Honda Pilot leaks? We have TWO 2004 Honda Pilots and they both leak on both sides. I tried using the link in these forums but it just takes me to the main Edmonds page and I don't know how to access your Carspace page. Thanks for your help!
  • How do I access photos on your Carspace page so that I know where to apply the RTV silicone to help prevent leaks? I clicked on links in prior posts but none work (including a Honda Service Advisory which I was really eager to read.... said I was "not authorized" to open the PDF... frustrating!) We own TWO 2004 Honda Pilots and both leak in the same areas - driver & passenger side carpet. Thanks for your suggestions & help!
  • steverstever Posts: 52,683
    CarSpace was retired and all the photos went away. Sorry!
  • bud57bud57 Posts: 1
    My 03 Pilot leaks on both sides also, and I have taken the front seats out, carpet, and the console. I soaked the car with water hose and nothing showed up. I ran the defrost and nothing. I,m taking it to the carwash tomorrow for more water pressure. Check back for an update. I am determined, I WILL FIX THIS LEAK.
  • Well, here's what we found... There are drain holes in the front corners of the sun roof opening. There are tubes that run down to the front fender wells. Thing is, they don't run to the BOTTOM, they come out about a foot ABOVE the floorboard! Then, there is a hole at the very bottom of the fender well that the water is supposed to drain out of. The problem with this is that the genius engineers did not seal off the fender wells - they are completely open to the engine compartment. When we looked in the wells - they were FULL of leaves that had blown in from the engine compartment. So, of course that plugged up the drain hole. When the water came out of the tube, since it couldn't drain out....
    We cleaned out the wells, and, unable to think of anything else, we used spray foam to fill the opening from the engine compartment to keep more leaves from getting in. I know DARE someone at Honda to laugh at the foam if I have to take it in to them for anything!
    Hope this helps!!!
  • cooldeezcooldeez Posts: 6
    After my father asked me to take a look at his 05 Pilot to determine where the water on the floorboards was coming from. I quickly looked through some of the posts here and started to perform my own investigation. What I found was a trail of deposits coming from a hole in the interior body just behind the hood latch release on the interior driverside. Inside the hole there are deposits as well. I figured that if I filled the hole with water and then started to spray water on the exterior I might be able to narrow down the choices because I would be able to quickly see a rise in water level. I was never able to introduce additional water. I then took a water hose from the outside, with the inner fender well plastic removed and the mud flap I sprayed water directly on each seam and noticed that my water level started to drop. Somehow I was able to help it drain, so with that I started to hit the seam with air pressure. Apparently there was enough debris in the seams that when I added more water to the interior compartment it just flowed right out the seams. I have not been able to get the same compartment to hold water yet. I assume that the factory needed to seal the seam edges, which is where the run-off water from the above windshield drain runs over on its way to the mud flap. I took some seam seal and filled the entire exposed seam. I am leaving the interior panels off in both corners to monitor the progress. I repeated the same repair process on the passenger side, with seam seal to the seam edges. Hope this helps. I took photos of the entire process just incase someone might need them.
  • I'm not familiar with seam seal. And yes, would like to see pics of what you did. ([email protected])
    I sent you an email with pics, if you do not receive let me know.
    After my repairs to the 05 Pilot I took it for a long drive in the pouring rain and could not detect any more water on the floorboard. I believe that would be referred to as "Problem Solved" for now. If I hear of any more issues I will be sure to update you, but for now....its not in my garage.
  • jbstrawbjbstrawb Posts: 1
    I'd like to get those pictures as well. Thanks in advance.
    What is the best way to send the photos to you?
    If you'll put your pics on Flickr or tinypics or some other photo hosting site and link to them, then anyone visiting here in the future will be able to find and view them.
  • Any chance I can get those pictures as well? Here's my email address: [email protected]
  • Can you post the pictures for all of us. Thanks.
    I would love to...however I cant seem to figure out how. I have tried repeatedly to post a link but I doesnt seem to work on this forum. So instead of sending people on links to nowhere I figure I can send the picture pretty easy too...
  • cris45cris45 Posts: 1
    Hello Shooter, I have the same issue with my 05 pilot.. Any chance you can send me those pics too? [email protected] THANKS!
  • I've got the same wet carpet issue. If you still have pics, can you send them to me?
  • My leak was caused by leaves coming in from the non-sealed engine compartment and piling up in the fender well just in front of the driver door (some on the passenger side, but not nearly as bad). Some genius engineer decided to run the drain for the sunroof down into the fender wells. Not all the way to the bottom - that would have actually made sense. The tube comes out several inches above the bottom of the well. Sooo, when the leaves filled up the bottom where the drain hole was - of course the water from the sunroof couldn't drain out so it backed up and into the floor of the passenger compartment. We cleaned all the leaves out and, cause we couldn't think of another way - used the expanding spray foam to seal where the leaves were coming in from the engine compartment. Yeah, it looks pretty hokey when you open the hood - but the carpets are dry and the car no longer floods or stinks! :-)
    edited October 2012
    Here is a link to the pictures I took during the repair process. I can still say that even now, my repair is still keeping the interior dry. I live in the NW so needless to say we have plenty of opportunities to test my repair. If you have any further questions please feel free to message me.
    link">http://sdrv.ms/Tmrk4T
  • cooldeez - Could you send me pics/info on your leak repair please Thank you [email protected]
    The pics are still up at the link posted above.
  • I have the same wet floor on the passenger side. I removed the interior trim and took the nut off the fusebox so I could pull it back and see what was happening. I found a round hole on the vertical surface that is approximately 3/4". When I pushed a rolled up paper towel in there it immediately was saturated. I then put a popsicle stick partway in the hole and water rolled out. It is clear there is a cavity behind that hole and it is filled with water. When I drive it comes out and soaks the carpet. It was hard to tell where it was coming from until I pulled the fusebox away from the body. I don't know if there is supposed to be a plug in this hole, and if there is a way for the water to drain out of that cavity. Will take outer body parts off on the next dry day to try to figure it out, but that is definitely where the water is coming from in my Pilot. Please comment if you have the same issue. Thank you.
  • berriberri Posts: 8,539
    edited March 2017
    We had a problem like that years back on a Taurus. Turned out to be a seal related to the outside air intake ahead of the windshield. Might also check around the inside cabin air filter.
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 60,696
    It sounds like you have a plugged drain in the fresh air intake cavity (under the wipers). This is a common cause of wet carpets in the front of the car. Very often you have to remove that front grille to access the drain. The terminus of the drain is usually in the middle of the firewall, behind the engine. If the drain hole is plugged, which happens when debris gets in there from parking under trees, etc., then you are driving around with a fish tank---this cavity is not meant to be waterproof, only water resistant, using rubber grommets that hold wires and cables, etc.
    Other common issues would be clogged sunroof drains, which are easily tested by opening the roof, looking for the drains in the rails, and pouring a little water into them--you should see the water exiting immediately from underneath the car, usually behind the front wheel and in front of the rear wheel.
    MODERATOR --Need help with anything? Click on my name!
    Share Your Vehicle Reviews Here
  • I had wet passenger side carpet on my 04 pilot. I read the comments and removed the seat, and glove box. The carpets were soaked. Water was dripping from the ac unit. I opened a small tab and water poured out. Removing the metal piece behind the glove box, the small tab was part of a door to access the cabin filter. I pulled the filter out, It was filthy. TOTALLY CLOGGED!! I cleaned the filter real good and dried out and cleaned what i could. I 'm thinking this may do the trick. The drain was working from what I could see on the ground, but the filter was so clogged it he'd back water from the drain. At least I hope so. Time will tell.
  • PF_FlyerPF_Flyer Pennsylvania Furnace, PAPosts: 8,175
    That's typically the issue when you see wet passenger side carpets. Kind of a maintenance issue rather than a "defect". New posts in topics like this are my reminder to go check mine ;)
    I'd bet you've solved the problem!
    Need some roadside assistance? [email protected] - or send a private message by clicking on my name.
    Just purchased or leased a vehicle? Share your vehicle reviews
    PF_Flyer's 2014 Versa Note Long Term Blog
    How To Start Your Own Long Term Blog
  • isellhondasisellhondas Issaquah WashingtonPosts: 20,150
    You CLEANED your cabin filter? Actually you are supposed to REPLACE it I think every 30,000 miles!
    They are made of pleated paper so I'm wondering how you were even able to clean it!
2»
